[GeoNode-users] GeoNode Updateip Error (No module named relationships)
Jeffy John Tomarong jeffytoms at gmail.com
Wed Jul 1 00:43:13 PDT 2015
Hi Simone,
It did help! Thank you very much for your quick response.. I also did pip
install django-request after that.
However, when I issued updateip again, I got this:
/usr/lib/python2.7/dist-packages/django/conf/__init__.py:221:
DeprecationWarning: You have no filters defined on the 'mail_admins'
logging handler: adding implicit debug-false-only filter. See
http://docs.djangoproject.com/en/dev/releases/1.4/#request-exceptions-are-now-always-logged
  DeprecationWarning)
OperationalError: could not connect to server: Connection refused
Is the server running on host "localhost" (127.0.0.1) and accepting
TCP/IP connections on port 5432?
Hmm.. ??
On Wed, Jul 1, 2015 at 3:31 PM, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> Hi, I see you are using geonode 2.0
> the missing package should be django-relationships and since your geonode
> is installed systemwide you have to use sudo so:
> $ sudo pip install  django-relationships
> Hope this helps
> 2015-07-01 9:23 GMT+02:00 Jeffy John Tomarong <jeffytoms at gmail.com>:
>> Hi Good Fellas!
>> Our GeoNode instance was running well in the previous months. But now, it
>> got Internal Server Error 500.
>> What I did was to update the IP of geonode (which is just the same
>> anyway), and it caused me this error:I also tried "pip install
>> relationship" since it displayed there "Error: No Module named
>> relationships". But it caused another set of error. GeoNode has been
>> running well in the last months, I do not know what happened.
>> I need your help guys on this. I'm at the end of my wits.
>> Will be very much appreciated. Thank you!
>> Here's the error message:
>> Replacing SITEURL in /etc/geonode/local_settings.py
>> Adding entry for local ip in
>> /usr/share/geoserver/data//printing/config.yaml
>>   IP was already added to the printing whitelist.
>> Replacing ALLOWED_HOSTS in /etc/geonode/local_settings.py
>>  * Restarting web server apache2
>>        apache2: Could not reliably determine the server's fully qualified
>> domain name, using 127.0.1.1 for ServerName
>>  ... waiting .apache2: Could not reliably determine the server's fully
>> qualified domain name, using 127.0.1.1 for ServerName
>>  [ OK ]
>>   DeprecationWarning)
>> Traceback (most recent call last):
>>   File "/usr/bin/django-admin", line 5, in <module>
>>     management.execute_from_command_line()
>>   File
>> "/usr/lib/python2.7/dist-packages/django/core/management/__init__.py", line
>> 453, in execute_from_command_line
>>     utility.execute()
>>   File
>> 392, in execute
>>     self.fetch_command(subcommand).run_from_argv(self.argv)
>>   File
>> 272, in fetch_command
>>     klass = load_command_class(app_name, subcommand)
>>   File
>> 77, in load_command_class
>>     module = import_module('%s.management.commands.%s' % (app_name, name))
>>   File "/usr/lib/python2.7/dist-packages/django/utils/importlib.py", line
>> 35, in import_module
>>     __import__(name)
>>   File
>> "/usr/local/lib/python2.7/dist-packages/geonode/layers/management/commands/updatelayers.py",
>> line 23, in <module>
>>     from geonode.geoserver.helpers import gs_slurp
>>   File
>> "/usr/local/lib/python2.7/dist-packages/geonode/geoserver/helpers.py", line
>> 31, in <module>
>>     from geonode.utils import _user, _password, ogc_server_settings
>>   File "/usr/local/lib/python2.7/dist-packages/geonode/utils.py", line
>> 36, in <module>
>>     from geonode.security.enumerations import AUTHENTICATED_USERS,
>> ANONYMOUS_USERS, INVALID_PERMISSION_MESSAGE
>>   File
>> "/usr/local/lib/python2.7/dist-packages/geonode/security/enumerations.py",
>> line 28, in <module>
>>     ANONYMOUS_USERS: _('Anonymous Users'),
>>   File
>> "/usr/lib/python2.7/dist-packages/django/utils/translation/__init__.py",
>> line 71, in ugettext
>>     return _trans.ugettext(message)
>>   File
>> "/usr/lib/python2.7/dist-packages/django/utils/translation/trans_real.py",
>> line 276, in ugettext
>>     return do_translate(message, 'ugettext')
>>   File
>> line 258, in do_translate
>>     _default = translation(settings.LANGUAGE_CODE)
>>   File
>> line 172, in translation
>>     default_translation = _fetch(settings.LANGUAGE_CODE)
>>   File
>> line 154, in _fetch
>>     app = import_module(appname)
>>     __import__(name)
>> ImportError: No module named relationships
>> jjqt at GeoNode:/usr/local/lib/python2.7/dist-packages/geonode$ sudo pico
>> local_settings.py
>> settings.py
>> jjqt at GeoNode:/usr/local/lib/python2.7/dist-packages/geonode$ sudo pip
>> install -e.
>> [sudo] password for jjqt:
>> --editable=. should be formatted with svn+URL, git+URL, hg+URL or bzr+URL
>> Storing complete log in /home/jjqt/.pip/pip.log
>> geonode-updateipcrisp.norminet.org.ph
>>  [ OK ]
>>   DeprecationWarning)
>>   File
>>     utility.execute()
>>   File
>> 392, in execute
>>   File
>>   File
>>     __import__(name)
>>   File
>>   File
>> 31, in <module>
>> 36, in <module>
>>   File
>>   File
>>   File
>>   File
>>   File
>>   File
>> line 154, in _fetch
>>     __import__(name)
>> jjqt at GeoNode:/usr/local/lib/python2.7/dist-packages/geonode$ pip install
>> relationships
>> Downloading/unpacking relationships
>> Exception:
>>   File "/usr/lib/python2.7/dist-packages/pip/basecommand.py", line 126,
>> in main
>>     self.run(options, args)
>>   File "/usr/lib/python2.7/dist-packages/pip/commands/install.py", line
>> 223, in run
>>     requirement_set.prepare_files(finder,
>> force_root_egg_info=self.bundle, bundle=self.bundle)
>>   File "/usr/lib/python2.7/dist-packages/pip/req.py", line 942, in
>> prepare_files
>>     location = req_to_install.build_location(self.build_dir, not
>> self.is_download)
>>   File "/usr/lib/python2.7/dist-packages/pip/req.py", line 144, in
>> build_location
>>     _make_build_dir(build_dir)
>>   File "/usr/lib/python2.7/dist-packages/pip/req.py", line 1185, in
>> _make_build_dir
>>     os.makedirs(build_dir)
>>   File "/usr/lib/python2.7/os.py", line 157, in makedirs
>>     mkdir(name, mode)
>> OSError: [Errno 13] Permission denied:
>> '/usr/local/lib/python2.7/dist-packages/geonode/build'
>>   File "/usr/bin/pip", line 9, in <module>
>>     load_entry_point('pip==1.0', 'console_scripts', 'pip')()
>>   File "/usr/lib/python2.7/dist-packages/pip/__init__.py", line 116, in
>> main
>>     return command.main(initial_args, args[1:], options)
>>   File "/usr/lib/python2.7/dist-packages/pip/basecommand.py", line 147,
>> in main
>>     log_fp = open_logfile(log_fn, 'w')
>>   File "/usr/lib/python2.7/dist-packages/pip/basecommand.py", line 176,
>> in open_logfile
>>     log_fp = open(filename, mode)
>> IOError: [Errno 13] Permission denied: '/home/jjqt/.pip/pip.log'
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150701/c157e983/attachment-0001.html>
More information about the geonode-users mailing list
