[GeoNode-devel] GeoServer crashed in GeoNode 2.10
Paolo Pasquali
paolo.pasquali at gmail.com
Mon Nov 23 01:28:01 PST 2020
Dear devs,
While updating some layers metadata using the GeoNode admin UI, suddenly
GeoServer crashed and now I'm not able to restart it anymore.
>From the logs I get some errors:
ERROR [context.ContextLoader] - Context initialization failed
org.springframework.beans.factory.BeanCreationException: Error creating
bean with name 'wcsService-1.0.0' defined in URL
Invocation of init method failed; nested exception is
java.lang.IllegalStateException: Could not locate a layer or layer group
with id LayerInfoImpl-52979d4a:172b8fc663e:-33fe within GeoServer
configuration, the GWC configuration seems to be out of synch
I have this kind of error related to several layers. My guess they are
related to the layers I tried to update in the admin ui.
The solution I've found on the web suggests removing the layers from the
gwc-layers folders and then running updatelayers.
Is this the only solution? Is there a painless fix?
Thanks for your help.
Ciao
P.
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20201123/497bb90c/attachment.html>
More information about the geonode-devel
