[GeoNode-devel] GeoNode 4.0.0rc0 + Keycloak
Pattara Kiatisevi
pattara at longdo.com
Sun May 29 18:31:41 PDT 2022
I confirm it was the same case. Setting SOCIALACCOUNT_LOGIN_ON_GET=True
solved the problem.
Thank you very much,
Pattara
On Wed, May 25, 2022 at 4:32 PM Giovanni Allegri <
giovanni.allegri at geosolutionsgroup.com> wrote:
> We also notice that some changes introduced in the latest versions of
> django-allauth has some small changes that require adapting something in
> the integration with GeoNode.
> django-allauth 0.44.0 is two years old. Several fixes have been introduced
> meanwhile, including security improvements.
> We would prefer to figure out and solve the problems rather than reverting
> it inside GeoNode.
> For example, in our case, the problematic configuration
> was SOCIALACCOUNT_LOGIN_ON_GET, which is False by default. Recent versions
> of django-allauth require a POST request to initiate the login flow, and it
> was causing some problems to us.
> Were you able to spot what was causing the problem with Keycloak?
> Giovanni
> On Wed, May 25, 2022 at 10:44 AM Pattara Kiatisevi <pattara at longdo.com>
> wrote:
>> Changing back to django-allauth 0.44.0 seems to solve the problem at the
>> moment.
>> $ git diff requirements.txt
>> diff --git a/requirements.txt b/requirements.txt
>> index 50c578230..be55ef0e8 100644
>> --- a/requirements.txt
>> +++ b/requirements.txt
>> @@ -27,7 +27,8 @@ rdflib==6.1.1
>> smart_open==6.0.0
>> # Django Apps
>> -django-allauth==0.50.0
>> +#django-allauth==0.50.0
>> +django-allauth==0.44.0
>> django-appconf==1.0.5
>> django-celery-results==2.3.1
>> django-filter==21.1
>> Cheers,
>> Pattara
>> On Fri, May 6, 2022 at 7:32 PM Giovanni Allegri <
>>> Thanks for reporting this Pattara.
>>> We have used Keyclok in several contexts in the past but we haven't had
>>> the chance to test it with GN 4 yet.
>>> Would you kindly open an issue on the GeoNode repo to keep track of it?
>>> Best,
>>> Giovanni
>>> On Thu, May 5, 2022 at 12:03 PM Pattara Kiatisevi <pattara at longdo.com>
>>> wrote:
>>>> Hi,
>>>> We used to set up a GeoNode 3.3x + Keycloak site according to
>>>> https://gist.github.com/t-book/0fb30804e217bdeb064dd91b5041fbc9 and
>>>> things worked well.
>>>> Now as we are trying GeoNode 4.0.0rc0, following the same steps. But
>>>> when clicking at the "Sign in with Keycloak" link (which is something like
>>>> https://<keycloak-hostname>/account/keycloak/login/?process=login&next=%2F
>>>> ), it doesn't redirect the user to the Keycloak site, but instead got stuck
>>>> at geonode.
>>>> When checking that URL, we found that if the request is made with HEAD
>>>> (i.e., curl -I), the response seems to be correct (HTTP 302, redirecting
>>>> users to Keycloak).
>>>> [image: image.png]
>>>> But when using browsers or normal curl (curl -v -o /dev/null "https://<geonode-hostname>/account/keycloak/login/?process=login&next=%2F",
>>>> it responds with HTTP 200, which is wrong.
>>>> [image: image.png]
>>>> Any input is really appreciated.
>>>> Thank you very much in advance,
>>>> Pattara
>>>> _______________________________________________
>>>> geonode-devel mailing list
>>>> geonode-devel at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/geonode-devel
>>> GeoServer Professional Services from the experts!
>>> Visit http://bit.ly/gs-services-us for more information.
>>> Dott. Giovanni Allegri
>>> Technical Lead / Project Manager
>>> GeoSolutions Group
>>> phone: +39 0584 962313
>>> fax: +39 345 2815774
>>> https://www.geosolutionsgroup.com/
>>> http://twitter.com/geosolutions_it
>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>>> precisa che ogni circostanza inerente alla presente email (il suo
>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>> This email is intended only for the person or entity to which it is
>>> addressed and may contain information that is privileged, confidential or
>>> otherwise protected from disclosure. We remind that - as provided by
>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>> e-mail or the information herein by anyone other than the intended
>>> recipient is prohibited. If you have received this email by mistake, please
>>> notify us immediately by telephone or e-mail.
> GeoSolutions Group
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20220530/fc9adbd9/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20220530/fc9adbd9/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20220530/fc9adbd9/attachment-0003.png>
More information about the geonode-devel
