[GeoNode-users] An exception occurred loading data to PostGIS- java.io.IOException: Error occurred creating table
Rajib Islam
rajiburp at gmail.com
Mon Dec 14 01:49:31 PST 2015
I have solved this problem. Thank you.
On Mon, Dec 14, 2015 at 2:42 PM, Rajib Islam <rajiburp at gmail.com> wrote:
> Dear Users,
> I have installed GeoNode 2.4 stable version on Ubuntu 14.04 into a real
> server. While uploading shape file it gives following error message:
> *An exception occurred loading data to PostGIS- java.io.IOException: Error
> occurred creating table*
> *geonode at geonode:~$ tail -f /var/log/apache2/error.log*
> [Mon Dec 14 00:03:52.366469 2015] [:error] [pid 13271]
> update_fields=update_fields)
> [Mon Dec 14 00:03:52.366476 2015] [:error] [pid 13271] File
> "/usr/lib/python2.7/dist-packages/django/dispatch/dispatcher.py", line 185,
> in send
> [Mon Dec 14 00:03:52.366483 2015] [:error] [pid 13271] response =
> receiver(signal=self, sender=sender, **named)
> [Mon Dec 14 00:03:52.366490 2015] [:error] [pid 13271] File
> "/usr/local/lib/python2.7/dist-packages/geonode/geoserver/signals.py", line
> 74, in geoserver_pre_save
> [Mon Dec 14 00:03:52.366497 2015] [:error] [pid 13271]
> charset=instance.charset)
> [Mon Dec 14 00:03:52.366504 2015] [:error] [pid 13271] File
> "/usr/local/lib/python2.7/dist-packages/geonode/geoserver/helpers.py", line
> 1121, in geoserver_upload
> [Mon Dec 14 00:03:52.366512 2015] [:error] [pid 13271]
> workspace=workspace)
> [Mon Dec 14 00:03:52.366519 2015] [:error] [pid 13271] File
> 998, in _create_db_featurestore
> [Mon Dec 14 00:03:52.366526 2015] [:error] [pid 13271] raise
> GeoNodeException(msg)
> [Mon Dec 14 00:03:52.366533 2015] [:error] [pid 13271] GeoNodeException:
> However, I can upload geotiff files and it works fine.
> I am requesting your support in this regard to solve this shape file
> uploading problem.
> Best regards
> Rajib
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20151214/89f6bb23/attachment.html>
More information about the geonode-users
