[GeoNode-users] Long attribute names in Map´s Query Table
Ariel Nunez ingenieroariel at gmail.com
Wed Dec 9 05:26:49 PST 2015
Sounds good Marcelo,
Please keep the geonode-users list in copy so others can also benefit from
the answers and your learning.
-a
On Wed, Dec 9, 2015 at 7:53 AM, Marcelo Villarroel <
raul.marcelo.villarroel.villazon at gmail.com> wrote:
> Hi Ariel,
> I will read about GXP and GeoExt. I´ve just find that GXP are high level
> components for GeoExt based apps.I don´t know about them.
> I´ll contact you later. Thanks for your support.
> Saludos,
> On Tue, Dec 8, 2015 at 10:34 PM, Ariel Nunez <ingenieroariel at gmail.com>
> wrote:
>> Marcelo,
>> I have heard the same request from other people (they wanted it for the
>> styler). It can be done modifying GXP but you may need to get your hands
>> dirty. It would involve making a request to GeoNode to learn the mappings
>> and then replacing those in the viewers.
>> If you decide to do it, I am sure we can support you here in the mailing
>> list if/when you get stuck.
>> Caminante no hay camino, se hace camino al andar.
>> -a
>> On Tue, Dec 8, 2015 at 6:30 PM, Marcelo Villarroel <
>>> Hi geonode-users/devs:
>>> As we know, when exporting a feature from geodatabase to shapefile, long
>>> size attribute names are truncated.
>>> Long attribute labels I defiined in GeoNode Administration / Layers /
>>> Attributes / Attribute Label are showing correctly in Identify´s Feature
>>> Info Table, but still showing truncated in Map's Query Table.
>>> Is it possible to view the Attribute names in Map´s Query Table the same
>>> way as written in   GeoNode Administration / Layers / Attributes /
>>> Attribute Label field?
>>> Thanks,
>>> *R. Marcelo Villarroel V.*
>>> Ing. Civil, MSc.
>>> *Sistemas de Información Geográfica*
>>> Cochabamba, Bolivia.
>>> Cel.:     (+591) - 722 12346
>>> Mail:     raul.marcelo.villarroel.villazon at gmail.com
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/geonode-users
> Ing. Civil, MSc.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20151209/ee1d2798/attachment-0001.html>
More information about the geonode-users mailing list
