[GeoNode-users] migrate geonode 2.4 to another server
Simone Dalmasso
simone.dalmasso at gmail.com
Fri Apr 3 08:38:41 PDT 2015
Shouldn't the geonode-updateip command do this?
2015-03-31 13:54 GMT+02:00 Paolo Corti <pcorti at gmail.com>:
> It looks to me to be a bug, could you file a ticket?
> Thanks
> Meanwhile what you can do is to manually update the base_links table
> with something like (not tested):
> update base_link
> set url = replace(url, 'old_ip', 'new_ip')
> p
> On Tue, Mar 31, 2015 at 1:16 PM, Alessandro Burastero
> <alessandro at acrotec.it> wrote:
> > i've truncated the base_link table and then i've run the geonode
> > updatelayers command (and also updatelayerid)... but the base_link table
> > remains empty
> > Alessandro
> > On 31/03/15 11:39, Paolo Corti wrote:
> >> I have no way to test this right now but I believe that truncating the
> >> base_links table and running the updatelayers command should fix this.
> >> Before doing this action do a backup and try it on just one layer
> >> (removing the links related to only that layer from the base_links
> >> table)
> >> You may also need to run the updatemaplayerip command.
> >> p
> >> On Tue, Mar 31, 2015 at 11:08 AM, Alessandro Burastero
> >>> Hi guys
> >>> i need to migrate my geonode 2.4b22 to another server (same os: ubuntu
> >>> 14-04
> >>> and same geonode version)...
> >>> I tried doing it in this way:
> >>> - copy the geoserver data, styles and workspace directory in the new
> >>> server
> >>> - domp via pg_dump and restore via psql the geonode database
> >>> the result is that geonode recognize all layers but it cannot view them
> >>> because all links in the layer metadata contains the old server
> >>> address...
> >>> haw can i solve it?
> >>> thanks in advance
> >>> Alessandro
> >>> _______________________________________________
> >>> geonode-users mailing list
> >>> geonode-users at lists.osgeo.org
> >>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
> Paolo Corti
> Geospatial software developer
> web: http://www.paolocorti.net
> twitter: @capooti
> skype: capooti
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150403/6388161f/attachment.html>
More information about the geonode-users
