[GeoNode-users] GeoNode Updateip Error (No module named relationships)
Simone Dalmasso simone.dalmasso at gmail.com
Wed Jul 1 00:54:33 PDT 2015
That is because it can't connect to postgresql. Do you have some kind of
custom configuration?
That command uses /etc/geonode/local_settings.py to get the db configuration
2015-07-01 9:43 GMT+02:00 Jeffy John Tomarong <jeffytoms at gmail.com>:
> Hi Simone,
> It did help! Thank you very much for your quick response.. I also did pip
> install django-request after that.
> However, when I issued updateip again, I got this:
> /usr/lib/python2.7/dist-packages/django/conf/__init__.py:221:
> DeprecationWarning: You have no filters defined on the 'mail_admins'
> logging handler: adding implicit debug-false-only filter. See
> http://docs.djangoproject.com/en/dev/releases/1.4/#request-exceptions-are-now-always-logged
>   DeprecationWarning)
> OperationalError: could not connect to server: Connection refused
> Is the server running on host "localhost" (127.0.0.1) and accepting
> TCP/IP connections on port 5432?
> Hmm.. ??
> On Wed, Jul 1, 2015 at 3:31 PM, Simone Dalmasso <simone.dalmasso at gmail.com
> > wrote:
>> Hi, I see you are using geonode 2.0
>> the missing package should be django-relationships and since your geonode
>> is installed systemwide you have to use sudo so:
>> $ sudo pip install  django-relationships
>> Hope this helps
>> 2015-07-01 9:23 GMT+02:00 Jeffy John Tomarong <jeffytoms at gmail.com>:
>>> Hi Good Fellas!
>>> Our GeoNode instance was running well in the previous months. But now,
>>> it got Internal Server Error 500.
>>> What I did was to update the IP of geonode (which is just the same
>>> anyway), and it caused me this error:I also tried "pip install
>>> relationship" since it displayed there "Error: No Module named
>>> relationships". But it caused another set of error. GeoNode has been
>>> running well in the last months, I do not know what happened.
>>> I need your help guys on this. I'm at the end of my wits.
>>> Will be very much appreciated. Thank you!
>>> Here's the error message:
>>> Replacing SITEURL in /etc/geonode/local_settings.py
>>> Adding entry for local ip in
>>> /usr/share/geoserver/data//printing/config.yaml
>>>   IP was already added to the printing whitelist.
>>> Replacing ALLOWED_HOSTS in /etc/geonode/local_settings.py
>>>  * Restarting web server apache2
>>>        apache2: Could not reliably determine the server's fully qualified
>>> domain name, using 127.0.1.1 for ServerName
>>>  ... waiting .apache2: Could not reliably determine the server's fully
>>> qualified domain name, using 127.0.1.1 for ServerName
>>>  [ OK ]
>>>   DeprecationWarning)
>>> Traceback (most recent call last):
>>>   File "/usr/bin/django-admin", line 5, in <module>
>>>     management.execute_from_command_line()
>>>   File
>>> "/usr/lib/python2.7/dist-packages/django/core/management/__init__.py", line
>>> 453, in execute_from_command_line
>>>     utility.execute()
>>>   File
>>> 392, in execute
>>>     self.fetch_command(subcommand).run_from_argv(self.argv)
>>>   File
>>> 272, in fetch_command
>>>     klass = load_command_class(app_name, subcommand)
>>>   File
>>> 77, in load_command_class
>>>     module = import_module('%s.management.commands.%s' % (app_name,
>>> name))
>>>   File "/usr/lib/python2.7/dist-packages/django/utils/importlib.py",
>>> line 35, in import_module
>>>     __import__(name)
>>>   File
>>> "/usr/local/lib/python2.7/dist-packages/geonode/layers/management/commands/updatelayers.py",
>>> line 23, in <module>
>>>     from geonode.geoserver.helpers import gs_slurp
>>>   File
>>> "/usr/local/lib/python2.7/dist-packages/geonode/geoserver/helpers.py", line
>>> 31, in <module>
>>>     from geonode.utils import _user, _password, ogc_server_settings
>>>   File "/usr/local/lib/python2.7/dist-packages/geonode/utils.py", line
>>> 36, in <module>
>>>     from geonode.security.enumerations import AUTHENTICATED_USERS,
>>> ANONYMOUS_USERS, INVALID_PERMISSION_MESSAGE
>>>   File
>>> "/usr/local/lib/python2.7/dist-packages/geonode/security/enumerations.py",
>>> line 28, in <module>
>>>     ANONYMOUS_USERS: _('Anonymous Users'),
>>>   File
>>> "/usr/lib/python2.7/dist-packages/django/utils/translation/__init__.py",
>>> line 71, in ugettext
>>>     return _trans.ugettext(message)
>>>   File
>>> "/usr/lib/python2.7/dist-packages/django/utils/translation/trans_real.py",
>>> line 276, in ugettext
>>>     return do_translate(message, 'ugettext')
>>>   File
>>> line 258, in do_translate
>>>     _default = translation(settings.LANGUAGE_CODE)
>>>   File
>>> line 172, in translation
>>>     default_translation = _fetch(settings.LANGUAGE_CODE)
>>>   File
>>> line 154, in _fetch
>>>     app = import_module(appname)
>>>     __import__(name)
>>> ImportError: No module named relationships
>>> jjqt at GeoNode:/usr/local/lib/python2.7/dist-packages/geonode$ sudo pico
>>> local_settings.py
>>> settings.py
>>> jjqt at GeoNode:/usr/local/lib/python2.7/dist-packages/geonode$ sudo pip
>>> install -e.
>>> [sudo] password for jjqt:
>>> --editable=. should be formatted with svn+URL, git+URL, hg+URL or bzr+URL
>>> Storing complete log in /home/jjqt/.pip/pip.log
>>> geonode-updateipcrisp.norminet.org.ph
>>>  [ OK ]
>>>   DeprecationWarning)
>>>   File
>>>     utility.execute()
>>>   File
>>> 392, in execute
>>>   File
>>>   File
>>> name))
>>>     __import__(name)
>>>   File
>>>   File
>>> 31, in <module>
>>> 36, in <module>
>>>   File
>>>   File
>>>   File
>>>   File
>>>   File
>>>   File
>>> line 154, in _fetch
>>>     __import__(name)
>>> jjqt at GeoNode:/usr/local/lib/python2.7/dist-packages/geonode$ pip
>>> install relationships
>>> Downloading/unpacking relationships
>>> Exception:
>>>   File "/usr/lib/python2.7/dist-packages/pip/basecommand.py", line 126,
>>> in main
>>>     self.run(options, args)
>>>   File "/usr/lib/python2.7/dist-packages/pip/commands/install.py", line
>>> 223, in run
>>>     requirement_set.prepare_files(finder,
>>> force_root_egg_info=self.bundle, bundle=self.bundle)
>>>   File "/usr/lib/python2.7/dist-packages/pip/req.py", line 942, in
>>> prepare_files
>>>     location = req_to_install.build_location(self.build_dir, not
>>> self.is_download)
>>>   File "/usr/lib/python2.7/dist-packages/pip/req.py", line 144, in
>>> build_location
>>>     _make_build_dir(build_dir)
>>>   File "/usr/lib/python2.7/dist-packages/pip/req.py", line 1185, in
>>> _make_build_dir
>>>     os.makedirs(build_dir)
>>>   File "/usr/lib/python2.7/os.py", line 157, in makedirs
>>>     mkdir(name, mode)
>>> OSError: [Errno 13] Permission denied:
>>> '/usr/local/lib/python2.7/dist-packages/geonode/build'
>>>   File "/usr/bin/pip", line 9, in <module>
>>>     load_entry_point('pip==1.0', 'console_scripts', 'pip')()
>>>   File "/usr/lib/python2.7/dist-packages/pip/__init__.py", line 116, in
>>> main
>>>     return command.main(initial_args, args[1:], options)
>>>   File "/usr/lib/python2.7/dist-packages/pip/basecommand.py", line 147,
>>> in main
>>>     log_fp = open_logfile(log_fn, 'w')
>>>   File "/usr/lib/python2.7/dist-packages/pip/basecommand.py", line 176,
>>> in open_logfile
>>>     log_fp = open(filename, mode)
>>> IOError: [Errno 13] Permission denied: '/home/jjqt/.pip/pip.log'
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
>> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150701/bedb65aa/attachment-0001.html>
More information about the geonode-users mailing list
