[GeoNode-users] migrate geonode 2.4 to another server
Paolo Corti pcorti at gmail.com
Tue Apr 7 01:04:39 PDT 2015
Definitely that is the best way, totally forgot about that command :)
we need to add it to the documentation
(http://docs.geonode.org/en/master/tutorials/admin/commands.html#commands)
by the way
cheers
p
On Fri, Apr 3, 2015 at 5:38 PM, Simone Dalmasso
<simone.dalmasso at gmail.com> wrote:
> Shouldn't the geonode-updateip command do this?
> 2015-03-31 13:54 GMT+02:00 Paolo Corti <pcorti at gmail.com>:
>> It looks to me to be a bug, could you file a ticket?
>> Thanks
>> Meanwhile what you can do is to manually update the base_links table
>> with something like (not tested):
>> update base_link
>> set url = replace(url, 'old_ip', 'new_ip')
>> p
>> On Tue, Mar 31, 2015 at 1:16 PM, Alessandro Burastero
>> <alessandro at acrotec.it> wrote:
>> > i've truncated the base_link table and then i've run the geonode
>> > updatelayers command (and also updatelayerid)... but the base_link table
>> > remains empty
>> > Alessandro
>> > On 31/03/15 11:39, Paolo Corti wrote:
>> >> I have no way to test this right now but I believe that truncating the
>> >> base_links table and running the updatelayers command should fix this.
>> >> Before doing this action do a backup and try it on just one layer
>> >> (removing the links related to only that layer from the base_links
>> >> table)
>> >> You may also need to run the updatemaplayerip command.
>> >> p
>> >> On Tue, Mar 31, 2015 at 11:08 AM, Alessandro Burastero
>> >>> Hi guys
>> >>> i need to migrate my geonode 2.4b22 to another server (same os: ubuntu
>> >>> 14-04
>> >>> and same geonode version)...
>> >>> I tried doing it in this way:
>> >>>   - copy the geoserver data, styles and workspace directory in the new
>> >>> server
>> >>>   - domp via pg_dump and restore via psql the geonode database
>> >>> the result is that geonode recognize all layers but it cannot view
>> >>> them
>> >>> because all links in the layer metadata contains the old server
>> >>> address...
>> >>> haw can i solve it?
>> >>> thanks in advance
>> >>>      Alessandro
>> >>> _______________________________________________
>> >>> geonode-users mailing list
>> >>> geonode-users at lists.osgeo.org
>> >>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
>> Paolo Corti
>> Geospatial software developer
>> web: http://www.paolocorti.net
>> twitter: @capooti
>> skype: capooti
> Simone
Paolo Corti
twitter: @capooti
skype: capooti
More information about the geonode-users mailing list
