[GeoNode-devel] GeoNode release 3.1: call for testing
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Mon Nov 9 01:44:36 PST 2020
Dear devs,
while GeoNode 3.1 is almost ready to be released, we ask for help with
functional tests.
You can find here below a link to a spreadsheet with a long series of tests
to be done. There are two sheets, one for functional tests and one for
installation and deployment methods.
Anyone can edit and modify the spreadsheet, so be careful.
Any help is much appreciated!
*P.S.: **Whenever you need temporary superuser access to the reference
instance, please write privately to the genode-psc mailing address
(geonode-psc at lists.osgeo.org <geonode-psc at lists.osgeo.org>) or contact one
of the PSC members.*
https://docs.google.com/spreadsheets/d/1sce9CaZCJD1e12r21INrxyDRohxz0IYGDiPLLK9e808/edit?usp=sharing
Best,
Alessio.
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
http://www.geo-solutions.it
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20201109/1c4e9efa/attachment.html>
More information about the geonode-devel
