[GeoNode-users] migrate geonode 2.4 to another server
    Alessandro Burastero
    alessandro at acrotec.it
    Tue Apr  7 05:25:05 PDT 2015
Thanks Simone... now i can install the b24 release
...but i confirm that the command geonode-updateid doesn't update the
base_link table... here is the steps made to migrate the datas
- install geonode
- run geonode createsuperuser
- run geonode-updateip
- copy (and replace) from old server:
     - /usr/share/geoserver/data/data/geonode
     - /usr/share/geoserver/data/workspaces
     - /usr/share/geoserver/data/styles
     - /var/www/geonode/uploaded/thumbs
- backup the old geonode store db and restore it in the new server
- modify the connection settings in the geoserver datastore (change the
password)
now i have all the layers defined correctly in the geoserver and also in
geonode... but all the links (also the WMS) pointing to the old
geoserver, even if i run a geonode-updateip.
the only way to se the link to the new geoserver is to manually update
the base_link table as Paolo sudjest (update base_link set url =
replace(url, 'old_ip', 'new_ip') ).
Alessandro
On 07/04/15 11:33, Simone Dalmasso wrote:
> Alessandro I just released the b24 which fixes the error. I apologize
> for it :)
> 2015-04-07 10:34 GMT+02:00 Alessandro Burastero <alessandro at acrotec.it
> <mailto:alessandro at acrotec.it>>:
>     mmm i tried the geonode-updateip but i didn't worked... maybe i
>     made something wrong...
>     ...now i'm testing again the procedure, but i can't install the
>     new geonode beta 23 in a new ubuntu 14-04 intallation... the
>     following error appear during the geonode postinstall step:
>     Running GeoNode postinstall ...
>     Traceback (most recent call last):
>       File "<string>", line 1, in <module>
>     ImportError: No module named geonode
>       File "/usr/bin/django-admin", line 5, in <module>
>         management.execute_from_command_line()
>       File
>     "/usr/lib/python2.7/dist-packages/django/core/management/__init__.py",
>     line 399, in execute_from_command_line
>         utility.execute()
>       File
>     line 392, in execute
>         self.fetch_command(subcommand).run_from_argv(self.argv)
>       File
>     line 261, in fetch_command
>         commands = get_commands()
>       File
>     line 107, in get_commands
>         apps = settings.INSTALLED_APPS
>       File "/usr/lib/python2.7/dist-packages/django/conf/__init__.py",
>     line 54, in __getattr__
>         self._setup(name)
>     line 49, in _setup
>         self._wrapped = Settings(settings_module)
>     line 132, in __init__
>         % (self.SETTINGS_MODULE, e)
>     ImportError: Could not import settings 'geonode.settings' (Is it
>     on sys.path? Is there an import error in the settings file?): No
>     module named geonode.settings
>       File
>         utility.execute()
>       File
>       File
>       File
>         self._setup(name)
>     line 49, in _setup
>     ...while the update from the beta22 goes well
>     thanks again
>     Alessandro
>     On 07/04/15 10:11, Paolo Corti wrote:
>         Uh forget my comment about documentation, I have just realized
>         that
>         geonode-updateip is a bash script and not a django command.
>         cheers
>         p
>         On Tue, Apr 7, 2015 at 10:04 AM, Paolo Corti <pcorti at gmail.com
>         <mailto:pcorti at gmail.com>> wrote:
>             Definitely that is the best way, totally forgot about that
>             command :)
>             we need to add it to the documentation
>             (http://docs.geonode.org/en/master/tutorials/admin/commands.html#commands)
>             by the way
>             cheers
>             p
>             On Fri, Apr 3, 2015 at 5:38 PM, Simone Dalmasso
>             <simone.dalmasso at gmail.com
>             <mailto:simone.dalmasso at gmail.com>> wrote:
>                 Shouldn't the geonode-updateip command do this?
>                 2015-03-31 13:54 GMT+02:00 Paolo Corti
>                 <pcorti at gmail.com <mailto:pcorti at gmail.com>>:
>                     It looks to me to be a bug, could you file a ticket?
>                     Thanks
>                     Meanwhile what you can do is to manually update
>                     the base_links table
>                     with something like (not tested):
>                     update base_link
>                     set url = replace(url, 'old_ip', 'new_ip')
>                     p
>                     On Tue, Mar 31, 2015 at 1:16 PM, Alessandro Burastero
>                     <mailto:alessandro at acrotec.it>> wrote:
>                         i've truncated the base_link table and then
>                         i've run the geonode
>                         updatelayers command (and also
>                         updatelayerid)... but the base_link table
>                         remains empty
>                         Alessandro
>                         On 31/03/15 11:39, Paolo Corti wrote:
>                             I have no way to test this right now but I
>                             believe that truncating the
>                             base_links table and running the
>                             updatelayers command should fix this.
>                             Before doing this action do a backup and
>                             try it on just one layer
>                             (removing the links related to only that
>                             layer from the base_links
>                             table)
>                             You may also need to run the
>                             updatemaplayerip command.
>                             p
>                             On Tue, Mar 31, 2015 at 11:08 AM,
>                                 Hi guys
>                                 i need to migrate my geonode 2.4b22 to
>                                 another server (same os: ubuntu
>                                 14-04
>                                 and same geonode version)...
>                                 I tried doing it in this way:
>                                    - copy the geoserver data, styles
>                                 and workspace directory in the new
>                                 server
>                                    - domp via pg_dump and restore via
>                                 psql the geonode database
>                                 the result is that geonode recognize
>                                 all layers but it cannot view
>                                 them
>                                 because all links in the layer
>                                 metadata contains the old server
>                                 address...
>                                 haw can i solve it?
>                                 thanks in advance
>                                       Alessandro
>                                 _______________________________________________
>                                 geonode-users mailing list
>                                 geonode-users at lists.osgeo.org
>                                 <mailto:geonode-users at lists.osgeo.org>
>                                 http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
>                     Paolo Corti
>                     Geospatial software developer
>                     web: http://www.paolocorti.net
>                     twitter: @capooti
>                     skype: capooti
>                 Simone
>             Paolo Corti
>             twitter: @capooti
>             skype: capooti
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150407/598e4bca/attachment.html>
More information about the geonode-users
