[GeoNode-users] site_index.html not being included
Charles Cossé
ccosse at gmail.com
Tue Dec 22 03:49:37 PST 2015
Hi again, sorry for not being more clear. All files are present but our
site_index.html is not being served. Our modified front page worked well
with the last release candidate but with a fresh install of the new release
site_index.html is being ignored, which breaks our front page. It can be
verified with just a string added to each of site_base and site_index.html
and noting that only the string from site_base.html shows up on the front
page. This is the conclusion we came to yesterday after much testing and
checking. I will triple check just in case. Thank you,
-Charles
On Tue, Dec 22, 2015 at 4:32 AM, Francesco Bartoli <xbartolone at gmail.com>
wrote:
> Hi,
> The file is included in the version 2.4 of the repository:
> https://github.com/GeoNode/geonode-project/blob/master/project_name/templates/site_index.html
> Did you run a fresh git clone for your project?
> Francesco
>> On Dec 22 2015, at 12:28 am, Charles Cossé <ccosse at gmail.com> wrote:
>> Hi, yes i am using geonode-project and site_base is being included
>> correctly but site_index is not.
>> On Dec 21, 2015 4:53 PM, "Francesco Bartoli" <xbartolone at gmail.com>
>> wrote:
>> Hi Charles,
>> site_index is a template from the geonode-project [1] and doesn’t compare
>> in the geonode code base. Essentially you can use it as an extension of the
>> template index.html and customize geonode
>> Regards,
>> Francesco
>> [1] https://github.com/GeoNode/geonode-project/
>> Il giorno 21/dic/2015, alle ore 21:22, Charles Cossé <ccosse at gmail.com>
>> ha scritto:
>> Hi, using the new/recent 2.4 release I find that site_index.html is not
>> being included but site_base.html is. Does anyone else see this
>> happening? Thanks,
>> Charles
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20151222/b8b60898/attachment.html>
More information about the geonode-users
