[GeoNode-users] An exception occurred loading data to PostGIS- java.io.IOException: Error occurred creating table
Rajib Islam
rajiburp at gmail.com
Mon Dec 14 00:42:52 PST 2015
Dear Users,
I have installed GeoNode 2.4 stable version on Ubuntu 14.04 into a real
server. While uploading shape file it gives following error message:
*An exception occurred loading data to PostGIS- java.io.IOException: Error
occurred creating table*
*geonode at geonode:~$ tail -f /var/log/apache2/error.log*
[Mon Dec 14 00:03:52.366469 2015] [:error] [pid 13271]
update_fields=update_fields)
[Mon Dec 14 00:03:52.366476 2015] [:error] [pid 13271] File
"/usr/lib/python2.7/dist-packages/django/dispatch/dispatcher.py", line 185,
in send
[Mon Dec 14 00:03:52.366483 2015] [:error] [pid 13271] response =
receiver(signal=self, sender=sender, **named)
[Mon Dec 14 00:03:52.366490 2015] [:error] [pid 13271] File
"/usr/local/lib/python2.7/dist-packages/geonode/geoserver/signals.py", line
74, in geoserver_pre_save
[Mon Dec 14 00:03:52.366497 2015] [:error] [pid 13271]
charset=instance.charset)
[Mon Dec 14 00:03:52.366504 2015] [:error] [pid 13271] File
"/usr/local/lib/python2.7/dist-packages/geonode/geoserver/helpers.py", line
1121, in geoserver_upload
[Mon Dec 14 00:03:52.366512 2015] [:error] [pid 13271]
workspace=workspace)
[Mon Dec 14 00:03:52.366519 2015] [:error] [pid 13271] File
998, in _create_db_featurestore
[Mon Dec 14 00:03:52.366526 2015] [:error] [pid 13271] raise
GeoNodeException(msg)
[Mon Dec 14 00:03:52.366533 2015] [:error] [pid 13271] GeoNodeException: An
However, I can upload geotiff files and it works fine.
I am requesting your support in this regard to solve this shape file
uploading problem.
Best regards
Rajib
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20151214/f96a8c03/attachment.html>
More information about the geonode-users
