[GeoNode-users] Long attribute names in Map´s Query Table
Marcelo Villarroel
raul.marcelo.villarroel.villazon at gmail.com
Wed Dec 9 10:41:13 PST 2015
Sorry, I forgot to reply to all.
Regards,
On Wed, Dec 9, 2015 at 9:26 AM, Ariel Nunez <ingenieroariel at gmail.com>
wrote:
> Sounds good Marcelo,
> Please keep the geonode-users list in copy so others can also benefit from
> the answers and your learning.
> -a
> On Wed, Dec 9, 2015 at 7:53 AM, Marcelo Villarroel <
> raul.marcelo.villarroel.villazon at gmail.com> wrote:
>> Hi Ariel,
>> I will read about GXP and GeoExt. I´ve just find that GXP are high level
>> components for GeoExt based apps.I don´t know about them.
>> I´ll contact you later. Thanks for your support.
>> Saludos,
>> On Tue, Dec 8, 2015 at 10:34 PM, Ariel Nunez <ingenieroariel at gmail.com>
>> wrote:
>>> Marcelo,
>>> I have heard the same request from other people (they wanted it for the
>>> styler). It can be done modifying GXP but you may need to get your hands
>>> dirty. It would involve making a request to GeoNode to learn the mappings
>>> and then replacing those in the viewers.
>>> If you decide to do it, I am sure we can support you here in the mailing
>>> list if/when you get stuck.
>>> Caminante no hay camino, se hace camino al andar.
>>> -a
>>> On Tue, Dec 8, 2015 at 6:30 PM, Marcelo Villarroel <
>>>> Hi geonode-users/devs:
>>>> As we know, when exporting a feature from geodatabase to shapefile,
>>>> long size attribute names are truncated.
>>>> Long attribute labels I defiined in GeoNode Administration / Layers /
>>>> Attributes / Attribute Label are showing correctly in Identify´s Feature
>>>> Info Table, but still showing truncated in Map's Query Table.
>>>> Is it possible to view the Attribute names in Map´s Query Table the
>>>> same way as written in GeoNode Administration / Layers / Attributes /
>>>> Attribute Label field?
>>>> Thanks,
>>>> *R. Marcelo Villarroel V.*
>>>> Ing. Civil, MSc.
>>>> *Sistemas de Información Geográfica*
>>>> Cochabamba, Bolivia.
>>>> Cel.: (+591) - 722 12346
>>>> Mail: raul.marcelo.villarroel.villazon at gmail.com
>>>> _______________________________________________
>>>> geonode-users mailing list
>>>> geonode-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/geonode-users
>> Ing. Civil, MSc.
Ing. Civil, MSc.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20151209/f2d8104c/attachment.html>
More information about the geonode-users
