[GeoNode-devel] GeoServer Patches 2.24
Giovanni Allegri
giovanni.allegri at geosolutionsgroup.com
Tue Jan 27 00:46:35 PST 2026
Harald,
The CVE is still present but ineffective for a standard GeoNode deployment
because, as I said, the vulnerability is blocked by Geofence.
Anyway, you can upgrade to Geoserver 2.27.4 on GeoNode 4.4.x. It's not
officially supported, but it's proven to work fine.
Giovanni
On Tue, Jan 27, 2026 at 9:31 AM Harald von Waldow <
harald.vonwaldow at thuenen.de> wrote:
> Hello Giovanni,
> Geoserver instances running 2.24.4-v2 (GeoNode Docker image) were
> flagged by BSI as vulnerable ("Software verwundbar für CVE-2025-58360.
> Nachweis erfolgte mittels Proof-of-Concept."). Not sure what to make of
> that.
> Best
> Harald
> On Mon, 2026-01-26 at 17:02 +0100, Giovanni Allegri via geonode-devel
> wrote:
> > Sorry for the very late reply Henning.
> > Geoserver for GeoNode is safe thanks to Geofence, which doesn't allow
> > those requests.
> > The block is at the source code level, so it's ssfe whatever the
> > Geofence configuration.
> > Giovanni
> > GeoServer Professional Services from the experts!
> > Visit http://bit.ly/gs-services-us for more information.
> > Dott. Giovanni Allegri
> > Technical Lead / Project Manager
> > GeoSolutions Group
> > phone: +39 0584 962313
> > cell: +39 345 2815774
> > fax: +39 0584 1660272
> > https://www.geosolutionsgroup.com/
> > http://twitter.com/geosolutions_it
> > Con riferimento alla normativa sul trattamento dei dati personali
> > (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati
> > “GDPR”), si precisa che ogni circostanza inerente alla presente email
> > (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui
> > conoscenza è riservata al/i solo/i destinatario/i indicati dallo
> > scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a
> > cancellarlo, ogni altra operazione è illecita. Le sarei comunque
> > grato se potesse darmene notizia.
> > This email is intended only for the person or entity to which it is
> > addressed and may contain information that is privileged,
> > confidential or otherwise protected from disclosure. We remind that -
> > as provided by European Regulation 2016/679 “GDPR” - copying,
> > dissemination or use of this e-mail or the information herein by
> > anyone other than the intended recipient is prohibited. If you have
> > received this email by mistake, please notify us immediately by
> > telephone or e-mail.
> > Il ven 19 dic 2025, 17:19 Bredel, Henning via geonode-devel
> > <geonode-devel at lists.osgeo.org> ha scritto:
> > > Hey,
> > > GeoServer [disclosed a
> > > CVE](https://github.com/geoserver/geoserver/security) some weeks
> > > ago:
> > > - [CVE-2025-
> > > 58360](https://github.com/geoserver/geoserver/security/advisories/G
> > > HSA-fjf5-xgmq-5525)
> > > Is it safe to use 2.24.4 referenced by the geonode-project [0]. I
> > > am not aware of any fixes/patches in geonode-docker or elsewhere.
> > > Did I miss something?
> > > Best
> > > Henning
> > > [0]
> https://github.com/GeoNode/geonode-project/blob/f5824531e3cb23d7899d6446bac3530bbfb69b58/.env.sample#L13
> > > Henning Bredel
> > > adesso SE
> > > Klaus-Bungert-Straße 5
> > > 40468 Düsseldorf
> > > T +49 211 740759-00
> > > M +49 151 56463626
> > > E henning.bredel at adesso.de
> > > www.adesso.de
> > > blog.adesso.de
> > > >>> business. people. technology. <<<
> > > adesso SE mit Sitz in Dortmund
> > > Vorstand: Mark Lohweber (Vors.), Benedikt Bonnmann, Kristina
> > > Gerwert, Michael Knopp,
> > > Andreas Prenneis
> > > Vorsitzender des Aufsichtsrates: Prof. Dr. Volker Gruhn
> > > Amtsgericht Dortmund HRB 20663
> > > _______________________________________________
> > > geonode-devel mailing list
> > > https://lists.osgeo.org/mailman/listinfo/geonode-devel
> Dr. Harald von Waldow
> Senior Research Data Specialist
> Thünen Institute
> Centre for Information Management
> Bundesallee 44
> 38116 Braunschweig, Germany
> Web: https://thuenen.de
> The Johann Heinrich von Thünen Institute, Federal Research Institute
> for Rural Areas, Forestry and Fisheries – Thünen Institute in brief -
> consists of 15 specialized institutes with socioeconomic, ecological
> and technological expertise. The Thünen Institute conducts research and
> policy advice related to rural areas, agriculture, forests and
> fisheries.
GeoSolutions Group
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-devel/attachments/20260127/ae80e06a/attachment.htm>
More information about the geonode-devel
