[GeoNode-users] migrate geonode 2.4 to another server
Simone Dalmasso
simone.dalmasso at gmail.com
Tue Apr 7 05:43:54 PDT 2015
Thanks Alessandro, we need to add such feature to the geonode-updateip
command.
2015-04-07 14:25 GMT+02:00 Alessandro Burastero <alessandro at acrotec.it>:
> Thanks Simone... now i can install the b24 release
> ...but i confirm that the command geonode-updateid doesn't update the
> base_link table... here is the steps made to migrate the datas
> - install geonode
> - run geonode createsuperuser
> - run geonode-updateip
> - copy (and replace) from old server:
> - /usr/share/geoserver/data/data/geonode
> - /usr/share/geoserver/data/workspaces
> - /usr/share/geoserver/data/styles
> - /var/www/geonode/uploaded/thumbs
> - backup the old geonode store db and restore it in the new server
> - modify the connection settings in the geoserver datastore (change the
> password)
> now i have all the layers defined correctly in the geoserver and also in
> geonode... but all the links (also the WMS) pointing to the old geoserver,
> even if i run a geonode-updateip.
> the only way to se the link to the new geoserver is to manually update the
> base_link table as Paolo sudjest (update base_link set url = replace(url,
> 'old_ip', 'new_ip') ).
> Alessandro
> On 07/04/15 11:33, Simone Dalmasso wrote:
> Alessandro I just released the b24 which fixes the error. I apologize for
> it :)
> 2015-04-07 10:34 GMT+02:00 Alessandro Burastero <alessandro at acrotec.it>:
>> mmm i tried the geonode-updateip but i didn't worked... maybe i made
>> something wrong...
>> ...now i'm testing again the procedure, but i can't install the new
>> geonode beta 23 in a new ubuntu 14-04 intallation... the following error
>> appear during the geonode postinstall step:
>> Running GeoNode postinstall ...
>> Traceback (most recent call last):
>> File "<string>", line 1, in <module>
>> ImportError: No module named geonode
>> File "/usr/bin/django-admin", line 5, in <module>
>> management.execute_from_command_line()
>> File
>> "/usr/lib/python2.7/dist-packages/django/core/management/__init__.py", line
>> 399, in execute_from_command_line
>> utility.execute()
>> File
>> 392, in execute
>> self.fetch_command(subcommand).run_from_argv(self.argv)
>> File
>> 261, in fetch_command
>> commands = get_commands()
>> File
>> 107, in get_commands
>> apps = settings.INSTALLED_APPS
>> File "/usr/lib/python2.7/dist-packages/django/conf/__init__.py", line
>> 54, in __getattr__
>> self._setup(name)
>> 49, in _setup
>> self._wrapped = Settings(settings_module)
>> 132, in __init__
>> % (self.SETTINGS_MODULE, e)
>> ImportError: Could not import settings 'geonode.settings' (Is it on
>> sys.path? Is there an import error in the settings file?): No module named
>> geonode.settings
>> File
>> utility.execute()
>> File
>> 392, in execute
>> File
>> File
>> 54, in __getattr__
>> self._setup(name)
>> 49, in _setup
>> 132, in __init__
>> geonode.settings
>> ...while the update from the beta22 goes well
>> thanks again
>> Alessandro
>> On 07/04/15 10:11, Paolo Corti wrote:
>>> Uh forget my comment about documentation, I have just realized that
>>> geonode-updateip is a bash script and not a django command.
>>> cheers
>>> p
>>> On Tue, Apr 7, 2015 at 10:04 AM, Paolo Corti <pcorti at gmail.com> wrote:
>>>> Definitely that is the best way, totally forgot about that command :)
>>>> we need to add it to the documentation
>>>> http://docs.geonode.org/en/master/tutorials/admin/commands.html#commands
>>>> by the way
>>>> cheers
>>>> p
>>>> On Fri, Apr 3, 2015 at 5:38 PM, Simone Dalmasso
>>>> <simone.dalmasso at gmail.com> wrote:
>>>>> Shouldn't the geonode-updateip command do this?
>>>>> 2015-03-31 13:54 GMT+02:00 Paolo Corti <pcorti at gmail.com>:
>>>>>> It looks to me to be a bug, could you file a ticket?
>>>>>> Thanks
>>>>>> Meanwhile what you can do is to manually update the base_links table
>>>>>> with something like (not tested):
>>>>>> update base_link
>>>>>> set url = replace(url, 'old_ip', 'new_ip')
>>>>>> p
>>>>>> On Tue, Mar 31, 2015 at 1:16 PM, Alessandro Burastero
>>>>>> <alessandro at acrotec.it> wrote:
>>>>>>> i've truncated the base_link table and then i've run the geonode
>>>>>>> updatelayers command (and also updatelayerid)... but the base_link
>>>>>>> table
>>>>>>> remains empty
>>>>>>> Alessandro
>>>>>>> On 31/03/15 11:39, Paolo Corti wrote:
>>>>>>>> I have no way to test this right now but I believe that truncating
>>>>>>>> the
>>>>>>>> base_links table and running the updatelayers command should fix
>>>>>>>> this.
>>>>>>>> Before doing this action do a backup and try it on just one layer
>>>>>>>> (removing the links related to only that layer from the base_links
>>>>>>>> table)
>>>>>>>> You may also need to run the updatemaplayerip command.
>>>>>>>> p
>>>>>>>> On Tue, Mar 31, 2015 at 11:08 AM, Alessandro Burastero
>>>>>>>>> Hi guys
>>>>>>>>> i need to migrate my geonode 2.4b22 to another server (same os:
>>>>>>>>> ubuntu
>>>>>>>>> 14-04
>>>>>>>>> and same geonode version)...
>>>>>>>>> I tried doing it in this way:
>>>>>>>>> - copy the geoserver data, styles and workspace directory in
>>>>>>>>> the new
>>>>>>>>> server
>>>>>>>>> - domp via pg_dump and restore via psql the geonode database
>>>>>>>>> the result is that geonode recognize all layers but it cannot view
>>>>>>>>> them
>>>>>>>>> because all links in the layer metadata contains the old server
>>>>>>>>> address...
>>>>>>>>> haw can i solve it?
>>>>>>>>> thanks in advance
>>>>>>>>> Alessandro
>>>>>>>>> _______________________________________________
>>>>>>>>> geonode-users mailing list
>>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
>>>>>> Paolo Corti
>>>>>> Geospatial software developer
>>>>>> web: http://www.paolocorti.net
>>>>>> twitter: @capooti
>>>>>> skype: capooti
>>>>> Simone
>>>> Paolo Corti
>>>> twitter: @capooti
>>>> skype: capooti
> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150407/1bcb867b/attachment-0001.html>
More information about the geonode-users
