[GeoNode-users] new project from template
Simone Dalmasso
simone.dalmasso at gmail.com
Wed Dec 2 23:44:09 PST 2015
Hi, the instructions at https://github.com/GeoNode/geonode-project are
actually updated for the 2.4 with the latest apache config (there is the
"Require all granted" directive).
I tested this on a virtual machine copying exactly the same from the docs
and it works fine.
Can you take a look at the apache logs (tail -f
/var/logs/apache2/error.log) and see if there's a more detailed trace?
2015-12-03 6:26 GMT+01:00 <tom at maptec.org>:
> Hello list,
> I am attempting to create a new geonode project from template using the
> instructions from geonode_project (
> https://github.com/GeoNode/geonode-project). The goal is to get the html
> and css template files into Github so someone else can make the
> modifications.
> The instructions may not be updated for the 2.4 release, although I have
> figured out some of it. Like the local_settings.py.sample is no longer
> included.
> After updating the geonode.wsgi file and restarting apache I have a no
> permission issue accessing the webpage. Tried updating ip but no luck.
> I did come across an article (link below) about how the access control
> configuration has changed in Apache 2.4.7. Tried their solution but still
> no luck. Getting out of my knowledge area so not sure where the problem is.
> http://www.zyxware.com/articles/4550/solved-forbidden-you-dont-have-permission-to-access-on-this-server
> Tom
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20151203/4882b868/attachment.html>
More information about the geonode-users
