[GeoNode-devel] geonode-devel Digest, Vol 81, Issue 7
Ahmed Osman
ahmednosman at cartologic.com
Tue Feb 22 12:15:19 PST 2022
On Tue, Feb 22, 2022 at 6:00 PM <geonode-devel-request at lists.osgeo.org>
wrote:
> Send geonode-devel mailing list submissions to
> geonode-devel at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
> https://lists.osgeo.org/mailman/listinfo/geonode-devel
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> geonode-devel-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of geonode-devel digest..."
> Today's Topics:
> 1. Ready for 3.2.3 and 3.3.1 releases (Alessio Fabiani)
> 2. Re: geonode-devel Digest, Vol 81, Issue 3 (Giovanni Allegri)
> Message: 1
> Date: Tue, 22 Feb 2022 11:01:00 +0100
> From: Alessio Fabiani <alessio.fabiani at geosolutionsgroup.com>
> To: geonode-devel <geonode-devel at lists.osgeo.org>
> Subject: [GeoNode-devel] Ready for 3.2.3 and 3.3.1 releases
> Message-ID:
> <CAK_Rad=
> eQ_n2UMU0nGXBQn0nePCa_z_rVFXSeQWYDrtx8B18qA at mail.gmail.com>
> Content-Type: text/plain; charset="utf-8"
> Release process started for:
> - GeoNode 3.2.3
> - GeoNode 3.3.1
> Changelog will be sent accordingly as soon as the releases have been done.
> Regards,
> Alessio Fabiani
> GeoServer Professional Services from the experts!
> Visit http://bit.ly/gs-services-us for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions Group
> phone: +39 0584 962313
> fax: +39 0584 1660272
> mob: +39 333 8128928
> https://www.geosolutionsgroup.com/
> http://twitter.com/geosolutions_it
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
> 2016/679 - Regolamento generale sulla protezione dei dati ?GDPR?), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) ? un dato la cui conoscenza ?
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le ? giunto per errore, ? tenuta/o a cancellarlo, ogni altra
> operazione ? illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 ?GDPR? - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <
> http://lists.osgeo.org/pipermail/geonode-devel/attachments/20220222/d86c3959/attachment-0001.html
> Message: 2
> Date: Tue, 22 Feb 2022 16:47:05 +0100
> From: Giovanni Allegri <giovanni.allegri at geosolutionsgroup.com>
> To: geonode-devel at lists.osgeo.org
> Subject: Re: [GeoNode-devel] geonode-devel Digest, Vol 81, Issue 3
> Message-ID:
> <CAE2GR-f36ZGEibxo=
> M8b7c5y4ahXKHwjgU9pjY3Hy0d9-STciw at mail.gmail.com>
> Dear Pattara,
> 1. Importing of GeoPackage files seems not supported yet. Is it just not
> >> yet implemented or are there any big obstacles against supporting it?
> I confirm that importing a GeoPackage is not currently supported neither
> in GeoNode nor in the Geoserver Importer extension, which is employed by
> GeoNode for the ingestion of new datasets (so I guess that this isn't
> available in Cartoview too).
> The implementation would be quite challenging but, as usual, it's doable if
> sufficient funds are available.
The Geopackage Upload function is available in CartoView as an independent
app that is not a part of geonode, from this app the user can
- Select a number of layers and download these layers as one geopackage
very useful for backup
- Upload a geopackage that contains a number of layers and in this case it
will automatically load all these layers at once instead of loading the
data one by one.
> >> 2. Does GeoNode already have a concept or implementation of layer
> >> analysis,
> >> e.g., user picks a layer, do some actions e.g., create buffer, or merge
> it
> >> with another layer, then save as another new layer? If we are to do it,
> do
> >> you have suggestions on how it should be done?
> Currently, GeoNode doesn't provide analysis tools. You can create
> dashboards and add widgets (charts, tables, etc.) to a map but only as
> visualization tools.
> GeoNode uses the OGC services provided by its cartographic backend, which
> is Geoserver.
> Potentially you could leverage the WFS service and implement your tools in
> a custom client app (either as a MapStore plugin or a standalone custom
> view published as a custom Django view), using a library like Turf.js
> <https://turfjs.org/>.
> With the help of GeoNode APIs, you could publish the results back as a new
> dataset, or alter the original dataset via WFS-T.
> >> 3. The following plug-ins/feature of MapStore seem to disappear in the
> >> Mapstore that is embedded in GeoNode. Is it possible to enable them?
> >> * config search service / create,edit search service
> >> * export map application to mapstore config format, WMC format
> >> * import map context file: MapStore legacy format, WMC and vector layer
> >> files: shapefiles (must be contained in zip archives), KML/KMZ, GeoJSON,
> >> Annotations or GPX to map application
> >> * add/edit Catalog layer service
> As already mentioned by others, we disabled this functionality on purpose,
> since maps configurations are stored and managed as GeoNode maps.
> A map export might be useful if map layers are public, otherwise, you lose
> the authentication and authorization services provided by GeoNode.
> A map import would work, but you would end up publishing a map with layers
> completely disconnected from GeoNode.
> Anyway, if you wish to have these plugins in a custom GeoNode client build
> of yourself you might give a look at the development documentation for the
> client
> https://github.com/GeoNode/geonode-mapstore-client/blob/master/docs/customizations/index.md
> >> 4. We have created a few custom plug-ins that adding something on the
> >> displaying map, but those stuff won't be on the printed output. Any
> >> suggestions on how do we customize the printing module to include those
> >> things?
> Printing is provided by a Geoserver extension. Basic support to print
> custom elements is provided by Vector layer params
> https://docs.geoserver.org/stable/en/user/extensions/printing/protocol.html#vector
> This is what for example MapStore uses to print map annotations.
> Best,
> Giovanni
> Dott. Giovanni Allegri
> Technical Lead / Project Manager
> GeoSolutions Group
> fax: +39 345 2815774
> URL: <
> http://lists.osgeo.org/pipermail/geonode-devel/attachments/20220222/7930b7d4/attachment.html
> Subject: Digest Footer
> End of geonode-devel Digest, Vol 81, Issue 7
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20220222/5b88bbcc/attachment.html>
More information about the geonode-devel
