[GeoNode-users] can't upload vector layers, but rasters okay
Simone Dalmasso
simone.dalmasso at gmail.com
Thu Aug 20 07:25:59 PDT 2015
Hi Charles, did you change the geoserver admin login here?
https://github.com/GeoNode/geonode/blob/master/geonode/settings.py#L498, if
yes make sure you also updated them in geoserver, you can use the geoserver
web interface.
2015-08-20 16:09 GMT+02:00 Charles Cossé <ccosse at gmail.com>:
> Hello GeoNode Team,
> Recently my geonode instance has developed a problem whereby I can
> upload/view raster layers but not vector layers. Here are select lines
> from catalina.out when the upload of a vector layer fails:
> -----------8<---------
> 20 Aug 06:34:58 ERROR [geoserver.rest] - No such datastore:
> geonode,mainrivers_1
> 20 Aug 06:34:58 ERROR [geoserver.rest] - No such wms store:
> Caused by: java.lang.RuntimeException: Unable to obtain connection: Cannot
> create PoolableConnectionFactory (FATAL: password authentication failed for
> user "geonode")
> I have triple-checked the geonode password everywhere (local_settings.py,
> manage-shell, setting psql) and restarted services many times but the
> problem persists. I can login using dbshell with my geonode password, so I
> think that it's set correctly. If the problem really was the geonode db's
> password then I would expect raster layer operations to fail as well, but
> they work fine ... so I'm appealing for help before doing anything drastic.
> Thank you,
> Charles Cossé
> Protected Areas Commission &
> Geospatial Information Management Unit
> Georgetown, Guyana
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150820/8a1c7016/attachment.html>
More information about the geonode-users
