[GeoNode-devel] Geoserver 2.27.3-latest with geonode 4.4.x?
Giovanni Allegri giovanni.allegri at geosolutionsgroup.com
Fri Dec 19 01:55:50 PST 2025
Hi Toni,
I think it should be fine. We haven't done many tests, but I did one some
time ago and everything looks good.
Giovanni
On Wed, Dec 17, 2025 at 8:52 AM Toni Schönbuchner via geonode-devel <
geonode-devel at lists.osgeo.org> wrote:
> Good morning,
> regarding CVE-2025-58360.
> Does one know if geonode 4.4.x is fine with running the latest
> geoserver build 2.27.3-latest as master does?
> https://github.com/GeoNode/geonode/blob/master/docker-compose.yml#L95
> Best regards,
> Toni
> geonode-devel mailing list
> https://lists.osgeo.org/mailman/listinfo/geonode-devel
GeoServer Professional Services from the experts!
Visit http://bit.ly/gs-services-us for more information.
Dott. Giovanni Allegri
Technical Lead / Project Manager
GeoSolutions Group
phone: +39 0584 962313
cell:     +39 345 2815774
fax:      +39 0584 1660272
https://www.geosolutionsgroup.com/
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20251219/bdd10dc1/attachment.htm>
More information about the geonode-devel mailing list
