[GeoNode-users] Fwd: Implement the search for GeoNode for title fields, abstract and keywords
Simone Dalmasso
simone.dalmasso at gmail.com
Mon Apr 13 23:58:55 PDT 2015
For the header search is easier since we use autocomplete for it, see this
https://github.com/GeoNode/geonode/blob/master/geonode/base/autocomplete_light_registry.py#L11
in the left bar of the search engine you could use autocomplete as well for
text inputs. If otherwise you need a prepopulated manu as the regions and
categories are then you have to do what Paolo suggested and write a custom
api and the template and js to support it. See here the apis
https://github.com/GeoNode/geonode/blob/master/geonode/api/api.py#L59
2015-04-13 19:50 GMT+02:00 Davi Custodio <davicustodio at gmail.com>:
> ---------- Forwarded message ----------
> From: Davi Custodio <davicustodio at gmail.com>
> Date: Mon, Apr 13, 2015 at 1:58 PM
> Subject: Re: [GeoNode-users] Implement the search for GeoNode for title
> To: Paolo Corti <pcorti at gmail.com>
> Paolo, I'm starting to learn Django, so I still have difficulty
> identifying some things. In my case, I would have the whole text search
> (both on the top bar of the layers, as in the sidebar) was applied in the
> title, abstract and keywords. I understand that in the case of key words I
> have to implement a for iterating the words to apply the search. But do not
> know where exactly (where classes) I should do it.
> Thank you.
> On Mon, Apr 13, 2015 at 10:55 AM, Paolo Corti <pcorti at gmail.com> wrote:
>> Another approach is to keep javascript as it is, and to override the
>> GeoNode API in your Django project.
>> I have to implement something like you are doing, but for tags
>> associated to models not inheriting from ResourceBase.
>> Therefore, in my urls.py:
>> api.unregister(geonode_api.TagResource())
>> api.register(TagResourceSimple())
>> where TagResourceSimple is my custom implementation of the Tag API.
>> Hope it helps
>> p
>> On Mon, Apr 13, 2015 at 3:17 PM, Simone Dalmasso
>> <simone.dalmasso at gmail.com> wrote:
>> > Davi, you you want to change the left filter bar behavior then this is
>> the
>> > place
>> https://github.com/GeoNode/geonode/blob/master/geonode/static/geonode/js/search/search.js
>> > and this folder for the templates as you are seeing
>> > https://github.com/GeoNode/geonode/tree/master/geonode/templates/search
>> > Don't hesitate to ask!
>> > 2015-04-13 15:08 GMT+02:00 Davi Custodio <davicustodio at gmail.com>:
>> >> Hello. I'm trying to customize the GeoNode 2.4 and in other changes, i
>> >> need to implement the main search find (besides the title field) in
>> abstrace
>> >> and and keywords fields. I was browsing through all project
>> directories, and
>> >> could not figure out exactly where I could change this search. I
>> realized
>> >> that in
>> >> folder are templates responsible for firing searches using Angular JS,
>> but I
>> >> could not understand exactly how the whole process works, and this
>> would be
>> >> the right spot to implement the change.
>> >> Can anyone help?
>> >> Thanks.
>> >> Davi de O. Custódio
>> >> _______________________________________________
>> >> geonode-users mailing list
>> >> geonode-users at lists.osgeo.org
>> >> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
>> > Simone
>> Paolo Corti
>> Geospatial software developer
>> web: http://www.paolocorti.net
>> twitter: @capooti
>> skype: capooti
> Davi de O. Custódio
> Davi de O. Custódio
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150414/e0b39cd2/attachment.html>
More information about the geonode-users
