[GeoNode-users] GeoNode Updateip Error (No module named relationships)
Simone Dalmasso simone.dalmasso at gmail.com
Wed Jul 1 01:11:44 PDT 2015
There's no way to restore, but you can add back your db configuration.
Check whether the local_settings.py file contains the correct db connection
parameters and that postgres is up and running.
2015-07-01 10:08 GMT+02:00 Jeffy John Tomarong <jeffytoms at gmail.com>:
> Nope we dont have a custom configuration. After I installed geonode, all I
> editted were on the ipaddress part or the site url. I did not touch the DB
> config in the local_settings.py ..
> Or is there a way to restore back the local_settings.py, say restore it
> back to two days ago? Because I'm afraid I might have overwritten the
> local_settings.py with the old backup file of local_settings.py the moment
> it got the internal server error..
> Thank you Simone!
> On Wed, Jul 1, 2015 at 3:54 PM, Simone Dalmasso <simone.dalmasso at gmail.com
> > wrote:
>> That is because it can't connect to postgresql. Do you have some kind of
>> custom configuration?
>> That command uses /etc/geonode/local_settings.py to get the db
>> configuration
>> 2015-07-01 9:43 GMT+02:00 Jeffy John Tomarong <jeffytoms at gmail.com>:
>>> Hi Simone,
>>> It did help! Thank you very much for your quick response.. I also did
>>> pip install django-request after that.
>>> However, when I issued updateip again, I got this:
>>> /usr/lib/python2.7/dist-packages/django/conf/__init__.py:221:
>>> DeprecationWarning: You have no filters defined on the 'mail_admins'
>>> logging handler: adding implicit debug-false-only filter. See
>>> http://docs.djangoproject.com/en/dev/releases/1.4/#request-exceptions-are-now-always-logged
>>>   DeprecationWarning)
>>> OperationalError: could not connect to server: Connection refused
>>> Is the server running on host "localhost" (127.0.0.1) and accepting
>>> TCP/IP connections on port 5432?
>>> Hmm.. ??
>>> On Wed, Jul 1, 2015 at 3:31 PM, Simone Dalmasso <
>>> simone.dalmasso at gmail.com> wrote:
>>>> Hi, I see you are using geonode 2.0
>>>> the missing package should be django-relationships and since your
>>>> geonode is installed systemwide you have to use sudo so:
>>>> $ sudo pip install  django-relationships
>>>> Hope this helps
>>>> 2015-07-01 9:23 GMT+02:00 Jeffy John Tomarong <jeffytoms at gmail.com>:
>>>>> Hi Good Fellas!
>>>>> Our GeoNode instance was running well in the previous months. But now,
>>>>> it got Internal Server Error 500.
>>>>> What I did was to update the IP of geonode (which is just the same
>>>>> anyway), and it caused me this error:I also tried "pip install
>>>>> relationship" since it displayed there "Error: No Module named
>>>>> relationships". But it caused another set of error. GeoNode has been
>>>>> running well in the last months, I do not know what happened.
>>>>> I need your help guys on this. I'm at the end of my wits.
>>>>> Will be very much appreciated. Thank you!
>>>>> Here's the error message:
>>>>> Replacing SITEURL in /etc/geonode/local_settings.py
>>>>> Adding entry for local ip in
>>>>> /usr/share/geoserver/data//printing/config.yaml
>>>>>   IP was already added to the printing whitelist.
>>>>> Replacing ALLOWED_HOSTS in /etc/geonode/local_settings.py
>>>>>  * Restarting web server apache2
>>>>>          apache2: Could not reliably determine the server's fully qualified
>>>>> domain name, using 127.0.1.1 for ServerName
>>>>>  ... waiting .apache2: Could not reliably determine the server's fully
>>>>> qualified domain name, using 127.0.1.1 for ServerName
>>>>>    [ OK ]
>>>>>   DeprecationWarning)
>>>>> Traceback (most recent call last):
>>>>>   File "/usr/bin/django-admin", line 5, in <module>
>>>>>     management.execute_from_command_line()
>>>>>   File
>>>>> "/usr/lib/python2.7/dist-packages/django/core/management/__init__.py", line
>>>>> 453, in execute_from_command_line
>>>>>     utility.execute()
>>>>>   File
>>>>> 392, in execute
>>>>>     self.fetch_command(subcommand).run_from_argv(self.argv)
>>>>>   File
>>>>> 272, in fetch_command
>>>>>     klass = load_command_class(app_name, subcommand)
>>>>>   File
>>>>> 77, in load_command_class
>>>>>     module = import_module('%s.management.commands.%s' % (app_name,
>>>>> name))
>>>>>   File "/usr/lib/python2.7/dist-packages/django/utils/importlib.py",
>>>>> line 35, in import_module
>>>>>     __import__(name)
>>>>>   File
>>>>> "/usr/local/lib/python2.7/dist-packages/geonode/layers/management/commands/updatelayers.py",
>>>>> line 23, in <module>
>>>>>     from geonode.geoserver.helpers import gs_slurp
>>>>>   File
>>>>> "/usr/local/lib/python2.7/dist-packages/geonode/geoserver/helpers.py", line
>>>>> 31, in <module>
>>>>>     from geonode.utils import _user, _password, ogc_server_settings
>>>>>   File "/usr/local/lib/python2.7/dist-packages/geonode/utils.py", line
>>>>> 36, in <module>
>>>>>     from geonode.security.enumerations import AUTHENTICATED_USERS,
>>>>> ANONYMOUS_USERS, INVALID_PERMISSION_MESSAGE
>>>>>   File
>>>>> "/usr/local/lib/python2.7/dist-packages/geonode/security/enumerations.py",
>>>>> line 28, in <module>
>>>>>     ANONYMOUS_USERS: _('Anonymous Users'),
>>>>>   File
>>>>> "/usr/lib/python2.7/dist-packages/django/utils/translation/__init__.py",
>>>>> line 71, in ugettext
>>>>>     return _trans.ugettext(message)
>>>>>   File
>>>>> "/usr/lib/python2.7/dist-packages/django/utils/translation/trans_real.py",
>>>>> line 276, in ugettext
>>>>>     return do_translate(message, 'ugettext')
>>>>>   File
>>>>> line 258, in do_translate
>>>>>     _default = translation(settings.LANGUAGE_CODE)
>>>>>   File
>>>>> line 172, in translation
>>>>>     default_translation = _fetch(settings.LANGUAGE_CODE)
>>>>>   File
>>>>> line 154, in _fetch
>>>>>     app = import_module(appname)
>>>>>     __import__(name)
>>>>> ImportError: No module named relationships
>>>>> jjqt at GeoNode:/usr/local/lib/python2.7/dist-packages/geonode$ sudo
>>>>> pico local_settings.py
>>>>> pico settings.py
>>>>> jjqt at GeoNode:/usr/local/lib/python2.7/dist-packages/geonode$ sudo pip
>>>>> install -e.
>>>>> [sudo] password for jjqt:
>>>>> --editable=. should be formatted with svn+URL, git+URL, hg+URL or
>>>>> bzr+URL
>>>>> Storing complete log in /home/jjqt/.pip/pip.log
>>>>> geonode-updateipcrisp.norminet.org.ph
>>>>>    [ OK ]
>>>>>   DeprecationWarning)
>>>>>   File
>>>>>     utility.execute()
>>>>>   File
>>>>> 392, in execute
>>>>>   File
>>>>>   File
>>>>> name))
>>>>>     __import__(name)
>>>>>   File
>>>>>   File
>>>>> 31, in <module>
>>>>> 36, in <module>
>>>>>   File
>>>>>   File
>>>>>   File
>>>>>   File
>>>>>   File
>>>>>   File
>>>>> line 154, in _fetch
>>>>>     __import__(name)
>>>>> jjqt at GeoNode:/usr/local/lib/python2.7/dist-packages/geonode$ pip
>>>>> install relationships
>>>>> Downloading/unpacking relationships
>>>>> Exception:
>>>>>   File "/usr/lib/python2.7/dist-packages/pip/basecommand.py", line
>>>>> 126, in main
>>>>>     self.run(options, args)
>>>>>   File "/usr/lib/python2.7/dist-packages/pip/commands/install.py",
>>>>> line 223, in run
>>>>>     requirement_set.prepare_files(finder,
>>>>> force_root_egg_info=self.bundle, bundle=self.bundle)
>>>>>   File "/usr/lib/python2.7/dist-packages/pip/req.py", line 942, in
>>>>> prepare_files
>>>>>     location = req_to_install.build_location(self.build_dir, not
>>>>> self.is_download)
>>>>>   File "/usr/lib/python2.7/dist-packages/pip/req.py", line 144, in
>>>>> build_location
>>>>>     _make_build_dir(build_dir)
>>>>>   File "/usr/lib/python2.7/dist-packages/pip/req.py", line 1185, in
>>>>> _make_build_dir
>>>>>     os.makedirs(build_dir)
>>>>>   File "/usr/lib/python2.7/os.py", line 157, in makedirs
>>>>>     mkdir(name, mode)
>>>>> OSError: [Errno 13] Permission denied:
>>>>> '/usr/local/lib/python2.7/dist-packages/geonode/build'
>>>>>   File "/usr/bin/pip", line 9, in <module>
>>>>>     load_entry_point('pip==1.0', 'console_scripts', 'pip')()
>>>>>   File "/usr/lib/python2.7/dist-packages/pip/__init__.py", line 116,
>>>>> in main
>>>>>     return command.main(initial_args, args[1:], options)
>>>>> 147, in main
>>>>>     log_fp = open_logfile(log_fn, 'w')
>>>>> 176, in open_logfile
>>>>>     log_fp = open(filename, mode)
>>>>> IOError: [Errno 13] Permission denied: '/home/jjqt/.pip/pip.log'
>>>>> _______________________________________________
>>>>> geonode-users mailing list
>>>>> geonode-users at lists.osgeo.org
>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
>>>> Simone
>> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150701/42effceb/attachment-0001.html>
More information about the geonode-users mailing list
