[GeoNode-devel] Practices on maintaining a geonode project, PR: "Align to GeoNode master 4.2.0"
Florian Hoedt florian.hoedt at thuenen.de
Tue Aug 1 03:57:26 PDT 2023
Thank you two for the insights,
I think we should take some time and funding to enable a better development experience. Other projects make it easier to add to the core. Most of the time those other projects are not as complex as GeoNode though. Maybe we as developer community could articulate and define the most urgent issues and we (Thünen-Institute) will try to get funding to smoothen the path?
Yours,
Florian
MSc Florian Hoedt
Head Research Data Management | OpenData Representative
Thünen Institute, Centre for Information Management
Bundesallee 44
38116 Braunschweig
Tel: +49 531 596-1428 | Mobile: +49 162 92 50 275
Fax: +49 531 596-1499
Mail: florian.hoedt at thuenen.de
Web: www.thuenen.de
The Johann Heinrich von Thünen Institute, Federal Research Institute for Rural Areas, Forestry and Fisheries – Thünen Institute in brief – consists of 15 specialized institutes with socioeconomic, ecological and technological expertise. The Thünen Institute conducts research and policy advice related to rural areas, agriculture, forests and fisheries.
Von: "Toni Schönbuchner" <toni.schoenbuchner at csgis.de>
An: "Henning Bredel" <h.bredel at 52north.org>
CC: "geonode-devel" <geonode-devel at lists.osgeo.org>
Gesendet: Dienstag, 1. August 2023 11:55:41
Betreff: Re: [GeoNode-devel] Practices on maintaining a geonode project, PR: "Align to GeoNode master 4.2.0"
H Henning,
Interesting approach. It seems even the blog you mention agrees with you when saying "[...] so we had to help all developers apply the filter. That is one downside: it’s totally quiet, so failures aren’t readily surfaced." :-)
Exactly. It somehow always felt wrong.
Especially Devs not familiar with Geonode had a hard time understanding what
is going on ;))
BQ_BEGIN
However, I still assume changes in your working copy
BQ_END
Correct, I also have to make some small tweaks in my working copy.
But trying to keep them as simple as possible:
BQ_BEGIN
- INSTALLED_APPS
BQ_END
I did not touch settings.py except having the following in the end:
# custom settings
try :
from .my_custom_settings import *
except ImportError :
pass
Doing so I can extend and override what ever I need like INSTALLED_APPS, but keep the rest of settings untouched.
Of course only things get into my_custom_settings that cannot be configured via .env anyways
BQ_BEGIN
- docker/-compose files
BQ_END
Similar as with settings I do override certain parts with a custom compose file
docker-compose -f docker-compose.yml -f docker-compose-custom.yml up -d
[ https://docs.docker.com/engine/reference/commandline/compose/#use--f-to-specify-the-name-and-path-of-one-or-more-compose-files | https://docs.docker.com/engine/reference/commandline/compose/#use--f-to-specify-the-name-and-path-of-one-or-more-compose-files ]
Doing so docker-compose.yml can stay as
BQ_BEGIN
or requirements.txt
BQ_END
Good point! I’ve just changed it and left a comment before my changes.
But I guess it should also work to mount your requirements into the container
and override the start command a bit:
entrypoint: ["/usr/src/geonode/entrypoint.sh", "bash", "-c", "pip install --no-cache-dir -r custom_requirements.txt && uwsgi --ini /usr/src/geonode/uwsgi.ini“]
(Untested, and leaving a comment in requirements.txt might be cleaner in that case ;)
BQ_BEGIN
These changes can be kept at a minimum and probably in a local branch, of course. Did you also try different approaches with regard to customizing geonode-mapstore-client, or do you prefer programming a completely different UI (probably this depends ;-))?
BQ_END
To be honest, I have blocked adaptations for clients here as much as possible. Mainly because the reactive part of mapstore2 doesn't make it easy to develop (but that's due to my lack of knowledge).
Also maintaining a fork is something I like to prevent.
In some cases I have developed small custom viewers that only have geonode as a data provider.
In one particular case, I decided to listen for WFS requests, process them as needed and create some DOM elements. This is of course a very messy solution as the virtual DOM should not be touched. But in this case it could be accepted and I avoided a custom build ;) To get the idea.
// Catch WFS request
var elements = [];
(function() {
var origOpen = XMLHttpRequest.prototype.open;
XMLHttpRequest.prototype.open = function() {
this.addEventListener('load', function() {
if (this.responseText.includes(’something')){
window.items = JSON.parse(this.responseText);
do_something()
origOpen.apply(this, arguments);
// Create the button that opens the compare tool
waitForElm("#drawer-menu-button").then((elm) => {
console.log(„mapstore is ready“);
// I guess there is a mapstore event we can listen on ...
drawer = document.getElementById("mapstore-drawermenu");
var i = document.createElement("i");
i.classList.add("bi", "bi-arrow-left-right", "switch_icon");
var _button = document.createElement("button");
_button.setAttribute("id", "compare_button");
_button.setAttribute("data-bs-toggle", "offcanvas");
_button.setAttribute("data-bs-target", "#offcanvasRight");
_button.setAttribute("aria-controls", "offcanvasRight");
_button.appendChild(i);
_button.classList.add(
"square-button",
"ms-drawer-menu-button",
"btn",
"btn-primary"
drawer.appendChild(_button);
and so on. Again this is of course a no no ;)
Hope this helps,
Cheers
Toni
geonode-devel mailing list
https://lists.osgeo.org/mailman/listinfo/geonode-devel
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20230801/da2ec80d/attachment-0001.htm>
More information about the geonode-devel mailing list
