[GeoNode-users] Geonode, pair of questions
Simone Dalmasso simone.dalmasso at gmail.com
Fri Apr 10 01:52:00 PDT 2015
You can upgrade geonode and the fix eventual errors that may appear. For
three geoserver should be fine as long as the server can handle them :)
2015-04-10 10:46 GMT+02:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
> Hi Simone,
> to upgrade my geonode version do you suggest me to update this version or
> remove everything and start again from scratch?
> Regarding the multi - instances solution, I already have two different
> geoserver running on two tomcat containers, one is the geoserver
> related to my institution and it's actually the main wms wfs repo of my
> two projects, the other is the 'special' geoserver offered by geonode,
> used mainly for the upload of new spatial data. I understand that in this
> solution I need to install in the same machine 3 geoserver instance,
> I wonder if that is a good solution.
> best
> Eugenio
> From: simone.dalmasso at gmail.com
> Date: Fri, 10 Apr 2015 10:05:32 +0200
> Subject: Re: [GeoNode-users] Geonode, pair of questions
> To: frippe12573 at hotmail.com
> CC: geonode-users at lists.osgeo.org
> Hi Eugenio, good to hear that you are back to geonode.
> Here my answers.
> 1) yes we kept developing in these months
> 2) Yes you should definitely upgrade geonode, there have been many
> improvements and also some small data model changes so you might have to
> rebuild your db or part of it.
> 3) although there are plans to fully support such feature, it is not fully
> implemented yet so you have to go for two geonodes (for geoserver is
> suggested to have two different tomcats on different ports with a geoserver
> each)
> 4) I'm not very confident with geonetwork but yes, it is supported and you
> can give a try on using it.
> Hope this helps.
> Ciao
> 2015-04-10 9:49 GMT+02:00 Eugenio Trumpy <frippe12573 at hotmail.com>:
> Dear list,
> this is my first time I use this list, I had some messages exchange in the
> previous google group.
> In the past I tested geonode installing on my own an instance on my ubuntu
> server 12.04 in the
> version *2.4.dev20140922100009.* For this I have to say thank you to
> Simone Dalmasso who
> drove me in the installation. I performed a custom installation,
> following  this guide:
> http://docs.geonode.org/en/master/tutorials/admin/install/custom_install.html#custom-install
> at this URL my instance is still running but actually it has been
> abandoned since last year more or less:
> http://repoigg.services.iit.cnr.it
> Currently I need to go further using geonode, however, due to a long time
> without using it, I'm requiring you
> some hints and tips.
> My questions are:
>    - is there a new dev version?
>    - do you think would be convenient to upgrade to a new dev version?
>    Are there important code improvements?
>    - I have two different projects: do you suggest me to prepare two
>    geonode installations (one for each project) or can I set up only one
>    instance and configure it to serve the two project? Can I set up two
>    different website (interfaces)?
>    - My data (for both project) are already metadated in a geonetwork
>    catalogue, I know I can use geonetwork as metadata catalogue as well as set
>    up my catalogue as external catalogue. What do you suggest?
> Thank you for now,
> best
> Eugenio
> geonode-users mailing list
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150410/e37091e4/attachment-0001.html>
More information about the geonode-users mailing list
