[GeoNode-users] GeoNode Updateip Error (No module named relationships)
Jeffy John Tomarong
jeffytoms at gmail.com
Wed Jul 1 01:52:15 PDT 2015
Hi Simone,
I got this error when I restarted postgresql and it's quite persistent:
Restarting PostgreSQL 9.1 database server
* The PostgreSQL server failed to start. Please check the log output:
2015-07-01 16:49:11 PHT LOG: database system was interrupted; last known
up at 2015-05-27 23:25:59 PHT
2015-07-01 16:49:11 PHT FATAL: could not open file
"/etc/ssl/certs/ssl-cert-snakeoil.pem": Permission denied
2015-07-01 16:49:11 PHT LOG: startup process (PID 5730) exited with exit
code 1
2015-07-01 16:49:11 PHT LOG: aborting startup due to startup process
failure
[fail]
On Wed, Jul 1, 2015 at 4:11 PM, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> There's no way to restore, but you can add back your db configuration.
> Check whether the local_settings.py file contains the correct db connection
> parameters and that postgres is up and running.
> 2015-07-01 10:08 GMT+02:00 Jeffy John Tomarong <jeffytoms at gmail.com>:
>> Nope we dont have a custom configuration. After I installed geonode, all
>> I editted were on the ipaddress part or the site url. I did not touch the
>> DB config in the local_settings.py ..
>> Or is there a way to restore back the local_settings.py, say restore it
>> back to two days ago? Because I'm afraid I might have overwritten the
>> local_settings.py with the old backup file of local_settings.py the moment
>> it got the internal server error..
>> Thank you Simone!
>> On Wed, Jul 1, 2015 at 3:54 PM, Simone Dalmasso <
>> simone.dalmasso at gmail.com> wrote:
>>> That is because it can't connect to postgresql. Do you have some kind of
>>> custom configuration?
>>> That command uses /etc/geonode/local_settings.py to get the db
>>> configuration
>>> 2015-07-01 9:43 GMT+02:00 Jeffy John Tomarong <jeffytoms at gmail.com>:
>>>> Hi Simone,
>>>> It did help! Thank you very much for your quick response.. I also did
>>>> pip install django-request after that.
>>>> However, when I issued updateip again, I got this:
>>>> /usr/lib/python2.7/dist-packages/django/conf/__init__.py:221:
>>>> DeprecationWarning: You have no filters defined on the 'mail_admins'
>>>> logging handler: adding implicit debug-false-only filter. See
>>>> http://docs.djangoproject.com/en/dev/releases/1.4/#request-exceptions-are-now-always-logged
>>>> DeprecationWarning)
>>>> OperationalError: could not connect to server: Connection refused
>>>> Is the server running on host "localhost" (127.0.0.1) and accepting
>>>> TCP/IP connections on port 5432?
>>>> Hmm.. ??
>>>> On Wed, Jul 1, 2015 at 3:31 PM, Simone Dalmasso <
>>>>> Hi, I see you are using geonode 2.0
>>>>> the missing package should be django-relationships and since your
>>>>> geonode is installed systemwide you have to use sudo so:
>>>>> $ sudo pip install django-relationships
>>>>> Hope this helps
>>>>> 2015-07-01 9:23 GMT+02:00 Jeffy John Tomarong <jeffytoms at gmail.com>:
>>>>>> Hi Good Fellas!
>>>>>> Our GeoNode instance was running well in the previous months. But
>>>>>> now, it got Internal Server Error 500.
>>>>>> What I did was to update the IP of geonode (which is just the same
>>>>>> anyway), and it caused me this error:I also tried "pip install
>>>>>> relationship" since it displayed there "Error: No Module named
>>>>>> relationships". But it caused another set of error. GeoNode has been
>>>>>> running well in the last months, I do not know what happened.
>>>>>> I need your help guys on this. I'm at the end of my wits.
>>>>>> Will be very much appreciated. Thank you!
>>>>>> Here's the error message:
>>>>>> Replacing SITEURL in /etc/geonode/local_settings.py
>>>>>> Adding entry for local ip in
>>>>>> /usr/share/geoserver/data//printing/config.yaml
>>>>>> IP was already added to the printing whitelist.
>>>>>> Replacing ALLOWED_HOSTS in /etc/geonode/local_settings.py
>>>>>> * Restarting web server apache2
>>>>>> apache2: Could not reliably determine the server's fully
>>>>>> qualified domain name, using 127.0.1.1 for ServerName
>>>>>> ... waiting .apache2: Could not reliably determine the server's
>>>>>> fully qualified domain name, using 127.0.1.1 for ServerName
>>>>>> [ OK ]
>>>>>> DeprecationWarning)
>>>>>> Traceback (most recent call last):
>>>>>> File "/usr/bin/django-admin", line 5, in <module>
>>>>>> management.execute_from_command_line()
>>>>>> File
>>>>>> "/usr/lib/python2.7/dist-packages/django/core/management/__init__.py", line
>>>>>> 453, in execute_from_command_line
>>>>>> utility.execute()
>>>>>> File
>>>>>> 392, in execute
>>>>>> self.fetch_command(subcommand).run_from_argv(self.argv)
>>>>>> File
>>>>>> 272, in fetch_command
>>>>>> klass = load_command_class(app_name, subcommand)
>>>>>> File
>>>>>> 77, in load_command_class
>>>>>> module = import_module('%s.management.commands.%s' % (app_name,
>>>>>> name))
>>>>>> File "/usr/lib/python2.7/dist-packages/django/utils/importlib.py",
>>>>>> line 35, in import_module
>>>>>> __import__(name)
>>>>>> File
>>>>>> "/usr/local/lib/python2.7/dist-packages/geonode/layers/management/commands/updatelayers.py",
>>>>>> line 23, in <module>
>>>>>> from geonode.geoserver.helpers import gs_slurp
>>>>>> File
>>>>>> "/usr/local/lib/python2.7/dist-packages/geonode/geoserver/helpers.py", line
>>>>>> 31, in <module>
>>>>>> from geonode.utils import _user, _password, ogc_server_settings
>>>>>> File "/usr/local/lib/python2.7/dist-packages/geonode/utils.py",
>>>>>> line 36, in <module>
>>>>>> from geonode.security.enumerations import AUTHENTICATED_USERS,
>>>>>> ANONYMOUS_USERS, INVALID_PERMISSION_MESSAGE
>>>>>> File
>>>>>> "/usr/local/lib/python2.7/dist-packages/geonode/security/enumerations.py",
>>>>>> line 28, in <module>
>>>>>> ANONYMOUS_USERS: _('Anonymous Users'),
>>>>>> File
>>>>>> "/usr/lib/python2.7/dist-packages/django/utils/translation/__init__.py",
>>>>>> line 71, in ugettext
>>>>>> return _trans.ugettext(message)
>>>>>> File
>>>>>> "/usr/lib/python2.7/dist-packages/django/utils/translation/trans_real.py",
>>>>>> line 276, in ugettext
>>>>>> return do_translate(message, 'ugettext')
>>>>>> File
>>>>>> line 258, in do_translate
>>>>>> _default = translation(settings.LANGUAGE_CODE)
>>>>>> File
>>>>>> line 172, in translation
>>>>>> default_translation = _fetch(settings.LANGUAGE_CODE)
>>>>>> File
>>>>>> line 154, in _fetch
>>>>>> app = import_module(appname)
>>>>>> __import__(name)
>>>>>> ImportError: No module named relationships
>>>>>> jjqt at GeoNode:/usr/local/lib/python2.7/dist-packages/geonode$ sudo
>>>>>> pico local_settings.py
>>>>>> pico settings.py
>>>>>> pip install -e.
>>>>>> [sudo] password for jjqt:
>>>>>> --editable=. should be formatted with svn+URL, git+URL, hg+URL or
>>>>>> bzr+URL
>>>>>> Storing complete log in /home/jjqt/.pip/pip.log
>>>>>> geonode-updateipcrisp.norminet.org.ph
>>>>>> [ OK ]
>>>>>> DeprecationWarning)
>>>>>> File
>>>>>> utility.execute()
>>>>>> File
>>>>>> 392, in execute
>>>>>> File
>>>>>> File
>>>>>> name))
>>>>>> __import__(name)
>>>>>> File
>>>>>> File
>>>>>> 31, in <module>
>>>>>> File
>>>>>> File
>>>>>> File
>>>>>> File
>>>>>> File
>>>>>> File
>>>>>> line 154, in _fetch
>>>>>> __import__(name)
>>>>>> jjqt at GeoNode:/usr/local/lib/python2.7/dist-packages/geonode$ pip
>>>>>> install relationships
>>>>>> Downloading/unpacking relationships
>>>>>> Exception:
>>>>>> File "/usr/lib/python2.7/dist-packages/pip/basecommand.py", line
>>>>>> 126, in main
>>>>>> self.run(options, args)
>>>>>> File "/usr/lib/python2.7/dist-packages/pip/commands/install.py",
>>>>>> line 223, in run
>>>>>> requirement_set.prepare_files(finder,
>>>>>> force_root_egg_info=self.bundle, bundle=self.bundle)
>>>>>> File "/usr/lib/python2.7/dist-packages/pip/req.py", line 942, in
>>>>>> prepare_files
>>>>>> location = req_to_install.build_location(self.build_dir, not
>>>>>> self.is_download)
>>>>>> File "/usr/lib/python2.7/dist-packages/pip/req.py", line 144, in
>>>>>> build_location
>>>>>> _make_build_dir(build_dir)
>>>>>> File "/usr/lib/python2.7/dist-packages/pip/req.py", line 1185, in
>>>>>> _make_build_dir
>>>>>> os.makedirs(build_dir)
>>>>>> File "/usr/lib/python2.7/os.py", line 157, in makedirs
>>>>>> mkdir(name, mode)
>>>>>> OSError: [Errno 13] Permission denied:
>>>>>> '/usr/local/lib/python2.7/dist-packages/geonode/build'
>>>>>> File "/usr/bin/pip", line 9, in <module>
>>>>>> load_entry_point('pip==1.0', 'console_scripts', 'pip')()
>>>>>> File "/usr/lib/python2.7/dist-packages/pip/__init__.py", line 116,
>>>>>> in main
>>>>>> return command.main(initial_args, args[1:], options)
>>>>>> 147, in main
>>>>>> log_fp = open_logfile(log_fn, 'w')
>>>>>> 176, in open_logfile
>>>>>> log_fp = open(filename, mode)
>>>>>> IOError: [Errno 13] Permission denied: '/home/jjqt/.pip/pip.log'
>>>>>> _______________________________________________
>>>>>> geonode-users mailing list
>>>>>> geonode-users at lists.osgeo.org
>>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
>>>>> Simone
>>> Simone
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150701/82d0b196/attachment-0001.html>
More information about the geonode-users
