[GeoNode-users] GeoNode Updateip Error (No module named relationships)
Simone Dalmasso
simone.dalmasso at gmail.com
Wed Jul 1 04:37:39 PDT 2015
Very strange,
it's like you are missing some settings. You have to track down the errors
until it's fixed, for now add
CACHE_TIME = 0
to your settings
2015-07-01 13:34 GMT+02:00 Jeffy John Tomarong <jeffytoms at gmail.com>:
> Yeah I'm sure. I also didn't even update Ubuntu..
> I was so excited to apply your fix. Unfortunately, it got this error again
> AttributeError at /
> 'Settings' object has no attribute 'CACHE_TIME'
> Request Method:GETRequest URL:http://crisp.norminet.org.ph/Django Version:
> 1.5.1Exception Type:AttributeErrorException Value:
> Exception Location:/usr/local/lib/python2.7/dist-packages/geonode/search/views.py
> in search_api, line 154Python Executable:/usr/bin/pythonPython Version:
> 2.7.3Python Path:
> ['/usr/lib/python2.7',
> '/usr/lib/python2.7/plat-linux2',
> '/usr/lib/python2.7/lib-tk',
> '/usr/lib/python2.7/lib-old',
> '/usr/lib/python2.7/lib-dynload',
> '/usr/local/lib/python2.7/dist-packages',
> '/usr/lib/python2.7/dist-packages',
> '/usr/lib/python2.7/dist-packages/PIL',
> '/usr/lib/python2.7/dist-packages/gtk-2.0',
> '/usr/lib/pymodules/python2.7',
> '/usr/lib/python2.7/dist-packages/ubuntu-sso-client']
> Server time:Wed, 1 Jul 2015 19:31:12 +0800
> Traceback Switch to copy-and-paste view <http://crisp.norminet.org.ph/#>
> - /usr/lib/python2.7/dist-packages/django/core/handlers/base.py in
> get_response
> 1.
> response = callback(request, *callback_args, **callback_kwargs)
> ▶ Local vars <http://crisp.norminet.org.ph/#>
> - /usr/local/lib/python2.7/dist-packages/geonode/views.py in index
> 1.
> return search_page(request, template=template)
> - /usr/local/lib/python2.7/dist-packages/geonode/search/views.py in
> search_page
> 1.
> results, facets, query = search_api(request, format='html', **kw)
> search_api
> 1.
> raise ex
> Request informationGET
> No GET data
> POSTVariableValuetype
> 'layer'
> FILES
> No FILES data
> COOKIESVariableValuecsrftoken
> 'abqLWg61drnUTEdw7Z1ghbLxXka8QVu0'
> METAVariableValuemod_wsgi.listener_port
> '80'
> HTTP_COOKIE
> 'csrftoken=abqLWg61drnUTEdw7Z1ghbLxXka8QVu0'
> mod_wsgi.listener_host
> SERVER_SOFTWARE
> 'Apache/2.2.22 (Ubuntu)'
> SCRIPT_NAME
> u''
> mod_wsgi.handler_script
> SERVER_SIGNATURE
> '<address>Apache/2.2.22 (Ubuntu) Server at crisp.norminet.org.ph Port 80</address>\n'
> REQUEST_METHOD
> 'GET'
> PATH_INFO
> u'/'
> SERVER_PROTOCOL
> 'HTTP/1.1'
> QUERY_STRING
> HTTP_USER_AGENT
> 'Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/35.0.1916.153 Safari/537.36'
> HTTP_CONNECTION
> 'keep-alive'
> SERVER_NAME
> 'crisp.norminet.org.ph'
> REMOTE_ADDR
> '121.97.223.10'
> mod_wsgi.request_handler
> 'wsgi-script'
> wsgi.url_scheme
> 'http'
> PATH_TRANSLATED
> '/var/www/geonode/wsgi/geonode.wsgi/'
> SERVER_PORT
> '80'
> wsgi.multiprocess
> True
> mod_wsgi.input_chunked
> '0'
> SERVER_ADDR
> '121.97.223.10'
> DOCUMENT_ROOT
> '/etc/apache2/htdocs'
> mod_wsgi.process_group
> 'geonode'
> SCRIPT_FILENAME
> '/var/www/geonode/wsgi/geonode.wsgi'
> SERVER_ADMIN
> 'webmaster at localhost'
> wsgi.input
> <mod_wsgi.Input object at 0x7f03645ab1b0>
> HTTP_HOST
> wsgi.multithread
> True
> mod_wsgi.callable_object
> 'application'
> HTTP_CACHE_CONTROL
> 'max-age=0'
> REQUEST_URI
> HTTP_ACCEPT
> 'text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,*/*;q=0.8'
> wsgi.version
> (1, 1)
> GATEWAY_INTERFACE
> 'CGI/1.1'
> wsgi.run_once
> False
> wsgi.errors
> <mod_wsgi.Log object at 0x7f0364773c30>
> REMOTE_PORT
> '40442'
> HTTP_ACCEPT_LANGUAGE
> 'en-US,en;q=0.8'
> mod_wsgi.version
> (3, 3)
> mod_wsgi.application_group
> 'localhost|'
> mod_wsgi.script_reloading
> '1'
> wsgi.file_wrapper
> CSRF_COOKIE
> u'abqLWg61drnUTEdw7Z1ghbLxXka8QVu0'
> HTTP_ACCEPT_ENCODING
> 'gzip,deflate,sdch'
> SettingsUsing settings module geonode.settingsSettingValue
> ACCOUNT_USER_DISPLAY
> STATIC_ROOT
> '/var/www/geonode/static/'
> GOOGLE_API_KEY
> u'********************'
> USE_THOUSAND_SEPARATOR
> False
> CSRF_COOKIE_SECURE
> False
> LANGUAGE_CODE
> 'en'
> ROOT_URLCONF
> 'geonode.urls'
> MANAGERS
> DB_DATASTORE_NAME
> DEFAULT_CHARSET
> 'utf-8'
> PYCSW
> {'CONFIGURATION': {'metadata:inspire': {'conformity_service': 'notEvaluated',
> 'contact_email': 'Email Address',
> 'contact_name': 'Organization Name',
> 'date': 'YYYY-MM-DD',
> 'default_language': 'eng',
> 'enabled': 'true',
> 'gemet_keywords': 'Utility and governmental services',
> 'languages_supported': 'eng,gre',
> 'temp_extent': 'YYYY-MM-DD/YYYY-MM-DD'},
> 'metadata:main': {'contact_address': 'Mailing Address',
> 'contact_city': 'City',
> 'contact_country': 'Country',
> 'contact_fax': '+xx-xxx-xxx-xxxx',
> 'contact_hours': 'Hours of Service',
> 'contact_instructions': 'During hours of service. Off on weekends.',
> 'contact_name': 'Lastname, Firstname',
> 'contact_phone': '+xx-xxx-xxx-xxxx',
> 'contact_position': 'Position Title',
> 'contact_postalcode': 'Zip or Postal Code',
> 'contact_role': 'pointOfContact',
> 'contact_stateorprovince': 'Administrative Area',
> 'contact_url': 'Contact URL',
> 'identification_abstract': 'GeoNode is an open source platform that facilitates the creation, sharing, and collaborative use of geospatial data',
> 'identification_accessconstraints': 'None',
> 'identification_fees': 'None',
> 'identification_keywords': 'sdi,catalogue,discovery,metadata,GeoNode',
> 'identification_keywords_type': 'theme',
> 'identification_title': 'GeoNode Catalogue',
> 'provider_name': 'Organization Name',
> 'provider_url': 'http://crisp.norminet.org.ph:8000/'}}}
> DEFAULT_MAP_CENTER
> (0, 0)
> ACCOUNT_EMAIL_CONFIRMATION_EXPIRE_DAYS
> 3
> DB_DATASTORE
> False
> ACCOUNT_EMAIL_CONFIRMATION_AUTHENTICATED_REDIRECT_URL
> None
> GEOSERVER_BASE_URL
> 'http://crisp.norminet.org.ph:8080/geoserver/'
> REGISTRATION_OPEN
> False
> ALLOWED_HOSTS
> ['crisp.norminet.org.ph', 'localhost']
> OGC_SERVER
> {'default': {'BACKEND': 'geonode.geoserver',
> 'BACKEND_WRITE_ENABLED': True,
> 'DATASTORE': 'datastore',
> 'GEOGIT_DATASTORE_DIR': '',
> 'GEOGIT_ENABLED': False,
> 'GEONODE_SECURITY_ENABLED': True,
> 'LOCATION': 'http://crisp.norminet.org.ph:8080/geoserver/',
> 'MAPFISH_PRINT_ENABLED': True,
> 'PASSWORD': u'********************',
> 'PRINTING_ENABLED': True,
> 'PRINTNG_ENABLED': True,
> 'PUBLIC_LOCATION': 'http://crisp.norminet.org.ph/geoserver/',
> 'USER': 'admin',
> 'WMST_ENABLED': False,
> 'WPS_ENABLED': False}}
> MESSAGE_STORAGE
> 'django.contrib.messages.storage.fallback.FallbackStorage'
> DATABASE_HOST
> 'localhost'
> EMAIL_SUBJECT_PREFIX
> '[Django] '
> SEND_BROKEN_LINK_EMAILS
> False
> STATICFILES_FINDERS
> ('django.contrib.staticfiles.finders.FileSystemFinder',
> 'django.contrib.staticfiles.finders.AppDirectoriesFinder')
> SESSION_CACHE_ALIAS
> 'default'
> SESSION_COOKIE_DOMAIN
> None
> SESSION_COOKIE_NAME
> 'sessionid'
> DB_DATASTORE_USER
> CSRF_COOKIE_NAME
> 'csrftoken'
> ADMIN_FOR
> TIME_INPUT_FORMATS
> ('%H:%M:%S', '%H:%M')
> DATABASES
> {'datastore': {'ENGINE': 'django.contrib.gis.db.backends.postgis',
> 'HOST': 'localhost',
> 'NAME': 'geonode',
> 'OPTIONS': {},
> 'PORT': '5432',
> 'TEST_CHARSET': None,
> 'TEST_COLLATION': None,
> 'TEST_MIRROR': None,
> 'TEST_NAME': None,
> 'TIME_ZONE': 'Asia/Manila',
> 'USER': 'geonode'},
> 'default': {'ENGINE': 'django.db.backends.postgresql_psycopg2',
> 'NAME': 'geonode',
> 'OPTIONS': {},
> 'PORT': '5432',
> 'TEST_NAME': None,
> 'USER': 'geonode'}}
> FILE_UPLOAD_PERMISSIONS
> None
> ACCOUNT_TIMEZONES
> [('Africa/Abidjan', 'Africa/Abidjan'),
> ('Africa/Accra', 'Africa/Accra'),
> ('Africa/Addis_Ababa', 'Africa/Addis_Ababa'),
> ('Africa/Algiers', 'Africa/Algiers'),
> ('Africa/Asmara', 'Africa/Asmara'),
> ('Africa/Asmera', 'Africa/Asmera'),
> ('Africa/Bamako', 'Africa/Bamako'),
> ('Africa/Bangui', 'Africa/Bangui'),
> ('Africa/Banjul', 'Africa/Banjul'),
> ('Africa/Bissau', 'Africa/Bissau'),
> ('Africa/Blantyre', 'Africa/Blantyre'),
> ('Africa/Brazzaville', 'Africa/Brazzaville'),
> ('Africa/Bujumbura', 'Africa/Bujumbura'),
> ('Africa/Cairo', 'Africa/Cairo'),
> ('Africa/Casablanca', 'Africa/Casablanca'),
> ('Africa/Ceuta', 'Africa/Ceuta'),
> ('Africa/Conakry', 'Africa/Conakry'),
> ('Africa/Dakar', 'Africa/Dakar'),
> ('Africa/Dar_es_Salaam', 'Africa/Dar_es_Salaam'),
> ('Africa/Djibouti', 'Africa/Djibouti'),
> ('Africa/Douala', 'Africa/Douala'),
> ('Africa/El_Aaiun', 'Africa/El_Aaiun'),
> ('Africa/Freetown', 'Africa/Freetown'),
> ('Africa/Gaborone', 'Africa/Gaborone'),
> ('Africa/Harare', 'Africa/Harare'),
> ('Africa/Johannesburg', 'Africa/Johannesburg'),
> ('Africa/Kampala', 'Africa/Kampala'),
> ('Africa/Khartoum', 'Africa/Khartoum'),
> ('Africa/Kigali', 'Africa/Kigali'),
> ('Africa/Kinshasa', 'Africa/Kinshasa'),
> ('Africa/Lagos', 'Africa/Lagos'),
> ('Africa/Libreville', 'Africa/Libreville'),
> ('Africa/Lome', 'Africa/Lome'),
> ('Africa/Luanda', 'Africa/Luanda'),
> ('Africa/Lubumbashi', 'Africa/Lubumbashi'),
> ('Africa/Lusaka', 'Africa/Lusaka'),
> ('Africa/Malabo', 'Africa/Malabo'),
> ('Africa/Maputo', 'Africa/Maputo'),
> ('Africa/Maseru', 'Africa/Maseru'),
> ('Africa/Mbabane', 'Africa/Mbabane'),
> ('Africa/Mogadishu', 'Africa/Mogadishu'),
> ('Africa/Monrovia', 'Africa/Monrovia'),
> ('Africa/Nairobi', 'Africa/Nairobi'),
> ('Africa/Ndjamena', 'Africa/Ndjamena'),
> ('Africa/Niamey', 'Africa/Niamey'),
> ('Africa/Nouakchott', 'Africa/Nouakchott'),
> ('Africa/Ouagadougou', 'Africa/Ouagadougou'),
> ('Africa/Porto-Novo', 'Africa/Porto-Novo'),
> ('Africa/Sao_Tome', 'Africa/Sao_Tome'),
> ('Africa/Timbuktu', 'Africa/Timbuktu'),
> ('Africa/Tripoli', 'Africa/Tripoli'),
> ('Africa/Tunis', 'Africa/Tunis'),
> ('Africa/Windhoek', 'Africa/Windhoek'),
> ('America/Adak', 'America/Adak'),
> ('America/Anchorage', 'America/Anchorage'),
> ('America/Anguilla', 'America/Anguilla'),
> ('America/Antigua', 'America/Antigua'),
> ('America/Araguaina', 'America/Araguaina'),
> ('America/Argentina/Buenos_Aires', 'America/Argentina/Buenos_Aires'),
> ('America/Argentina/Catamarca', 'America/Argentina/Catamarca'),
> ('America/Argentina/ComodRivadavia', 'America/Argentina/ComodRivadavia'),
> ('America/Argentina/Cordoba', 'America/Argentina/Cordoba'),
> ('America/Argentina/Jujuy', 'America/Argentina/Jujuy'),
> ('America/Argentina/La_Rioja', 'America/Argentina/La_Rioja'),
> ('America/Argentina/Mendoza', 'America/Argentina/Mendoza'),
> ('America/Argentina/Rio_Gallegos', 'America/Argentina/Rio_Gallegos'),
> ('America/Argentina/Salta', 'America/Argentina/Salta'),
> ('America/Argentina/San_Juan', 'America/Argentina/San_Juan'),
> ('America/Argentina/San_Luis', 'America/Argentina/San_Luis'),
> ('America/Argentina/Tucuman', 'America/Argentina/Tucuman'),
> ('America/Argentina/Ushuaia', 'America/Argentina/Ushuaia'),
> ('America/Aruba', 'America/Aruba'),
> ('America/Asuncion', 'America/Asuncion'),
> ('America/Atikokan', 'America/Atikokan'),
> ('America/Atka', 'America/Atka'),
> ('America/Bahia', 'America/Bahia'),
> ('America/Bahia_Banderas', 'America/Bahia_Banderas'),
> ('America/Barbados', 'America/Barbados'),
> ('America/Belem', 'America/Belem'),
> ('America/Belize', 'America/Belize'),
> ('America/Blanc-Sablon', 'America/Blanc-Sablon'),
> ('America/Boa_Vista', 'America/Boa_Vista'),
> ('America/Bogota', 'America/Bogota'),
> ('America/Boise', 'America/Boise'),
> ('America/Buenos_Aires', 'America/Buenos_Aires'),
> ('America/Cambridge_Bay', 'America/Cambridge_Bay'),
> ('America/Campo_Grande', 'America/Campo_Grande'),
> ('America/Cancun', 'America/Cancun'),
> ('America/Caracas', 'America/Caracas'),
> ('America/Catamarca', 'America/Catamarca'),
> ('America/Cayenne', 'America/Cayenne'),
> ('America/Cayman', 'America/Cayman'),
> ('America/Chicago', 'America/Chicago'),
> ('America/Chihuahua', 'America/Chihuahua'),
> ('America/Coral_Harbour', 'America/Coral_Harbour'),
> ('America/Cordoba', 'America/Cordoba'),
> ('America/Costa_Rica', 'America/Costa_Rica'),
> ('America/Cuiaba', 'America/Cuiaba'),
> ('America/Curacao', 'America/Curacao'),
> ('America/Danmarkshavn', 'America/Danmarkshavn'),
> ('America/Dawson', 'America/Dawson'),
> ('America/Dawson_Creek', 'America/Dawson_Creek'),
> ('America/Denver', 'America/Denver'),
> ('America/Detroit', 'America/Detroit'),
> ('America/Dominica', 'America/Dominica'),
> ('America/Edmonton', 'America/Edmonton'),
> ('America/Eirunepe', 'America/Eirunepe'),
> ('America/El_Salvador', 'America/El_Salvador'),
> ('America/Ensenada', 'America/Ensenada'),
> ('America/Fort_Wayne', 'America/Fort_Wayne'),
> ('America/Fortaleza', 'America/Fortaleza'),
> ('America/Glace_Bay', 'America/Glace_Bay'),
> ('America/Godthab', 'America/Godthab'),
> ('America/Goose_Bay', 'America/Goose_Bay'),
> ('America/Grand_Turk', 'America/Grand_Turk'),
> ('America/Grenada', 'America/Grenada'),
> ('America/Guadeloupe', 'America/Guadeloupe'),
> ('America/Guatemala', 'America/Guatemala'),
> ('America/Guayaquil', 'America/Guayaquil'),
> ('America/Guyana', 'America/Guyana'),
> ('America/Halifax', 'America/Halifax'),
> ('America/Havana', 'America/Havana'),
> ('America/Hermosillo', 'America/Hermosillo'),
> ('America/Indiana/Indianapolis', 'America/Indiana/Indianapolis'),
> ('America/Indiana/Knox', 'America/Indiana/Knox'),
> ('America/Indiana/Marengo', 'America/Indiana/Marengo'),
> ('America/Indiana/Petersburg', 'America/Indiana/Petersburg'),
> ('America/Indiana/Tell_City', 'America/Indiana/Tell_City'),
> ('America/Indiana/Vevay', 'America/Indiana/Vevay'),
> ('America/Indiana/Vincennes', 'America/Indiana/Vincennes'),
> ('America/Indiana/Winamac', 'America/Indiana/Winamac'),
> ('America/Indianapolis', 'America/Indianapolis'),
> ('America/Inuvik', 'America/Inuvik'),
> ('America/Iqaluit', 'America/Iqaluit'),
> ('America/Jamaica', 'America/Jamaica'),
> ('America/Jujuy', 'America/Jujuy'),
> ('America/Juneau', 'America/Juneau'),
> ('America/Kentucky/Louisville', 'America/Kentucky/Louisville'),
> ('America/Kentucky/Monticello', 'America/Kentucky/Monticello'),
> ('America/Knox_IN', 'America/Knox_IN'),
> ('America/Kralendijk', 'America/Kralendijk'),
> ('America/La_Paz', 'America/La_Paz'),
> ('America/Lima', 'America/Lima'),
> ('America/Los_Angeles', 'America/Los_Angeles'),
> ('America/Louisville', 'America/Louisville'),
> ('America/Lower_Princes', 'America/Lower_Princes'),
> ('America/Maceio', 'America/Maceio'),
> ('America/Managua', 'America/Managua'),
> ('America/Manaus', 'America/Manaus'),
> ('America/Marigot', 'America/Marigot'),
> ('America/Martinique', 'America/Martinique'),
> ('America/Matamoros', 'America/Matamoros'),
> ('America/Mazatlan', 'America/Mazatlan'),
> ('America/Mendoza', 'America/Mendoza'),
> ('America/Menominee', 'America/Menominee'),
> ('America/Merida', 'America/Merida'),
> ('America/Metlakatla', 'America/Metlakatla'),
> ('America/Mexico_City', 'America/Mexico_City'),
> ('America/Miquelon', 'America/Miquelon'),
> ('America/Moncton', 'America/Moncton'),
> ('America/Monterrey', 'America/Monterrey'),
> ('America/Montevideo', 'America/Montevideo'),
> ('America/Montreal', 'America/Montreal'),
> ('America/Montserrat', 'America/Montserrat'),
> ('America/Nassau', 'America/Nassau'),
> ('America/New_York', 'America/New_York'),
> ('America/Nipigon', 'America/Nipigon'),
> ('America/Nome', 'America/Nome'),
> ('America/Noronha', 'America/Noronha'),
> ('America/North_Dakota/Beulah', 'America/North_Dakota/Beulah'),
> ('America/North_Dakota/Center', 'America/North_Dakota/Center'),
> ('America/North_Dakota/New_Salem', 'America/North_Dakota/New_Salem'),
> ('America/Ojinaga', 'America/Ojinaga'),
> ('America/Panama', 'America/Panama'),
> ('America/Pangnirtung', 'America/Pangnirtung'),
> ('America/Paramaribo', 'America/Paramaribo'),
> ('America/Phoenix', 'America/Phoenix'),
> ('America/Port-au-Prince', 'America/Port-au-Prince'),
> ('America/Port_of_Spain', 'America/Port_of_Spain'),
> ('America/Porto_Acre', 'America/Porto_Acre'),
> ('America/Porto_Velho', 'America/Porto_Velho'),
> ('America/Puerto_Rico', 'America/Puerto_Rico'),
> ('America/Rainy_River', 'America/Rainy_River'),
> ('America/Rankin_Inlet', 'America/Rankin_Inlet'),
> ('America/Recife', 'America/Recife'),
> ('America/Regina', 'America/Regina'),
> ('America/Resolute', 'America/Resolute'),
> ('America/Rio_Branco', 'America/Rio_Branco'),
> ('America/Rosario', 'America/Rosario'),
> ('America/Santa_Isabel', 'America/Santa_Isabel'),
> ('America/Santarem', 'America/Santarem'),
> ('America/Santiago', 'America/Santiago'),
> ('America/Santo_Domingo', 'America/Santo_Domingo'),
> ('America/Sao_Paulo', 'America/Sao_Paulo'),
> ('America/Scoresbysund', 'America/Scoresbysund'),
> ('America/Shiprock', 'America/Shiprock'),
> ('America/Sitka', 'America/Sitka'),
> ('America/St_Barthelemy', 'America/St_Barthelemy'),
> ('America/St_Johns', 'America/St_Johns'),
> ('America/St_Kitts', 'America/St_Kitts'),
> ('America/St_Lucia', 'America/St_Lucia'),
> ('America/St_Thomas', 'America/St_Thomas'),
> ('America/St_Vincent', 'America/St_Vincent'),
> ('America/Swift_Current', 'America/Swift_Current'),
> ('America/Tegucigalpa', 'America/Tegucigalpa'),
> ('America/Thule', 'America/Thule'),
> ('America/Thunder_Bay', 'America/Thunder_Bay'),
> ('America/Tijuana', 'America/Tijuana'),
> ('America/Toronto', 'America/Toronto'),
> ('America/Tortola', 'America/Tortola'),
> ('America/Vancouver', 'America/Vancouver'),
> ('America/Virgin', 'America/Virgin'),
> ('America/Whitehorse', 'America/Whitehorse'),
> ('America/Winnipeg', 'America/Winnipeg'),
> ('America/Yakutat', 'America/Yakutat'),
> ('America/Yellowknife', 'America/Yellowknife'),
> ('Antarctica/Casey', 'Antarctica/Casey'),
> ('Antarctica/Davis', 'Antarctica/Davis'),
> ('Antarctica/DumontDUrville', 'Antarctica/DumontDUrville'),
> ('Antarctica/Macquarie', 'Antarctica/Macquarie'),
> ('Antarctica/Mawson', 'Antarctica/Mawson'),
> ('Antarctica/McMurdo', 'Antarctica/McMurdo'),
> ('Antarctica/Palmer', 'Antarctica/Palmer'),
> ('Antarctica/Rothera', 'Antarctica/Rothera'),
> ('Antarctica/South_Pole', 'Antarctica/South_Pole'),
> ('Antarctica/Syowa', 'Antarctica/Syowa'),
> ('Antarctica/Vostok', 'Antarctica/Vostok'),
> ('Arctic/Longyearbyen', 'Arctic/Longyearbyen'),
> ('Asia/Aden', 'Asia/Aden'),
> ('Asia/Almaty', 'Asia/Almaty'),
> ('Asia/Amman', 'Asia/Amman'),
> ('Asia/Anadyr', 'Asia/Anadyr'),
> ('Asia/Aqtau', 'Asia/Aqtau'),
> ('Asia/Aqtobe', 'Asia/Aqtobe'),
> ('Asia/Ashgabat', 'Asia/Ashgabat'),
> ('Asia/Ashkhabad', 'Asia/Ashkhabad'),
> ('Asia/Baghdad', 'Asia/Baghdad'),
> ('Asia/Bahrain', 'Asia/Bahrain'),
> ('Asia/Baku', 'Asia/Baku'),
> ('Asia/Bangkok', 'Asia/Bangkok'),
> ('Asia/Beirut', 'Asia/Beirut'),
> ('Asia/Bishkek', 'Asia/Bishkek'),
> ('Asia/Brunei', 'Asia/Brunei'),
> ('Asia/Calcutta', 'Asia/Calcutta'),
> ('Asia/Choibalsan', 'Asia/Choibalsan'),
> ('Asia/Chongqing', 'Asia/Chongqing'),
> ('Asia/Chungking', 'Asia/Chungking'),
> ('Asia/Colombo', 'Asia/Colombo'),
> ('Asia/Dacca', 'Asia/Dacca'),
> ('Asia/Damascus', 'Asia/Damascus'),
> ('Asia/Dhaka', 'Asia/Dhaka'),
> ('Asia/Dili', 'Asia/Dili'),
> ('Asia/Dubai', 'Asia/Dubai'),
> ('Asia/Dushanbe', 'Asia/Dushanbe'),
> ('Asia/Gaza', 'Asia/Gaza'),
> ('Asia/Harbin', 'Asia/Harbin'),
> ('Asia/Ho_Chi_Minh', 'Asia/Ho_Chi_Minh'),
> ('Asia/Hong_Kong', 'Asia/Hong_Kong'),
> ('Asia/Hovd', 'Asia/Hovd'),
> ('Asia/Irkutsk', 'Asia/Irkutsk'),
> ('Asia/Istanbul', 'Asia/Istanbul'),
> ('Asia/Jakarta', 'Asia/Jakarta'),
> ('Asia/Jayapura', 'Asia/Jayapura'),
> ('Asia/Jerusalem', 'Asia/Jerusalem'),
> ('Asia/Kabul', 'Asia/Kabul'),
> ('Asia/Kamchatka', 'Asia/Kamchatka'),
> ('Asia/Karachi', 'Asia/Karachi'),
> ('Asia/Kashgar', 'Asia/Kashgar'),
> ('Asia/Kathmandu', 'Asia/Kathmandu'),
> ('Asia/Katmandu', 'Asia/Katmandu'),
> ('Asia/Kolkata', 'Asia/Kolkata'),
> ('Asia/Krasnoyarsk', 'Asia/Krasnoyarsk'),
> ('Asia/Kuala_Lumpur', 'Asia/Kuala_Lumpur'),
> ('Asia/Kuching', 'Asia/Kuching'),
> ('Asia/Kuwait', 'Asia/Kuwait'),
> ('Asia/Macao', 'Asia/Macao'),
> ('Asia/Macau', 'Asia/Macau'),
> ('Asia/Magadan', 'Asia/Magadan'),
> ('Asia/Makassar', 'Asia/Makassar'),
> ('Asia/Manila', 'Asia/Manila'),
> ('Asia/Muscat', 'Asia/Muscat'),
> ('Asia/Nicosia', 'Asia/Nicosia'),
> ('Asia/Novokuznetsk', 'Asia/Novokuznetsk'),
> ('Asia/Novosibirsk', 'Asia/Novosibirsk'),
> ('Asia/Omsk', 'Asia/Omsk'),
> ('Asia/Oral', 'Asia/Oral'),
> ('Asia/Phnom_Penh', 'Asia/Phnom_Penh'),
> ('Asia/Pontianak', 'Asia/Pontianak'),
> ('Asia/Pyongyang', 'Asia/Pyongyang'),
> ('Asia/Qatar', 'Asia/Qatar'),
> ('Asia/Qyzylorda', 'Asia/Qyzylorda'),
> ('Asia/Rangoon', 'Asia/Rangoon'),
> ('Asia/Riyadh', 'Asia/Riyadh'),
> ('Asia/Saigon', 'Asia/Saigon'),
> ('Asia/Sakhalin', 'Asia/Sakhalin'),
> ('Asia/Samarkand', 'Asia/Samarkand'),
> ('Asia/Seoul', 'Asia/Seoul'),
> ('Asia/Shanghai', 'Asia/Shanghai'),
> ('Asia/Singapore', 'Asia/Singapore'),
> ('Asia/Taipei', 'Asia/Taipei'),
> ('Asia/Tashkent', 'Asia/Tashkent'),
> ('Asia/Tbilisi', 'Asia/Tbilisi'),
> ('Asia/Tehran', 'Asia/Tehran'),
> ('Asia/Tel_Aviv', 'Asia/Tel_Aviv'),
> ('Asia/Thimbu', 'Asia/Thimbu'),
> ('Asia/Thimphu', 'Asia/Thimphu'),
> ('Asia/Tokyo', 'Asia/Tokyo'),
> ('Asia/Ujung_Pandang', 'Asia/Ujung_Pandang'),
> ('Asia/Ulaanbaatar', 'Asia/Ulaanbaatar'),
> ('Asia/Ulan_Bator', 'Asia/Ulan_Bator'),
> ('Asia/Urumqi', 'Asia/Urumqi'),
> ('Asia/Vientiane', 'Asia/Vientiane'),
> ('Asia/Vladivostok', 'Asia/Vladivostok'),
> ('Asia/Yakutsk', 'Asia/Yakutsk'),
> ('Asia/Yekaterinburg', 'Asia/Yekaterinburg'),
> ('Asia/Yerevan', 'Asia/Yerevan'),
> ('Atlantic/Azores', 'Atlantic/Azores'),
> ('Atlantic/Bermuda', 'Atlantic/Bermuda'),
> ('Atlantic/Canary', 'Atlantic/Canary'),
> ('Atlantic/Cape_Verde', 'Atlantic/Cape_Verde'),
> ('Atlantic/Faeroe', 'Atlantic/Faeroe'),
> ('Atlantic/Faroe', 'Atlantic/Faroe'),
> ('Atlantic/Jan_Mayen', 'Atlantic/Jan_Mayen'),
> ('Atlantic/Madeira', 'Atlantic/Madeira'),
> ('Atlantic/Reykjavik', 'Atlantic/Reykjavik'),
> ('Atlantic/South_Georgia', 'Atlantic/South_Georgia'),
> ('Atlantic/St_Helena', 'Atlantic/St_Helena'),
> ('Atlantic/Stanley', 'Atlantic/Stanley'),
> ('Australia/ACT', 'Australia/ACT'),
> ('Australia/Adelaide', 'Australia/Adelaide'),
> ('Australia/Brisbane', 'Australia/Brisbane'),
> ('Australia/Broken_Hill', 'Australia/Broken_Hill'),
> ('Australia/Canberra', 'Australia/Canberra'),
> ('Australia/Currie', 'Australia/Currie'),
> ('Australia/Darwin', 'Australia/Darwin'),
> ('Australia/Eucla', 'Australia/Eucla'),
> ('Australia/Hobart', 'Australia/Hobart'),
> ('Australia/LHI', 'Australia/LHI'),
> ('Australia/Lindeman', 'Australia/Lindeman'),
> ('Australia/Lord_Howe', 'Australia/Lord_Howe'),
> ('Australia/Melbourne', 'Australia/Melbourne'),
> ('Australia/NSW', 'Australia/NSW'),
> ('Australia/North', 'Australia/North'),
> ('Australia/Perth', 'Australia/Perth'),
> ('Australia/Queensland', 'Australia/Queensland'),
> ('Australia/South', 'Australia/South'),
> ('Australia/Sydney', 'Australia/Sydney'),
> ('Australia/Tasmania', 'Australia/Tasmania'),
> ('Australia/Victoria', 'Australia/Victoria'),
> ('Australia/West', 'Australia/West'),
> ('Australia/Yancowinna', 'Australia/Yancowinna'),
> ('Brazil/Acre', 'Brazil/Acre'),
> ('Brazil/DeNoronha', 'Brazil/DeNoronha'),
> ('Brazil/East', 'Brazil/East'),
> ('Brazil/West', 'Brazil/West'),
> ('CET', 'CET'),
> ('CST6CDT', 'CST6CDT'),
> ('Canada/Atlantic', 'Canada/Atlantic'),
> ('Canada/Central', 'Canada/Central'),
> ('Canada/East-Saskatchewan', 'Canada/East-Saskatchewan'),
> ('Canada/Eastern', 'Canada/Eastern'),
> ('Canada/Mountain', 'Canada/Mountain'),
> ('Canada/Newfoundland', 'Canada/Newfoundland'),
> ('Canada/Pacific', 'Canada/Pacific'),
> ('Canada/Saskatchewan', 'Canada/Saskatchewan'),
> ('Canada/Yukon', 'Canada/Yukon'),
> ('Chile/Continental', 'Chile/Continental'),
> ('Chile/EasterIsland', 'Chile/EasterIsland'),
> ('Cuba', 'Cuba'),
> ('EET', 'EET'),
> ('EST', 'EST'),
> ('EST5EDT', 'EST5EDT'),
> ('Egypt', 'Egypt'),
> ('Eire', 'Eire'),
> ('Etc/GMT', 'Etc/GMT'),
> ('Etc/GMT+0', 'Etc/GMT+0'),
> ('Etc/GMT+1', 'Etc/GMT+1'),
> ('Etc/GMT+10', 'Etc/GMT+10'),
> ('Etc/GMT+11', 'Etc/GMT+11'),
> ('Etc/GMT+12', 'Etc/GMT+12'),
> ('Etc/GMT+2', 'Etc/GMT+2'),
> ('Etc/GMT+3', 'Etc/GMT+3'),
> ('Etc/GMT+4', 'Etc/GMT+4'),
> ('Etc/GMT+5', 'Etc/GMT+5'),
> ('Etc/GMT+6', 'Etc/GMT+6'),
> ('Etc/GMT+7', 'Etc/GMT+7'),
> ('Etc/GMT+8', 'Etc/GMT+8'),
> ('Etc/GMT+9', 'Etc/GMT+9'),
> ('Etc/GMT-0', 'Etc/GMT-0'),
> ('Etc/GMT-1', 'Etc/GMT-1'),
> ('Etc/GMT-10', 'Etc/GMT-10'),
> ('Etc/GMT-11', 'Etc/GMT-11'),
> ('Etc/GMT-12', 'Etc/GMT-12'),
> ('Etc/GMT-13', 'Etc/GMT-13'),
> ('Etc/GMT-14', 'Etc/GMT-14'),
> ('Etc/GMT-2', 'Etc/GMT-2'),
> ('Etc/GMT-3', 'Etc/GMT-3'),
> ('Etc/GMT-4', 'Etc/GMT-4'),
> ('Etc/GMT-5', 'Etc/GMT-5'),
> ('Etc/GMT-6', 'Etc/GMT-6'),
> ('Etc/GMT-7', 'Etc/GMT-7'),
> ('Etc/GMT-8', 'Etc/GMT-8'),
> ('Etc/GMT-9', 'Etc/GMT-9'),
> ('Etc/GMT0', 'Etc/GMT0'),
> ('Etc/Greenwich', 'Etc/Greenwich'),
> ('Etc/UCT', 'Etc/UCT'),
> ('Etc/UTC', 'Etc/UTC'),
> ('Etc/Universal', 'Etc/Universal'),
> ('Etc/Zulu', 'Etc/Zulu'),
> ('Europe/Amsterdam', 'Europe/Amsterdam'),
> ('Europe/Andorra', 'Europe/Andorra'),
> ('Europe/Athens', 'Europe/Athens'),
> ('Europe/Belfast', 'Europe/Belfast'),
> ('Europe/Belgrade', 'Europe/Belgrade'),
> ('Europe/Berlin', 'Europe/Berlin'),
> ('Europe/Bratislava', 'Europe/Bratislava'),
> ('Europe/Brussels', 'Europe/Brussels'),
> ('Europe/Bucharest', 'Europe/Bucharest'),
> ('Europe/Budapest', 'Europe/Budapest'),
> ('Europe/Chisinau', 'Europe/Chisinau'),
> ('Europe/Copenhagen', 'Europe/Copenhagen'),
> ('Europe/Dublin', 'Europe/Dublin'),
> ('Europe/Gibraltar', 'Europe/Gibraltar'),
> ('Europe/Guernsey', 'Europe/Guernsey'),
> ('Europe/Helsinki', 'Europe/Helsinki'),
> ('Europe/Isle_of_Man', 'Europe/Isle_of_Man'),
> ('Europe/Istanbul', 'Europe/Istanbul'),
> ('Europe/Jersey', 'Europe/Jersey'),
> ('Europe/Kaliningrad', 'Europe/Kaliningrad'),
> ('Europe/Kiev', 'Europe/Kiev'),
> ('Europe/Lisbon', 'Europe/Lisbon'),
> ('Europe/Ljubljana', 'Europe/Ljubljana'),
> ('Europe/London', 'Europe/London'),
> ('Europe/Luxembourg', 'Europe/Luxembourg'),
> ('Europe/Madrid', 'Europe/Madrid'),
> ('Europe/Malta', 'Europe/Malta'),
> ('Europe/Mariehamn', 'Europe/Mariehamn'),
> ('Europe/Minsk', 'Europe/Minsk'),
> ('Europe/Monaco', 'Europe/Monaco'),
> ('Europe/Moscow', 'Europe/Moscow'),
> ('Europe/Nicosia', 'Europe/Nicosia'),
> ('Europe/Oslo', 'Europe/Oslo'),
> ('Europe/Paris', 'Europe/Paris'),
> ('Europe/Podgorica', 'Europe/Podgorica'),
> ('Europe/Prague', 'Europe/Prague'),
> ('Europe/Riga', 'Europe/Riga'),
> ('Europe/Rome', 'Europe/Rome'),
> ('Europe/Samara', 'Europe/Samara'),
> ('Europe/San_Marino', 'Europe/San_Marino'),
> ('Europe/Sarajevo', 'Europe/Sarajevo'),
> ('Europe/Simferopol', 'Europe/Simferopol'),
> ('Europe/Skopje', 'Europe/Skopje'),
> ('Europe/Sofia', 'Europe/Sofia'),
> ('Europe/Stockholm', 'Europe/Stockholm'),
> ('Europe/Tallinn', 'Europe/Tallinn'),
> ('Europe/Tirane', 'Europe/Tirane'),
> ('Europe/Tiraspol', 'Europe/Tiraspol'),
> ('Europe/Uzhgorod', 'Europe/Uzhgorod'),
> ('Europe/Vaduz', 'Europe/Vaduz'),
> ('Europe/Vatican', 'Europe/Vatican'),
> ('Europe/Vienna', 'Europe/Vienna'),
> ('Europe/Vilnius', 'Europe/Vilnius'),
> ('Europe/Volgograd', 'Europe/Volgograd'),
> ('Europe/Warsaw', 'Europe/Warsaw'),
> ('Europe/Zagreb', 'Europe/Zagreb'),
> ('Europe/Zaporozhye', 'Europe/Zaporozhye'),
> ('Europe/Zurich', 'Europe/Zurich'),
> ('GB', 'GB'),
> ('GB-Eire', 'GB-Eire'),
> ('GMT', 'GMT'),
> ('GMT+0', 'GMT+0'),
> ('GMT-0', 'GMT-0'),
> ('GMT0', 'GMT0'),
> ('Greenwich', 'Greenwich'),
> ('HST', 'HST'),
> ('Hongkong', 'Hongkong'),
> ('Iceland', 'Iceland'),
> ('Indian/Antananarivo', 'Indian/Antananarivo'),
> ('Indian/Chagos', 'Indian/Chagos'),
> ('Indian/Christmas', 'Indian/Christmas'),
> ('Indian/Cocos', 'Indian/Cocos'),
> ('Indian/Comoro', 'Indian/Comoro'),
> ('Indian/Kerguelen', 'Indian/Kerguelen'),
> ('Indian/Mahe', 'Indian/Mahe'),
> ('Indian/Maldives', 'Indian/Maldives'),
> ('Indian/Mauritius', 'Indian/Mauritius'),
> ('Indian/Mayotte', 'Indian/Mayotte'),
> ('Indian/Reunion', 'Indian/Reunion'),
> ('Iran', 'Iran'),
> ('Israel', 'Israel'),
> ('Jamaica', 'Jamaica'),
> ('Japan', 'Japan'),
> ('Kwajalein', 'Kwajalein'),
> ('Libya', 'Libya'),
> ('MET', 'MET'),
> ('MST', 'MST'),
> ('MST7MDT', 'MST7MDT'),
> ('Mexico/BajaNorte', 'Mexico/BajaNorte'),
> ('Mexico/BajaSur', 'Mexico/BajaSur'),
> ('Mexico/General', 'Mexico/General'),
> ('NZ', 'NZ'),
> ('NZ-CHAT', 'NZ-CHAT'),
> ('Navajo', 'Navajo'),
> ('PRC', 'PRC'),
> ('PST8PDT', 'PST8PDT'),
> ('Pacific/Apia', 'Pacific/Apia'),
> ('Pacific/Auckland', 'Pacific/Auckland'),
> ('Pacific/Chatham', 'Pacific/Chatham'),
> ('Pacific/Chuuk', 'Pacific/Chuuk'),
> ('Pacific/Easter', 'Pacific/Easter'),
> ('Pacific/Efate', 'Pacific/Efate'),
> ('Pacific/Enderbury', 'Pacific/Enderbury'),
> ('Pacific/Fakaofo', 'Pacific/Fakaofo'),
> ('Pacific/Fiji', 'Pacific/Fiji'),
> ('Pacific/Funafuti', 'Pacific/Funafuti'),
> ('Pacific/Galapagos', 'Pacific/Galapagos'),
> ('Pacific/Gambier', 'Pacific/Gambier'),
> ('Pacific/Guadalcanal', 'Pacific/Guadalcanal'),
> ('Pacific/Guam', 'Pacific/Guam'),
> ('Pacific/Honolulu', 'Pacific/Honolulu'),
> ('Pacific/Johnston', 'Pacific/Johnston'),
> ('Pacific/Kiritimati', 'Pacific/Kiritimati'),
> ('Pacific/Kosrae', 'Pacific/Kosrae'),
> ('Pacific/Kwajalein', 'Pacific/Kwajalein'),
> ('Pacific/Majuro', 'Pacific/Majuro'),
> ('Pacific/Marquesas', 'Pacific/Marquesas'),
> ('Pacific/Midway', 'Pacific/Midway'),
> ('Pacific/Nauru', 'Pacific/Nauru'),
> ('Pacific/Niue', 'Pacific/Niue'),
> ('Pacific/Norfolk', 'Pacific/Norfolk'),
> ('Pacific/Noumea', 'Pacific/Noumea'),
> ('Pacific/Pago_Pago', 'Pacific/Pago_Pago'),
> ('Pacific/Palau', 'Pacific/Palau'),
> ('Pacific/Pitcairn', 'Pacific/Pitcairn'),
> ('Pacific/Pohnpei', 'Pacific/Pohnpei'),
> ('Pacific/Ponape', 'Pacific/Ponape'),
> ('Pacific/Port_Moresby', 'Pacific/Port_Moresby'),
> ('Pacific/Rarotonga', 'Pacific/Rarotonga'),
> ('Pacific/Saipan', 'Pacific/Saipan'),
> ('Pacific/Samoa', 'Pacific/Samoa'),
> ('Pacific/Tahiti', 'Pacific/Tahiti'),
> ('Pacific/Tarawa', 'Pacific/Tarawa'),
> ('Pacific/Tongatapu', 'Pacific/Tongatapu'),
> ('Pacific/Truk', 'Pacific/Truk'),
> ('Pacific/Wake', 'Pacific/Wake'),
> ('Pacific/Wallis', 'Pacific/Wallis'),
> ('Pacific/Yap', 'Pacific/Yap'),
> ('Poland', 'Poland'),
> ('Portugal', 'Portugal'),
> ('ROC', 'ROC'),
> ('ROK', 'ROK'),
> ('Singapore', 'Singapore'),
> ('Turkey', 'Turkey'),
> ('UCT', 'UCT'),
> ('US/Alaska', 'US/Alaska'),
> ('US/Aleutian', 'US/Aleutian'),
> ('US/Arizona', 'US/Arizona'),
> ('US/Central', 'US/Central'),
> ('US/East-Indiana', 'US/East-Indiana'),
> ('US/Eastern', 'US/Eastern'),
> ('US/Hawaii', 'US/Hawaii'),
> ('US/Indiana-Starke', 'US/Indiana-Starke'),
> ('US/Michigan', 'US/Michigan'),
> ('US/Mountain', 'US/Mountain'),
> ('US/Pacific', 'US/Pacific'),
> ('US/Pacific-New', 'US/Pacific-New'),
> ('US/Samoa', 'US/Samoa'),
> ('UTC', 'UTC'),
> ('Universal', 'Universal'),
> ('W-SU', 'W-SU'),
> ('WET', 'WET'),
> ('Zulu', 'Zulu')]
> FILE_UPLOAD_HANDLERS
> ('django.core.files.uploadhandler.MemoryFileUploadHandler',
> 'django.core.files.uploadhandler.TemporaryFileUploadHandler')
> DEFAULT_CONTENT_TYPE
> 'text/html'
> LEAFLET_CONFIG
> {'TILES_URL': 'http://{s}.tile2.opencyclemap.org/transport/{z}/{x}/{y}.png <http://tile2.opencyclemap.org/transport/%7Bz%7D/%7Bx%7D/%7By%7D.png>'}
> DEBUG_STATIC
> True
> TEST_RUNNER
> 'django_nose.NoseTestSuiteRunner'
> APPEND_SLASH
> True
> FIRST_DAY_OF_WEEK
> 0
> DATABASE_ROUTERS
> DEFAULT_MAP_ZOOM
> 0
> YEAR_MONTH_FORMAT
> 'F Y'
> STATICFILES_STORAGE
> 'django.contrib.staticfiles.storage.StaticFilesStorage'
> CACHES
> {'default': {'BACKEND': 'django.core.cache.backends.locmem.LocMemCache'}}
> SERVER_EMAIL
> 'root at localhost'
> SESSION_COOKIE_PATH
> USE_X_FORWARDED_HOST
> False
> ACCOUNT_OPEN_SIGNUP
> True
> CATALOGUE
> {'default': {'ENGINE': 'geonode.catalogue.backends.pycsw_local',
> 'URL': 'http://crisp.norminet.org.ph/catalogue/csw'}}
> FILE_UPLOAD_TEMP_DIR
> None
> MIDDLEWARE_CLASSES
> ('django.middleware.common.CommonMiddleware',
> 'django.contrib.sessions.middleware.SessionMiddleware',
> 'django.contrib.messages.middleware.MessageMiddleware',
> 'request.middleware.RequestMiddleware',
> 'django.middleware.locale.LocaleMiddleware',
> 'pagination.middleware.PaginationMiddleware',
> 'django.middleware.csrf.CsrfViewMiddleware',
> 'django.contrib.auth.middleware.AuthenticationMiddleware')
> USE_I18N
> True
> THOUSAND_SEPARATOR
> SECRET_KEY
> DB_DATASTORE_PORT
> LANGUAGE_COOKIE_NAME
> 'django_language'
> ACCOUNT_REMEMBER_ME_EXPIRY
> 315360000
> ACCOUNT_PASSWORD_CHANGE_REDIRECT_URL
> ACCOUNT_EMAIL_UNIQUE
> True
> TRANSACTIONS_MANAGED
> False
> LOGGING_CONFIG
> 'django.utils.log.dictConfig'
> TEMPLATE_LOADERS
> ('django.template.loaders.filesystem.Loader',
> 'django.template.loaders.app_directories.Loader')
> FORCE_SCRIPT_NAME
> None
> WSGI_APPLICATION
> None
> TEMPLATE_DEBUG
> True
> X_FRAME_OPTIONS
> 'SAMEORIGIN'
> AUTHENTICATION_BACKENDS
> ('geonode.security.auth.GranularBackend',)
> ACCOUNT_EMAIL_CONFIRMATION_EMAIL
> True
> ACCOUNT_LOGIN_REDIRECT_URL
> SIGNING_BACKEND
> 'django.core.signing.TimestampSigner'
> SESSION_COOKIE_SECURE
> False
> ACCOUNT_LOGIN_URL
> 'account_login'
> CSRF_COOKIE_DOMAIN
> None
> FILE_CHARSET
> 'utf-8'
> DEBUG
> True
> SESSION_FILE_PATH
> None
> DEFAULT_FILE_STORAGE
> 'django.core.files.storage.FileSystemStorage'
> INSTALLED_APPS
> ('django.contrib.auth',
> 'django.contrib.contenttypes',
> 'django.contrib.sessions',
> 'django.contrib.sites',
> 'django.contrib.admin',
> 'django.contrib.sitemaps',
> 'django.contrib.staticfiles',
> 'django.contrib.messages',
> 'django.contrib.humanize',
> 'pagination',
> 'taggit',
> 'taggit_templatetags',
> 'south',
> 'friendlytagloader',
> 'geoexplorer',
> 'request',
> 'pinax_theme_bootstrap_account',
> 'pinax_theme_bootstrap',
> 'django_forms_bootstrap',
> 'account',
> 'avatar',
> 'dialogos',
> 'agon_ratings',
> 'notification',
> 'announcements',
> 'actstream',
> 'relationships',
> 'user_messages',
> 'geonode.people',
> 'geonode.base',
> 'geonode.layers',
> 'geonode.upload',
> 'geonode.maps',
> 'geonode.proxy',
> 'geonode.security',
> 'geonode.search',
> 'geonode.catalogue',
> 'geonode.documents')
> LANGUAGES_BIDI
> ('he', 'ar', 'fa')
> USE_L10N
> False
> DATABASE_ENGINE
> 'postgresql_psycopg2'
> DB_DATASTORE_PASSWORD
> DATABASE_NAME
> 'geonode'
> PREPEND_WWW
> False
> SECURE_PROXY_SSL_HEADER
> None
> PASSWORD_RESET_TIMEOUT_DAYS
> ACCOUNT_PASSWORD_RESET_REDIRECT_URL
> SESSION_COOKIE_HTTPONLY
> True
> DATABASE_PORT
> '5432'
> DEBUG_PROPAGATE_EXCEPTIONS
> False
> MEDIA_URL
> '/uploaded/'
> MONTH_DAY_FORMAT
> 'F j'
> ACCOUNT_EMAIL_CONFIRMATION_ANONYMOUS_REDIRECT_URL
> 'account_login'
> LOGIN_URL
> '/account/login/'
> SESSION_EXPIRE_AT_BROWSER_CLOSE
> False
> SOUTH_TESTS_MIGRATE
> False
> SESSION_SAVE_EVERY_REQUEST
> False
> TIME_FORMAT
> 'P'
> AUTH_USER_MODEL
> 'auth.User'
> DATE_INPUT_FORMATS
> ('%Y-%m-%d',
> '%m/%d/%Y',
> '%m/%d/%y',
> '%b %d %Y',
> '%b %d, %Y',
> '%d %b %Y',
> '%d %b, %Y',
> '%B %d %Y',
> '%B %d, %Y',
> '%d %B %Y',
> '%d %B, %Y')
> ACCOUNT_LOGOUT_REDIRECT_URL
> DOCUMENTS_APP
> True
> EMAIL_HOST_PASSWORD
> AUTH_PROFILE_MODULE
> 'people.Profile'
> CACHE_MIDDLEWARE_ALIAS
> 'default'
> DB_DATASTORE_HOST
> NUMBER_GROUPING
> 0
> SHORT_DATETIME_FORMAT
> 'm/d/Y P'
> GEOSERVER_CREDENTIALS
> ('admin', 'geoserver')
> SESSION_ENGINE
> 'django.contrib.sessions.backends.db'
> ACCOUNT_DELETION_MARK_CALLBACK
> CSRF_COOKIE_PATH
> LOGIN_REDIRECT_URL
> ABSOLUTE_URL_OVERRIDES
> {'auth.user': <function get_user_url at 0x7f03647ab578>}
> PROJECT_ROOT
> '/usr/local/lib/python2.7/dist-packages/geonode'
> ACCOUNT_DELETION_EXPUNGE_HOURS
> 48
> GEONODE_ROOT
> DECIMAL_SEPARATOR
> CSRF_FAILURE_VIEW
> 'django.views.csrf.csrf_failure'
> CACHE_MIDDLEWARE_KEY_PREFIX
> NOSE_ARGS
> ['--nocapture', '--detailed-errors']
> LOCALE_PATHS
> ('/usr/local/lib/python2.7/dist-packages/geonode/locale',)
> TEMPLATE_STRING_IF_INVALID
> COMMENTS_ALLOW_PROFANITIES
> False
> LOGOUT_URL
> '/account/logout/'
> MAP_BASELAYERS
> [{'source': {'ptype': 'gxp_wmscsource',
> 'restUrl': '/gs/rest',
> 'url': 'http://crisp.norminet.org.ph/geoserver/wms'}},
> {'args': ['No background'],
> 'fixed': True,
> 'group': 'background',
> 'source': {'ptype': 'gxp_olsource'},
> 'type': 'OpenLayers.Layer',
> 'visibility': False},
> {'args': ['OpenStreetMap'],
> 'fixed': True,
> 'type': 'OpenLayers.Layer.OSM',
> {'group': 'background',
> 'name': 'osm',
> 'source': {'ptype': 'gxp_mapquestsource'},
> 'visibility': True},
> 'name': 'naip',
> {'fixed': True,
> 'name': 'AerialWithLabels',
> 'source': {'ptype': 'gxp_bingsource'},
> {'source': {'ptype': 'gxp_mapboxsource'}}]
> EMAIL_USE_TLS
> True
> ACCOUNT_LANGUAGES
> [('en', u'English'),
> ('es', u'espa\xf1ol'),
> ('it', u'italiano'),
> ('fr', u'fran\xe7ais'),
> ('de', u'Deutsch'),
> ('el', u'\u0395\u03bb\u03bb\u03b7\u03bd\u03b9\u03ba\u03ac'),
> ('id', u'Bahasa Indonesia'),
> ('ja', u'\u65e5\u672c\u8a9e')]
> FIXTURE_DIRS
> EMAIL_HOST
> 'smtp.gmail.com'
> DATE_FORMAT
> 'N j, Y'
> ACCOUNT_NOTIFY_ON_PASSWORD_CHANGE
> MEDIA_ROOT
> '/var/www/geonode/uploaded'
> AGON_RATINGS_CATEGORY_CHOICES
> {'layers.Layer': {'layer': 'How good is this layer?'},
> 'maps.Map': {'map': 'How good is this map?'}}
> DEFAULT_EXCEPTION_REPORTER_FILTER
> 'django.views.debug.SafeExceptionReporterFilter'
> ADMINS
> (('Jeff', 'jeffytoms at gmail.com'),)
> FORMAT_MODULE_PATH
> None
> DEFAULT_FROM_EMAIL
> STATICFILES_DIRS
> ['/etc/geonode/media', '/usr/local/lib/python2.7/dist-packages/geonode/static']
> GEOSERVER_URL
> DATETIME_FORMAT
> 'N j, Y, P'
> TEMPLATE_DIRS
> ('/etc/geonode/templates',
> '/usr/local/lib/python2.7/dist-packages/geonode/templates')
> ALLOWED_DOCUMENT_TYPES
> ['doc',
> 'docx',
> 'xls',
> 'xslx',
> 'pdf',
> 'zip',
> 'jpg',
> 'jpeg',
> 'tif',
> 'tiff',
> 'png',
> 'gif',
> 'txt']
> ACCOUNT_DELETION_EXPUNGE_CALLBACK
> SITE_ID
> 1
> DISALLOWED_USER_AGENTS
> ALLOWED_INCLUDE_ROOTS
> ACCOUNT_SETTINGS_REDIRECT_URL
> 'account_settings'
> SITEURL
> 'http://crisp.norminet.org.ph/'
> LOGGING
> {'disable_existing_loggers': True,
> 'filters': {'require_debug_false': {'()': 'django.utils.log.RequireDebugFalse'}},
> 'formatters': {'simple': {'format': '%(message)s'},
> 'verbose': {'format': '%(levelname)s %(asctime)s %(module)s %(process)d %(thread)d %(message)s'}},
> 'handlers': {'console': {'class': 'logging.StreamHandler',
> 'formatter': 'simple',
> 'level': 'ERROR'},
> 'mail_admins': {'class': 'django.utils.log.AdminEmailHandler',
> 'filters': ['require_debug_false'],
> 'level': 'ERROR'},
> 'null': {'class': 'django.utils.log.NullHandler',
> 'level': 'ERROR'}},
> 'loggers': {'django': {'handlers': ['console'], 'level': 'ERROR'},
> 'django.request': {'handlers': ['mail_admins'],
> 'level': 'ERROR',
> 'propagate': True},
> 'geonode': {'handlers': ['console'], 'level': 'ERROR'},
> 'gsconfig.catalog': {'handlers': ['console'], 'level': 'ERROR'},
> 'owslib': {'handlers': ['console'], 'level': 'ERROR'},
> 'pycsw': {'handlers': ['console'], 'level': 'ERROR'},
> 'south': {'handlers': ['console'], 'level': 'ERROR'}},
> 'version': 1}
> SHORT_DATE_FORMAT
> 'm/d/Y'
> DATABASE_USER
> 'geonode'
> DB_DATASTORE_DATABASE
> ACCOUNT_SIGNUP_REDIRECT_URL
> SITENAME
> 'GeoNode'
> IGNORABLE_404_URLS
> TIME_ZONE
> 'Asia/Manila'
> SOUTH_MIGRATION_MODULES
> {'avatar': 'geonode.migrations.avatar'}
> FILE_UPLOAD_MAX_MEMORY_SIZE
> 2621440
> DB_DATASTORE_TYPE
> EMAIL_BACKEND
> 'django.core.mail.backends.smtp.EmailBackend'
> DEFAULT_TABLESPACE
> TEMPLATE_CONTEXT_PROCESSORS
> ('django.contrib.auth.context_processors.auth',
> 'django.core.context_processors.debug',
> 'django.core.context_processors.i18n',
> 'django.core.context_processors.tz',
> 'django.core.context_processors.media',
> 'django.core.context_processors.static',
> 'django.core.context_processors.request',
> 'django.contrib.messages.context_processors.messages',
> 'account.context_processors.account',
> 'geonode.context_processors.resource_urls')
> SESSION_COOKIE_AGE
> 1209600
> SETTINGS_MODULE
> 'geonode.settings'
> USE_ETAGS
> False
> LANGUAGES
> (('en', 'English'),
> ('es', 'Espa\xc3\xb1ol'),
> ('it', 'Italiano'),
> ('fr', 'Fran\xc3\xa7ais'),
> ('de', 'Deutsch'),
> ('el', '\xce\x95\xce\xbb\xce\xbb\xce\xb7\xce\xbd\xce\xb9\xce\xba\xce\xac'),
> ('id', 'Bahasa Indonesia'),
> ('ja', '\xe6\x97\xa5\xe6\x9c\xac\xe4\xba\xba'))
> DEFAULT_INDEX_TABLESPACE
> INTERNAL_IPS
> STATIC_URL
> '/static/'
> EMAIL_PORT
> 587
> DEFAULT_TOPICCATEGORY
> 'location'
> USE_TZ
> False
> DEFAULT_SEARCH_SIZE
> 10
> PASSWORD_HASHERS
> ACTSTREAM_SETTINGS
> {'FETCH_RELATIONS': True,
> 'GFK_FETCH_DEPTH': 1,
> 'MODELS': ('auth.user', 'layers.layer', 'maps.map'),
> 'USE_JSONFIELD': True,
> 'USE_PREFETCH': True}
> CACHE_MIDDLEWARE_SECONDS
> 600
> ACCOUNT_CREATE_ON_SAVE
> True
> DATETIME_INPUT_FORMATS
> ('%Y-%m-%d %H:%M:%S',
> '%Y-%m-%d %H:%M:%S.%f',
> '%Y-%m-%d %H:%M',
> '%Y-%m-%d',
> '%m/%d/%Y %H:%M:%S',
> '%m/%d/%Y %H:%M:%S.%f',
> '%m/%d/%Y %H:%M',
> '%m/%d/%Y',
> '%m/%d/%y %H:%M:%S',
> '%m/%d/%y %H:%M:%S.%f',
> '%m/%d/%y %H:%M',
> '%m/%d/%y')
> ACCOUNT_EMAIL_CONFIRMATION_REQUIRED
> False
> DATABASE_PASSWORD
> PROFANITIES_LIST
> EMAIL_HOST_USER
> MAX_DOCUMENT_SIZE
> 10
> You're seeing this error because you have DEBUG = True in your Django
> settings file. Change that to False, and Django will display a standard
> 500 page.
> On Wed, Jul 1, 2015 at 7:10 PM, Simone Dalmasso <simone.dalmasso at gmail.com
> > wrote:
>> Hm sure that you didn't upgrade geonode at some point ? :)
>> anyway:
>> $ geonode syncdb
>> should fix it
>> 2015-07-01 11:55 GMT+02:00 Jeffy John Tomarong <jeffytoms at gmail.com>:
>>> That was really Simone! I applied everything there and it somehow
>>> started postgres..
>>> I also managed to finally execute the updateip command at last.
>>> However, I got a longer error (debug=true), and an error page if I
>>> access the site url.
>>> So here's the error (I hope you can bear with me):
>>> DatabaseError at /
>>> relation "request_request" does not exist
>>> LINE 1: INSERT INTO "request_request" ("response", "method", "path",...
>>> Request Method:GETRequest URL:http://localhost/Django Version:1.5.1Exception
>>> Type:DatabaseErrorException Value:
>>> Exception Location:/usr/lib/python2.7/dist-packages/django/db/backends/postgresql_psycopg2/base.py
>>> in execute, line 54Python Executable:/usr/bin/pythonPython Version:2.7.3Python
>>> Path:
>>> Server time:Wed, 1 Jul 2015 17:16:14 +0800
>>> Traceback Switch to copy-and-paste view <http://localhost/#>
>>> get_response
>>> 1.
>>> response = middleware_method(request, response)
>>> ▶ Local vars <http://localhost/#>
>>> - /usr/local/lib/python2.7/dist-packages/request/middleware.py in
>>> process_response
>>> 1.
>>> r.from_http_request(request, response)
>>> - /usr/local/lib/python2.7/dist-packages/request/models.py in
>>> from_http_request
>>> 1.
>>> self.save()
>>> - /usr/local/lib/python2.7/dist-packages/request/models.py in save
>>> 1.
>>> super(Request, self).save(*args, **kwargs)
>>> - /usr/lib/python2.7/dist-packages/django/db/models/base.py in save
>>> 1.
>>> force_update=force_update, update_fields=update_fields)
>>> save_base
>>> 1.
>>> result = manager._insert([self], fields=fields, return_id=update_pk, using=using, raw=raw)
>>> - /usr/lib/python2.7/dist-packages/django/db/models/manager.py in
>>> _insert
>>> 1.
>>> return insert_query(self.model, objs, fields, **kwargs)
>>> - /usr/lib/python2.7/dist-packages/django/db/models/query.py in
>>> insert_query
>>> 1.
>>> return query.get_compiler(using=using).execute_sql(return_id)
>>> - /usr/lib/python2.7/dist-packages/django/db/models/sql/compiler.py
>>> in execute_sql
>>> 1.
>>> cursor.execute(sql, params)
>>> - /usr/lib/python2.7/dist-packages/django/db/backends/util.py in
>>> execute
>>> 1.
>>> return self.cursor.execute(sql, params)
>>> in execute
>>> 1.
>>> six.reraise(utils.DatabaseError, utils.DatabaseError(*tuple(e.args)), sys.exc_info()[2])
>>> in execute
>>> 1.
>>> return self.cursor.execute(query, args)
>>> No GET data
>>> 'layer'
>>> FILES
>>> No FILES data
>>> 'h9otIWjzzJPpzTDjHy2TmpAwfLeBnRXT'
>>> '80'
>>> HTTP_COOKIE
>>> 'csrftoken=h9otIWjzzJPpzTDjHy2TmpAwfLeBnRXT'
>>> SERVER_SOFTWARE
>>> SCRIPT_NAME
>>> u''
>>> SERVER_SIGNATURE
>>> '<address>Apache/2.2.22 (Ubuntu) Server at localhost Port 80</address>\n'
>>> REQUEST_METHOD
>>> 'GET'
>>> PATH_INFO
>>> u'/'
>>> SERVER_PROTOCOL
>>> 'HTTP/1.1'
>>> QUERY_STRING
>>> HTTP_USER_AGENT
>>> HTTP_CONNECTION
>>> 'keep-alive'
>>> SERVER_NAME
>>> 'localhost'
>>> REMOTE_ADDR
>>> '127.0.0.1'
>>> 'wsgi-script'
>>> wsgi.url_scheme
>>> 'http'
>>> PATH_TRANSLATED
>>> SERVER_PORT
>>> '80'
>>> wsgi.multiprocess
>>> True
>>> '0'
>>> SERVER_ADDR
>>> '127.0.0.1'
>>> DOCUMENT_ROOT
>>> 'geonode'
>>> SCRIPT_FILENAME
>>> SERVER_ADMIN
>>> wsgi.input
>>> <mod_wsgi.Input object at 0x7fa31c5ab1b0>
>>> HTTP_HOST
>>> 'localhost'
>>> wsgi.multithread
>>> True
>>> 'application'
>>> HTTP_CACHE_CONTROL
>>> 'max-age=0'
>>> REQUEST_URI
>>> HTTP_ACCEPT
>>> wsgi.version
>>> (1, 1)
>>> GATEWAY_INTERFACE
>>> 'CGI/1.1'
>>> wsgi.run_once
>>> False
>>> wsgi.errors
>>> <mod_wsgi.Log object at 0x7fa31d89fc30>
>>> REMOTE_PORT
>>> '35077'
>>> 'en-US,en;q=0.8'
>>> mod_wsgi.version
>>> (3, 3)
>>> 'localhost|'
>>> '1'
>>> wsgi.file_wrapper
>>> CSRF_COOKIE
>>> u'h9otIWjzzJPpzTDjHy2TmpAwfLeBnRXT'
>>> 'gzip,deflate,sdch'
>>> STATIC_ROOT
>>> GOOGLE_API_KEY
>>> False
>>> CSRF_COOKIE_SECURE
>>> False
>>> LANGUAGE_CODE
>>> 'en'
>>> ROOT_URLCONF
>>> 'geonode.urls'
>>> MANAGERS
>>> DB_DATASTORE_NAME
>>> DEFAULT_CHARSET
>>> 'utf-8'
>>> PYCSW
>>> 'enabled': 'true',
>>> DEFAULT_MAP_CENTER
>>> (0, 0)
>>> 3
>>> DB_DATASTORE
>>> False
>>> None
>>> GEOSERVER_BASE_URL
>>> REGISTRATION_OPEN
>>> False
>>> ALLOWED_HOSTS
>>> OGC_SERVER
>>> 'USER': 'admin',
>>> MESSAGE_STORAGE
>>> DATABASE_HOST
>>> 'localhost'
>>> '[Django] '
>>> False
>>> STATICFILES_FINDERS
>>> SESSION_CACHE_ALIAS
>>> 'default'
>>> None
>>> SESSION_COOKIE_NAME
>>> 'sessionid'
>>> DB_DATASTORE_USER
>>> CSRF_COOKIE_NAME
>>> 'csrftoken'
>>> ADMIN_FOR
>>> TIME_INPUT_FORMATS
>>> DATABASES
>>> 'NAME': 'geonode',
>>> 'OPTIONS': {},
>>> 'PORT': '5432',
>>> 'TEST_NAME': None,
>>> 'USER': 'geonode'},
>>> 'NAME': 'geonode',
>>> 'OPTIONS': {},
>>> 'PORT': '5432',
>>> 'TEST_NAME': None,
>>> 'USER': 'geonode'}}
>>> None
>>> ACCOUNT_TIMEZONES
>>> ('CET', 'CET'),
>>> ('Cuba', 'Cuba'),
>>> ('EET', 'EET'),
>>> ('EST', 'EST'),
>>> ('Egypt', 'Egypt'),
>>> ('Eire', 'Eire'),
>>> ('GB', 'GB'),
>>> ('GMT', 'GMT'),
>>> ('GMT+0', 'GMT+0'),
>>> ('GMT-0', 'GMT-0'),
>>> ('GMT0', 'GMT0'),
>>> ('HST', 'HST'),
>>> ('Iran', 'Iran'),
>>> ('Japan', 'Japan'),
>>> ('Libya', 'Libya'),
>>> ('MET', 'MET'),
>>> ('MST', 'MST'),
>>> ('NZ', 'NZ'),
>>> ('PRC', 'PRC'),
>>> ('ROC', 'ROC'),
>>> ('ROK', 'ROK'),
>>> ('UCT', 'UCT'),
>>> ('UTC', 'UTC'),
>>> ('W-SU', 'W-SU'),
>>> ('WET', 'WET'),
>>> ('Zulu', 'Zulu')]
>>> 'text/html'
>>> LEAFLET_CONFIG
>>> DEBUG_STATIC
>>> True
>>> TEST_RUNNER
>>> APPEND_SLASH
>>> True
>>> FIRST_DAY_OF_WEEK
>>> 0
>>> DATABASE_ROUTERS
>>> DEFAULT_MAP_ZOOM
>>> 0
>>> YEAR_MONTH_FORMAT
>>> 'F Y'
>>> STATICFILES_STORAGE
>>> CACHES
>>> SERVER_EMAIL
>>> 'root at localhost'
>>> SESSION_COOKIE_PATH
>>> False
>>> ACCOUNT_OPEN_SIGNUP
>>> True
>>> CATALOGUE
>>> None
>>> MIDDLEWARE_CLASSES
>>> USE_I18N
>>> True
>>> THOUSAND_SEPARATOR
>>> SECRET_KEY
>>> DB_DATASTORE_PORT
>>> 'django_language'
>>> 315360000
>>> True
>>> False
>>> LOGGING_CONFIG
>>> TEMPLATE_LOADERS
>>> FORCE_SCRIPT_NAME
>>> None
>>> WSGI_APPLICATION
>>> None
>>> TEMPLATE_DEBUG
>>> True
>>> X_FRAME_OPTIONS
>>> 'SAMEORIGIN'
>>> True
>>> SIGNING_BACKEND
>>> False
>>> ACCOUNT_LOGIN_URL
>>> 'account_login'
>>> CSRF_COOKIE_DOMAIN
>>> None
>>> FILE_CHARSET
>>> 'utf-8'
>>> DEBUG
>>> True
>>> SESSION_FILE_PATH
>>> None
>>> INSTALLED_APPS
>>> 'pagination',
>>> 'taggit',
>>> 'south',
>>> 'geoexplorer',
>>> 'request',
>>> 'account',
>>> 'avatar',
>>> 'dialogos',
>>> 'agon_ratings',
>>> 'notification',
>>> 'announcements',
>>> 'actstream',
>>> 'relationships',
>>> 'user_messages',
>>> 'geonode.people',
>>> 'geonode.base',
>>> 'geonode.layers',
>>> 'geonode.upload',
>>> 'geonode.maps',
>>> 'geonode.proxy',
>>> 'geonode.security',
>>> 'geonode.search',
>>> LANGUAGES_BIDI
>>> ('he', 'ar', 'fa')
>>> USE_L10N
>>> False
>>> DATABASE_ENGINE
>>> DATABASE_NAME
>>> 'geonode'
>>> PREPEND_WWW
>>> False
>>> None
>>> True
>>> DATABASE_PORT
>>> '5432'
>>> False
>>> MEDIA_URL
>>> '/uploaded/'
>>> MONTH_DAY_FORMAT
>>> 'F j'
>>> 'account_login'
>>> LOGIN_URL
>>> '/account/login/'
>>> False
>>> SOUTH_TESTS_MIGRATE
>>> False
>>> False
>>> TIME_FORMAT
>>> 'P'
>>> AUTH_USER_MODEL
>>> 'auth.User'
>>> DATE_INPUT_FORMATS
>>> ('%Y-%m-%d',
>>> '%m/%d/%Y',
>>> '%m/%d/%y',
>>> '%b %d %Y',
>>> '%b %d, %Y',
>>> '%d %b %Y',
>>> '%d %b, %Y',
>>> '%B %d %Y',
>>> '%B %d, %Y',
>>> '%d %B %Y',
>>> '%d %B, %Y')
>>> DOCUMENTS_APP
>>> True
>>> EMAIL_HOST_PASSWORD
>>> AUTH_PROFILE_MODULE
>>> 'people.Profile'
>>> 'default'
>>> DB_DATASTORE_HOST
>>> NUMBER_GROUPING
>>> 0
>>> 'm/d/Y P'
>>> SESSION_ENGINE
>>> CSRF_COOKIE_PATH
>>> LOGIN_REDIRECT_URL
>>> {'auth.user': <function get_user_url at 0x7fa31c7ab5f0>}
>>> PROJECT_ROOT
>>> 48
>>> GEONODE_ROOT
>>> DECIMAL_SEPARATOR
>>> CSRF_FAILURE_VIEW
>>> NOSE_ARGS
>>> LOCALE_PATHS
>>> False
>>> LOGOUT_URL
>>> '/account/logout/'
>>> MAP_BASELAYERS
>>> 'fixed': True,
>>> 'fixed': True,
>>> 'name': 'osm',
>>> 'name': 'naip',
>>> {'fixed': True,
>>> EMAIL_USE_TLS
>>> True
>>> ACCOUNT_LANGUAGES
>>> ('de', u'Deutsch'),
>>> FIXTURE_DIRS
>>> EMAIL_HOST
>>> 'smtp.gmail.com'
>>> DATE_FORMAT
>>> 'N j, Y'
>>> MEDIA_ROOT
>>> ADMINS
>>> FORMAT_MODULE_PATH
>>> None
>>> DEFAULT_FROM_EMAIL
>>> STATICFILES_DIRS
>>> GEOSERVER_URL
>>> DATETIME_FORMAT
>>> 'N j, Y, P'
>>> TEMPLATE_DIRS
>>> ['doc',
>>> 'docx',
>>> 'xls',
>>> 'xslx',
>>> 'pdf',
>>> 'zip',
>>> 'jpg',
>>> 'jpeg',
>>> 'tif',
>>> 'tiff',
>>> 'png',
>>> 'gif',
>>> 'txt']
>>> SITE_ID
>>> 1
>>> 'account_settings'
>>> SITEURL
>>> LOGGING
>>> 'level': 'ERROR'},
>>> 'level': 'ERROR'},
>>> 'level': 'ERROR'}},
>>> 'level': 'ERROR',
>>> 'propagate': True},
>>> 'version': 1}
>>> SHORT_DATE_FORMAT
>>> 'm/d/Y'
>>> DATABASE_USER
>>> 'geonode'
>>> SITENAME
>>> 'GeoNode'
>>> IGNORABLE_404_URLS
>>> TIME_ZONE
>>> 'Asia/Manila'
>>> 2621440
>>> DB_DATASTORE_TYPE
>>> EMAIL_BACKEND
>>> DEFAULT_TABLESPACE
>>> SESSION_COOKIE_AGE
>>> 1209600
>>> SETTINGS_MODULE
>>> 'geonode.settings'
>>> USE_ETAGS
>>> False
>>> LANGUAGES
>>> (('en', 'English'),
>>> ('it', 'Italiano'),
>>> ('de', 'Deutsch'),
>>> INTERNAL_IPS
>>> STATIC_URL
>>> '/static/'
>>> EMAIL_PORT
>>> 587
>>> 'location'
>>> USE_TZ
>>> False
>>> DEFAULT_SEARCH_SIZE
>>> 10
>>> PASSWORD_HASHERS
>>> ACTSTREAM_SETTINGS
>>> 600
>>> True
>>> '%Y-%m-%d %H:%M',
>>> '%Y-%m-%d',
>>> '%m/%d/%Y %H:%M',
>>> '%m/%d/%Y',
>>> '%m/%d/%y %H:%M',
>>> '%m/%d/%y')
>>> False
>>> DATABASE_PASSWORD
>>> PROFANITIES_LIST
>>> EMAIL_HOST_USER
>>> MAX_DOCUMENT_SIZE
>>> 10
>>> 500 page.
>>> On Wed, Jul 1, 2015 at 4:50 PM, Jeffy John Tomarong <jeffytoms at gmail.com
>>> > wrote:
>>>> Restarting PostgreSQL 9.1 database server
>>>> * The PostgreSQL server failed to start. Please check the log
>>>> output:
>>>> 2015-07-01 16:49:11 PHT LOG: database system was interrupted; last
>>>> known up at 2015-05-27 23:25:59 PHT
>>>> 2015-07-01 16:49:11 PHT FATAL: could not open file
>>>> "/etc/ssl/certs/ssl-cert-snakeoil.pem": Permission denied
>>>> 2015-07-01 16:49:11 PHT LOG: startup process (PID 5730) exited with
>>>> exit code 1
>>>> 2015-07-01 16:49:11 PHT LOG: aborting startup due to startup process
>>>> failure
>>>> [fail]
>>>> On Wed, Jul 1, 2015 at 3:40 PM, Jeffy John Tomarong <
>>>> jeffytoms at gmail.com> wrote:
>>>>> /usr/lib/python2.7/dist-packages/django/conf/__init__.py:221:
>>>>> DeprecationWarning: You have no filters defined on the 'mail_admins'
>>>>> logging handler: adding implicit debug-false-only filter. See
>>>>> http://docs.djangoproject.com/en/dev/releases/1.4/#request-exceptions-are-now-always-logged
>>>>> DeprecationWarning)
>>>>> OperationalError: could not connect to server: Connection refused
>>>>> Is the server running on host "localhost" (127.0.0.1) and accepting
>>>>> TCP/IP connections on port 5432?
>>>>> On Wed, Jul 1, 2015 at 3:15 PM, Jeffy John Tomarong <
>>>>>> Replacing SITEURL in /etc/geonode/local_settings.py
>>>>>> Adding entry for local ip in
>>>>>> /usr/share/geoserver/data//printing/config.yaml
>>>>>> IP was already added to the printing whitelist.
>>>>>> Replacing ALLOWED_HOSTS in /etc/geonode/local_settings.py
>>>>>> * Restarting web server apache2
>>>>>> apache2: Could not reliably determine the server's fully
>>>>>> qualified domain name, using 127.0.1.1 for ServerName
>>>>>> ... waiting .apache2: Could not reliably determine the server's
>>>>>> fully qualified domain name, using 127.0.1.1 for ServerName
>>>>>> [ OK ]
>>>>>> DeprecationWarning)
>>>>>> Traceback (most recent call last):
>>>>>> File "/usr/bin/django-admin", line 5, in <module>
>>>>>> management.execute_from_command_line()
>>>>>> File
>>>>>> "/usr/lib/python2.7/dist-packages/django/core/management/__init__.py", line
>>>>>> 453, in execute_from_command_line
>>>>>> utility.execute()
>>>>>> File
>>>>>> 392, in execute
>>>>>> self.fetch_command(subcommand).run_from_argv(self.argv)
>>>>>> File
>>>>>> 272, in fetch_command
>>>>>> klass = load_command_class(app_name, subcommand)
>>>>>> File
>>>>>> 77, in load_command_class
>>>>>> module = import_module('%s.management.commands.%s' % (app_name,
>>>>>> name))
>>>>>> File "/usr/lib/python2.7/dist-packages/django/utils/importlib.py",
>>>>>> line 35, in import_module
>>>>>> __import__(name)
>>>>>> File
>>>>>> "/usr/local/lib/python2.7/dist-packages/geonode/layers/management/commands/updatelayers.py",
>>>>>> line 23, in <module>
>>>>>> from geonode.geoserver.helpers import gs_slurp
>>>>>> File
>>>>>> "/usr/local/lib/python2.7/dist-packages/geonode/geoserver/helpers.py", line
>>>>>> 31, in <module>
>>>>>> from geonode.utils import _user, _password, ogc_server_settings
>>>>>> File "/usr/local/lib/python2.7/dist-packages/geonode/utils.py",
>>>>>> line 36, in <module>
>>>>>> from geonode.security.enumerations import AUTHENTICATED_USERS,
>>>>>> ANONYMOUS_USERS, INVALID_PERMISSION_MESSAGE
>>>>>> File
>>>>>> "/usr/local/lib/python2.7/dist-packages/geonode/security/enumerations.py",
>>>>>> line 28, in <module>
>>>>>> ANONYMOUS_USERS: _('Anonymous Users'),
>>>>>> File
>>>>>> "/usr/lib/python2.7/dist-packages/django/utils/translation/__init__.py",
>>>>>> line 71, in ugettext
>>>>>> return _trans.ugettext(message)
>>>>>> File
>>>>>> "/usr/lib/python2.7/dist-packages/django/utils/translation/trans_real.py",
>>>>>> line 276, in ugettext
>>>>>> return do_translate(message, 'ugettext')
>>>>>> File
>>>>>> line 258, in do_translate
>>>>>> _default = translation(settings.LANGUAGE_CODE)
>>>>>> File
>>>>>> line 172, in translation
>>>>>> default_translation = _fetch(settings.LANGUAGE_CODE)
>>>>>> File
>>>>>> line 154, in _fetch
>>>>>> app = import_module(appname)
>>>>>> __import__(name)
>>>>>> ImportError: No module named relationships
>>>>>> jjqt at GeoNode:/usr/local/lib/python2.7/dist-packages/geonode$ sudo
>>>>>> pico local_settings.py
>>>>>> pico settings.py
>>>>>> pip install -e.
>>>>>> [sudo] password for jjqt:
>>>>>> --editable=. should be formatted with svn+URL, git+URL, hg+URL or
>>>>>> bzr+URL
>>>>>> Storing complete log in /home/jjqt/.pip/pip.log
>>>>>> geonode-updateip crisp.norminet.org.ph
>>>>>> [ OK ]
>>>>>> DeprecationWarning)
>>>>>> File
>>>>>> utility.execute()
>>>>>> File
>>>>>> 392, in execute
>>>>>> File
>>>>>> File
>>>>>> name))
>>>>>> __import__(name)
>>>>>> File
>>>>>> File
>>>>>> 31, in <module>
>>>>>> File
>>>>>> File
>>>>>> File
>>>>>> File
>>>>>> File
>>>>>> File
>>>>>> line 154, in _fetch
>>>>>> __import__(name)
>>>>>> jjqt at GeoNode:/usr/local/lib/python2.7/dist-packages/geonode$ pip
>>>>>> install relationships
>>>>>> Downloading/unpacking relationships
>>>>>> Exception:
>>>>>> File "/usr/lib/python2.7/dist-packages/pip/basecommand.py", line
>>>>>> 126, in main
>>>>>> self.run(options, args)
>>>>>> File "/usr/lib/python2.7/dist-packages/pip/commands/install.py",
>>>>>> line 223, in run
>>>>>> requirement_set.prepare_files(finder,
>>>>>> force_root_egg_info=self.bundle, bundle=self.bundle)
>>>>>> File "/usr/lib/python2.7/dist-packages/pip/req.py", line 942, in
>>>>>> prepare_files
>>>>>> location = req_to_install.build_location(self.build_dir, not
>>>>>> self.is_download)
>>>>>> File "/usr/lib/python2.7/dist-packages/pip/req.py", line 144, in
>>>>>> build_location
>>>>>> _make_build_dir(build_dir)
>>>>>> File "/usr/lib/python2.7/dist-packages/pip/req.py", line 1185, in
>>>>>> _make_build_dir
>>>>>> os.makedirs(build_dir)
>>>>>> File "/usr/lib/python2.7/os.py", line 157, in makedirs
>>>>>> mkdir(name, mode)
>>>>>> OSError: [Errno 13] Permission denied:
>>>>>> '/usr/local/lib/python2.7/dist-packages/geonode/build'
>>>>>> File "/usr/bin/pip", line 9, in <module>
>>>>>> load_entry_point('pip==1.0', 'console_scripts', 'pip')()
>>>>>> File "/usr/lib/python2.7/dist-packages/pip/__init__.py", line 116,
>>>>>> in main
>>>>>> return command.main(initial_args, args[1:], options)
>>>>>> 147, in main
>>>>>> log_fp = open_logfile(log_fn, 'w')
>>>>>> 176, in open_logfile
>>>>>> log_fp = open(filename, mode)
>>>>>> IOError: [Errno 13] Permission denied: '/home/jjqt/.pip/pip.log'
>>> On Wed, Jul 1, 2015 at 4:55 PM, Simone Dalmasso <
>>> simone.dalmasso at gmail.com> wrote:
>>>> Take a look at this thread if it helps
>>>> https://wiki.postgresql.org/wiki/May_2015_Fsync_Permissions_Bug
>>>> 2015-07-01 10:52 GMT+02:00 Jeffy John Tomarong <jeffytoms at gmail.com>:
>>>>> Hi Simone,
>>>>> I got this error when I restarted postgresql and it's quite persistent:
>>>>> output:
>>>>> exit code 1
>>>>> failure
>>>>> [fail]
>>>>> On Wed, Jul 1, 2015 at 4:11 PM, Simone Dalmasso <
>>>>>> There's no way to restore, but you can add back your db
>>>>>> configuration. Check whether the local_settings.py file contains the
>>>>>> correct db connection parameters and that postgres is up and running.
>>>>>> 2015-07-01 10:08 GMT+02:00 Jeffy John Tomarong <jeffytoms at gmail.com>:
>>>>>>> Nope we dont have a custom configuration. After I installed geonode,
>>>>>>> all I editted were on the ipaddress part or the site url. I did not touch
>>>>>>> the DB config in the local_settings.py ..
>>>>>>> Or is there a way to restore back the local_settings.py, say restore
>>>>>>> it back to two days ago? Because I'm afraid I might have overwritten the
>>>>>>> local_settings.py with the old backup file of local_settings.py the moment
>>>>>>> it got the internal server error..
>>>>>>> Thank you Simone!
>>>>>>> On Wed, Jul 1, 2015 at 3:54 PM, Simone Dalmasso <
>>>>>>>> That is because it can't connect to postgresql. Do you have some
>>>>>>>> kind of custom configuration?
>>>>>>>> That command uses /etc/geonode/local_settings.py to get the db
>>>>>>>> configuration
>>>>>>>> 2015-07-01 9:43 GMT+02:00 Jeffy John Tomarong <jeffytoms at gmail.com>
>>>>>>>>> Hi Simone,
>>>>>>>>> It did help! Thank you very much for your quick response.. I also
>>>>>>>>> did pip install django-request after that.
>>>>>>>>> However, when I issued updateip again, I got this:
>>>>>>>>> DeprecationWarning)
>>>>>>>>> Hmm.. ??
>>>>>>>>> On Wed, Jul 1, 2015 at 3:31 PM, Simone Dalmasso <
>>>>>>>>>> Hi, I see you are using geonode 2.0
>>>>>>>>>> the missing package should be django-relationships and since your
>>>>>>>>>> geonode is installed systemwide you have to use sudo so:
>>>>>>>>>> $ sudo pip install django-relationships
>>>>>>>>>> Hope this helps
>>>>>>>>>> 2015-07-01 9:23 GMT+02:00 Jeffy John Tomarong <
>>>>>>>>>>> Hi Good Fellas!
>>>>>>>>>>> Our GeoNode instance was running well in the previous months.
>>>>>>>>>>> But now, it got Internal Server Error 500.
>>>>>>>>>>> What I did was to update the IP of geonode (which is just the
>>>>>>>>>>> same anyway), and it caused me this error:I also tried "pip install
>>>>>>>>>>> relationship" since it displayed there "Error: No Module named
>>>>>>>>>>> relationships". But it caused another set of error. GeoNode has been
>>>>>>>>>>> running well in the last months, I do not know what happened.
>>>>>>>>>>> I need your help guys on this. I'm at the end of my wits.
>>>>>>>>>>> Will be very much appreciated. Thank you!
>>>>>>>>>>> Here's the error message:
>>>>>>>>>>> [ OK ]
>>>>>>>>>>> DeprecationWarning)
>>>>>>>>>>> File
>>>>>>>>>>> utility.execute()
>>>>>>>>>>> File
>>>>>>>>>>> 392, in execute
>>>>>>>>>>> File
>>>>>>>>>>> File
>>>>>>>>>>> (app_name, name))
>>>>>>>>>>> File
>>>>>>>>>>> "/usr/lib/python2.7/dist-packages/django/utils/importlib.py", line 35, in
>>>>>>>>>>> import_module
>>>>>>>>>>> __import__(name)
>>>>>>>>>>> File
>>>>>>>>>>> File
>>>>>>>>>>> 31, in <module>
>>>>>>>>>>> ogc_server_settings
>>>>>>>>>>> File
>>>>>>>>>>> "/usr/local/lib/python2.7/dist-packages/geonode/utils.py", line 36, in
>>>>>>>>>>> <module>
>>>>>>>>>>> AUTHENTICATED_USERS, ANONYMOUS_USERS, INVALID_PERMISSION_MESSAGE
>>>>>>>>>>> File
>>>>>>>>>>> File
>>>>>>>>>>> File
>>>>>>>>>>> File
>>>>>>>>>>> File
>>>>>>>>>>> File
>>>>>>>>>>> line 154, in _fetch
>>>>>>>>>>> File
>>>>>>>>>>> import_module
>>>>>>>>>>> __import__(name)
>>>>>>>>>>> sudo pico local_settings.py
>>>>>>>>>>> sudo pico settings.py
>>>>>>>>>>> sudo pip install -e.
>>>>>>>>>>> or bzr+URL
>>>>>>>>>>> sudo geonode-updateipcrisp.norminet.org.ph
>>>>>>>>>>> [ OK ]
>>>>>>>>>>> DeprecationWarning)
>>>>>>>>>>> File
>>>>>>>>>>> utility.execute()
>>>>>>>>>>> File
>>>>>>>>>>> 392, in execute
>>>>>>>>>>> File
>>>>>>>>>>> File
>>>>>>>>>>> (app_name, name))
>>>>>>>>>>> File
>>>>>>>>>>> import_module
>>>>>>>>>>> __import__(name)
>>>>>>>>>>> File
>>>>>>>>>>> File
>>>>>>>>>>> 31, in <module>
>>>>>>>>>>> ogc_server_settings
>>>>>>>>>>> File
>>>>>>>>>>> <module>
>>>>>>>>>>> File
>>>>>>>>>>> File
>>>>>>>>>>> File
>>>>>>>>>>> File
>>>>>>>>>>> File
>>>>>>>>>>> File
>>>>>>>>>>> line 154, in _fetch
>>>>>>>>>>> File
>>>>>>>>>>> import_module
>>>>>>>>>>> __import__(name)
>>>>>>>>>>> pip install relationships
>>>>>>>>>>> Exception:
>>>>>>>>>>> line 126, in main
>>>>>>>>>>> File
>>>>>>>>>>> "/usr/lib/python2.7/dist-packages/pip/commands/install.py", line 223, in run
>>>>>>>>>>> in prepare_files
>>>>>>>>>>> self.is_download)
>>>>>>>>>>> in build_location
>>>>>>>>>>> in _make_build_dir
>>>>>>>>>>> mkdir(name, mode)
>>>>>>>>>>> 116, in main
>>>>>>>>>>> line 147, in main
>>>>>>>>>>> line 176, in open_logfile
>>>>>>>>>>> _______________________________________________
>>>>>>>>>>> geonode-users mailing list
>>>>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
>>>>>>>>>> Simone
>>>>>>>> Simone
>>>>>> Simone
>>>> Simone
>> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150701/6552e2e2/attachment-0001.html>
More information about the geonode-users
