[GeoNode-devel] Node version compatibility for Geonode-mapstore-client
    Mrinmoy Pal
    mrinmoy21pal at gmail.com
    Mon Apr 29 06:14:41 PDT 2024
Hello All,
Hope you are well!
Could you please look into the mail guide if we still need to use node v12
or v14 to Geonode-mapstore-client? Actually these versions are quite old
and might be vulnerable.
Regards,
Mrinmoy Pal
mailto: mrinmoy21pal at gmail.com
On Tue, Apr 23, 2024, 13:57 Mrinmoy Pal <mrinmoy21pal at gmail.com> wrote:
> Dear All,
>  I am trying to compile the geonode-mapstore-client.
> However, I am getting error when trying to compile and run with node v20
> or v21.
> Could you please suggest which is the latest node version that should be
> used to run this repo? If we use node v12 or v14 isn't that outdated and
> vulnerable?
> Regards,
> Mrinmoy Pal
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20240429/d45b6c19/attachment.htm>
More information about the geonode-devel
