[GeoNode-devel] GeoServer Error while installing custom geonode-project with paver
Rafael Sá
rafael.sa at ua.pt
Fri Sep 30 04:42:48 PDT 2022
Hello everyone,
I am installing a GeoNode project (version 3.3.2, installation without Docker) on a new machine, and after run the commands paver setup and paver sync, I start with paver start but I am getting the following error:
java.lang.ClassNotFoundException: org.geoserver.GeoserverInitStartupListener
at java.base/jdk.internal.loader.BuiltinClassLoader.loadClass(BuiltinClassLoader.java:581)
at java.base/jdk.internal.loader.ClassLoaders$AppClassLoader.loadClass(ClassLoaders.java:178)
at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:522)
at org.eclipse.jetty.webapp.WebAppClassLoader.loadClass(WebAppClassLoader.java:543)
at org.eclipse.jetty.util.Loader.loadClass(Loader.java:64)
at org.eclipse.jetty.servlet.BaseHolder.doStart(BaseHolder.java:88)
at org.eclipse.jetty.servlet.ListenerHolder.doStart(ListenerHolder.java:73)
at org.eclipse.jetty.util.component.AbstractLifeCycle.start(AbstractLifeCycle.java:72)
at org.eclipse.jetty.servlet.ServletContextHandler.startContext(ServletContextHandler.java:350)
at org.eclipse.jetty.webapp.WebAppContext.startWebapp(WebAppContext.java:1445)
at org.eclipse.jetty.webapp.WebAppContext.startContext(WebAppContext.java:1409)
at org.eclipse.jetty.server.handler.ContextHandler.doStart(ContextHandler.java:855)
at org.eclipse.jetty.servlet.ServletContextHandler.doStart(ServletContextHandler.java:275)
at org.eclipse.jetty.webapp.WebAppContext.doStart(WebAppContext.java:524)
at org.eclipse.jetty.util.component.ContainerLifeCycle.start(ContainerLifeCycle.java:169)
at org.eclipse.jetty.util.component.ContainerLifeCycle.doStart(ContainerLifeCycle.java:117)
at org.eclipse.jetty.server.handler.AbstractHandler.doStart(AbstractHandler.java:97)
at org.eclipse.jetty.server.Server.start(Server.java:408)
at org.eclipse.jetty.util.component.ContainerLifeCycle.doStart(ContainerLifeCycle.java:110)
at org.eclipse.jetty.server.Server.doStart(Server.java:372)
at org.eclipse.jetty.runner.Runner.run(Runner.java:520)
at org.eclipse.jetty.runner.Runner.main(Runner.java:565)
2022-09-29 17:46:41.378:WARN:oejw.WebAppContext:main: Failed startup of context o.e.j.w.WebAppContext at 2641e737{GeoServer,/geoserver,file:///home/odyssey/odyssey/src/geoserver/geoserver/,UNAVAILABLE}{../geoserver}
javax.servlet.UnavailableException: Class loading error for holder ListenerHolder at 38102d01{STARTING}: org.geoserver.GeoserverInitStartupListener
at org.eclipse.jetty.servlet.BaseHolder.doStart(BaseHolder.java:95)
I can't understand what seems to be the problem here, as I installed before on other machine and had no problems.
Any help?
Regards,
Rafael
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20220930/a0949263/attachment.htm>
More information about the geonode-devel
