[GeoNode-users] Trouble uploading .sld files to GeoNode
Simone Dalmasso
simone.dalmasso at gmail.com
Tue Aug 18 09:26:49 PDT 2015
Hi, right click on one pink tile and open it in another window, geoserver
should give you a file with the error. In alternative you can take a look
at the geoserver logs from the geoserver page.
2015-08-18 16:14 GMT+02:00 Tukang Sampah <tkgsmph at gmail.com>:
> Dear all,
> I'm trying to upload an .sld file enclosed within a zipped shapefile. The
> style displays correctly on the layer detail page for this sample (
> https://drive.google.com/open?id=0B6wX8X80IDvoVUctWUdSODg3NGs). It's just
> a basic .sld that I copied from /geoserver/rest/styles.
> However if I use another .sld file (
> https://drive.google.com/file/d/0B6wX8X80IDvoS3otaVVLX1I5Z1E/view?usp=sharing)
> which has <sld:TextSymbolizer> defined, the shapefile upload completes but
> does not display correctly on the layer detail page (pink tiles, no
> thumbnail on the layer list page). Furthermore after that if I try to
> upload any other shapefile (with or without the .sld) it seems the previous
> error constantly happens. The only way to fix the upload process is to
> restart the tomcat7 service, so maybe geoserver crashed? I'm using the
> latest GeoNode from master branch on github with Oracle JRE installed.
> What is the proper way to generate .sld files that are compatible GeoNode?
> Does anyone have a sample zipped shapefile with a complex .sld that I can
> try?
> Thanks,
> Tukang
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150818/788d6777/attachment.html>
More information about the geonode-users
