[GeoNode-users] GeoNode Updateip Error (No module named relationships)
Jeffy John Tomarong
jeffytoms at gmail.com
Wed Jul 1 22:39:39 PDT 2015
Thank you very much Simone! Your fixes were really effective..
The site can now be accessed, though the layer thumbnails are no longer
showing up.
Nevertheless, what's important is that the site is now up and running.
Thank you for your unswerving support! :) *thumbs up
On Wed, Jul 1, 2015 at 7:37 PM, Simone Dalmasso <simone.dalmasso at gmail.com>
wrote:
> Very strange,
> it's like you are missing some settings. You have to track down the errors
> until it's fixed, for now add
> CACHE_TIME = 0
> to your settings
> 2015-07-01 13:34 GMT+02:00 Jeffy John Tomarong <jeffytoms at gmail.com>:
>> Yeah I'm sure. I also didn't even update Ubuntu..
>> I was so excited to apply your fix. Unfortunately, it got this error
>> again :(
>> AttributeError at /
>> 'Settings' object has no attribute 'CACHE_TIME'
>> Request Method:GETRequest URL:http://crisp.norminet.org.ph/Django
>> Version:1.5.1Exception Type:AttributeErrorException Value:
>> Exception Location:/usr/local/lib/python2.7/dist-packages/geonode/search/views.py
>> in search_api, line 154Python Executable:/usr/bin/pythonPython Version:
>> 2.7.3Python Path:
>> ['/usr/lib/python2.7',
>> '/usr/lib/python2.7/plat-linux2',
>> '/usr/lib/python2.7/lib-tk',
>> '/usr/lib/python2.7/lib-old',
>> '/usr/lib/python2.7/lib-dynload',
>> '/usr/local/lib/python2.7/dist-packages',
>> '/usr/lib/python2.7/dist-packages',
>> '/usr/lib/python2.7/dist-packages/PIL',
>> '/usr/lib/python2.7/dist-packages/gtk-2.0',
>> '/usr/lib/pymodules/python2.7',
>> '/usr/lib/python2.7/dist-packages/ubuntu-sso-client']
>> Server time:Wed, 1 Jul 2015 19:31:12 +0800
>> Traceback Switch to copy-and-paste view <http://crisp.norminet.org.ph/#>
>> - /usr/lib/python2.7/dist-packages/django/core/handlers/base.py in
>> get_response
>> 1.
>> response = callback(request, *callback_args, **callback_kwargs)
>> ▶ Local vars <http://crisp.norminet.org.ph/#>
>> - /usr/local/lib/python2.7/dist-packages/geonode/views.py in index
>> 1.
>> return search_page(request, template=template)
>> - /usr/local/lib/python2.7/dist-packages/geonode/search/views.py in
>> search_page
>> 1.
>> results, facets, query = search_api(request, format='html', **kw)
>> search_api
>> 1.
>> raise ex
>> Request informationGET
>> No GET data
>> POSTVariableValuetype
>> 'layer'
>> FILES
>> No FILES data
>> COOKIESVariableValuecsrftoken
>> 'abqLWg61drnUTEdw7Z1ghbLxXka8QVu0'
>> METAVariableValuemod_wsgi.listener_port
>> '80'
>> HTTP_COOKIE
>> 'csrftoken=abqLWg61drnUTEdw7Z1ghbLxXka8QVu0'
>> mod_wsgi.listener_host
>> SERVER_SOFTWARE
>> 'Apache/2.2.22 (Ubuntu)'
>> SCRIPT_NAME
>> u''
>> mod_wsgi.handler_script
>> SERVER_SIGNATURE
>> '<address>Apache/2.2.22 (Ubuntu) Server at crisp.norminet.org.ph Port 80</address>\n'
>> REQUEST_METHOD
>> 'GET'
>> PATH_INFO
>> u'/'
>> SERVER_PROTOCOL
>> 'HTTP/1.1'
>> QUERY_STRING
>> HTTP_USER_AGENT
>> 'Mozilla/5.0 (X11; Linux x86_64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/35.0.1916.153 Safari/537.36'
>> HTTP_CONNECTION
>> 'keep-alive'
>> SERVER_NAME
>> 'crisp.norminet.org.ph'
>> REMOTE_ADDR
>> '121.97.223.10'
>> mod_wsgi.request_handler
>> 'wsgi-script'
>> wsgi.url_scheme
>> 'http'
>> PATH_TRANSLATED
>> '/var/www/geonode/wsgi/geonode.wsgi/'
>> SERVER_PORT
>> '80'
>> wsgi.multiprocess
>> True
>> mod_wsgi.input_chunked
>> '0'
>> SERVER_ADDR
>> '121.97.223.10'
>> DOCUMENT_ROOT
>> '/etc/apache2/htdocs'
>> mod_wsgi.process_group
>> 'geonode'
>> SCRIPT_FILENAME
>> '/var/www/geonode/wsgi/geonode.wsgi'
>> SERVER_ADMIN
>> 'webmaster at localhost'
>> wsgi.input
>> <mod_wsgi.Input object at 0x7f03645ab1b0>
>> HTTP_HOST
>> wsgi.multithread
>> True
>> mod_wsgi.callable_object
>> 'application'
>> HTTP_CACHE_CONTROL
>> 'max-age=0'
>> REQUEST_URI
>> HTTP_ACCEPT
>> 'text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,*/*;q=0.8'
>> wsgi.version
>> (1, 1)
>> GATEWAY_INTERFACE
>> 'CGI/1.1'
>> wsgi.run_once
>> False
>> wsgi.errors
>> <mod_wsgi.Log object at 0x7f0364773c30>
>> REMOTE_PORT
>> '40442'
>> HTTP_ACCEPT_LANGUAGE
>> 'en-US,en;q=0.8'
>> mod_wsgi.version
>> (3, 3)
>> mod_wsgi.application_group
>> 'localhost|'
>> mod_wsgi.script_reloading
>> '1'
>> wsgi.file_wrapper
>> CSRF_COOKIE
>> u'abqLWg61drnUTEdw7Z1ghbLxXka8QVu0'
>> HTTP_ACCEPT_ENCODING
>> 'gzip,deflate,sdch'
>> SettingsUsing settings module geonode.settingsSettingValue
>> ACCOUNT_USER_DISPLAY
>> STATIC_ROOT
>> '/var/www/geonode/static/'
>> GOOGLE_API_KEY
>> u'********************'
>> USE_THOUSAND_SEPARATOR
>> False
>> CSRF_COOKIE_SECURE
>> False
>> LANGUAGE_CODE
>> 'en'
>> ROOT_URLCONF
>> 'geonode.urls'
>> MANAGERS
>> DB_DATASTORE_NAME
>> DEFAULT_CHARSET
>> 'utf-8'
>> PYCSW
>> {'CONFIGURATION': {'metadata:inspire': {'conformity_service': 'notEvaluated',
>> 'contact_email': 'Email Address',
>> 'contact_name': 'Organization Name',
>> 'date': 'YYYY-MM-DD',
>> 'default_language': 'eng',
>> 'enabled': 'true',
>> 'gemet_keywords': 'Utility and governmental services',
>> 'languages_supported': 'eng,gre',
>> 'temp_extent': 'YYYY-MM-DD/YYYY-MM-DD'},
>> 'metadata:main': {'contact_address': 'Mailing Address',
>> 'contact_city': 'City',
>> 'contact_country': 'Country',
>> 'contact_fax': '+xx-xxx-xxx-xxxx',
>> 'contact_hours': 'Hours of Service',
>> 'contact_instructions': 'During hours of service. Off on weekends.',
>> 'contact_name': 'Lastname, Firstname',
>> 'contact_phone': '+xx-xxx-xxx-xxxx',
>> 'contact_position': 'Position Title',
>> 'contact_postalcode': 'Zip or Postal Code',
>> 'contact_role': 'pointOfContact',
>> 'contact_stateorprovince': 'Administrative Area',
>> 'contact_url': 'Contact URL',
>> 'identification_abstract': 'GeoNode is an open source platform that facilitates the creation, sharing, and collaborative use of geospatial data',
>> 'identification_accessconstraints': 'None',
>> 'identification_fees': 'None',
>> 'identification_keywords': 'sdi,catalogue,discovery,metadata,GeoNode',
>> 'identification_keywords_type': 'theme',
>> 'identification_title': 'GeoNode Catalogue',
>> 'provider_name': 'Organization Name',
>> 'provider_url': 'http://crisp.norminet.org.ph:8000/'}}}
>> DEFAULT_MAP_CENTER
>> (0, 0)
>> ACCOUNT_EMAIL_CONFIRMATION_EXPIRE_DAYS
>> 3
>> DB_DATASTORE
>> False
>> ACCOUNT_EMAIL_CONFIRMATION_AUTHENTICATED_REDIRECT_URL
>> None
>> GEOSERVER_BASE_URL
>> 'http://crisp.norminet.org.ph:8080/geoserver/'
>> REGISTRATION_OPEN
>> False
>> ALLOWED_HOSTS
>> ['crisp.norminet.org.ph', 'localhost']
>> OGC_SERVER
>> {'default': {'BACKEND': 'geonode.geoserver',
>> 'BACKEND_WRITE_ENABLED': True,
>> 'DATASTORE': 'datastore',
>> 'GEOGIT_DATASTORE_DIR': '',
>> 'GEOGIT_ENABLED': False,
>> 'GEONODE_SECURITY_ENABLED': True,
>> 'LOCATION': 'http://crisp.norminet.org.ph:8080/geoserver/',
>> 'MAPFISH_PRINT_ENABLED': True,
>> 'PASSWORD': u'********************',
>> 'PRINTING_ENABLED': True,
>> 'PRINTNG_ENABLED': True,
>> 'PUBLIC_LOCATION': 'http://crisp.norminet.org.ph/geoserver/',
>> 'USER': 'admin',
>> 'WMST_ENABLED': False,
>> 'WPS_ENABLED': False}}
>> MESSAGE_STORAGE
>> 'django.contrib.messages.storage.fallback.FallbackStorage'
>> DATABASE_HOST
>> 'localhost'
>> EMAIL_SUBJECT_PREFIX
>> '[Django] '
>> SEND_BROKEN_LINK_EMAILS
>> False
>> STATICFILES_FINDERS
>> ('django.contrib.staticfiles.finders.FileSystemFinder',
>> 'django.contrib.staticfiles.finders.AppDirectoriesFinder')
>> SESSION_CACHE_ALIAS
>> 'default'
>> SESSION_COOKIE_DOMAIN
>> None
>> SESSION_COOKIE_NAME
>> 'sessionid'
>> DB_DATASTORE_USER
>> CSRF_COOKIE_NAME
>> 'csrftoken'
>> ADMIN_FOR
>> TIME_INPUT_FORMATS
>> ('%H:%M:%S', '%H:%M')
>> DATABASES
>> {'datastore': {'ENGINE': 'django.contrib.gis.db.backends.postgis',
>> 'HOST': 'localhost',
>> 'NAME': 'geonode',
>> 'OPTIONS': {},
>> 'PORT': '5432',
>> 'TEST_CHARSET': None,
>> 'TEST_COLLATION': None,
>> 'TEST_MIRROR': None,
>> 'TEST_NAME': None,
>> 'TIME_ZONE': 'Asia/Manila',
>> 'USER': 'geonode'},
>> 'default': {'ENGINE': 'django.db.backends.postgresql_psycopg2',
>> 'NAME': 'geonode',
>> 'OPTIONS': {},
>> 'PORT': '5432',
>> 'TEST_NAME': None,
>> 'USER': 'geonode'}}
>> FILE_UPLOAD_PERMISSIONS
>> None
>> ACCOUNT_TIMEZONES
>> [('Africa/Abidjan', 'Africa/Abidjan'),
>> ('Africa/Accra', 'Africa/Accra'),
>> ('Africa/Addis_Ababa', 'Africa/Addis_Ababa'),
>> ('Africa/Algiers', 'Africa/Algiers'),
>> ('Africa/Asmara', 'Africa/Asmara'),
>> ('Africa/Asmera', 'Africa/Asmera'),
>> ('Africa/Bamako', 'Africa/Bamako'),
>> ('Africa/Bangui', 'Africa/Bangui'),
>> ('Africa/Banjul', 'Africa/Banjul'),
>> ('Africa/Bissau', 'Africa/Bissau'),
>> ('Africa/Blantyre', 'Africa/Blantyre'),
>> ('Africa/Brazzaville', 'Africa/Brazzaville'),
>> ('Africa/Bujumbura', 'Africa/Bujumbura'),
>> ('Africa/Cairo', 'Africa/Cairo'),
>> ('Africa/Casablanca', 'Africa/Casablanca'),
>> ('Africa/Ceuta', 'Africa/Ceuta'),
>> ('Africa/Conakry', 'Africa/Conakry'),
>> ('Africa/Dakar', 'Africa/Dakar'),
>> ('Africa/Dar_es_Salaam', 'Africa/Dar_es_Salaam'),
>> ('Africa/Djibouti', 'Africa/Djibouti'),
>> ('Africa/Douala', 'Africa/Douala'),
>> ('Africa/El_Aaiun', 'Africa/El_Aaiun'),
>> ('Africa/Freetown', 'Africa/Freetown'),
>> ('Africa/Gaborone', 'Africa/Gaborone'),
>> ('Africa/Harare', 'Africa/Harare'),
>> ('Africa/Johannesburg', 'Africa/Johannesburg'),
>> ('Africa/Kampala', 'Africa/Kampala'),
>> ('Africa/Khartoum', 'Africa/Khartoum'),
>> ('Africa/Kigali', 'Africa/Kigali'),
>> ('Africa/Kinshasa', 'Africa/Kinshasa'),
>> ('Africa/Lagos', 'Africa/Lagos'),
>> ('Africa/Libreville', 'Africa/Libreville'),
>> ('Africa/Lome', 'Africa/Lome'),
>> ('Africa/Luanda', 'Africa/Luanda'),
>> ('Africa/Lubumbashi', 'Africa/Lubumbashi'),
>> ('Africa/Lusaka', 'Africa/Lusaka'),
>> ('Africa/Malabo', 'Africa/Malabo'),
>> ('Africa/Maputo', 'Africa/Maputo'),
>> ('Africa/Maseru', 'Africa/Maseru'),
>> ('Africa/Mbabane', 'Africa/Mbabane'),
>> ('Africa/Mogadishu', 'Africa/Mogadishu'),
>> ('Africa/Monrovia', 'Africa/Monrovia'),
>> ('Africa/Nairobi', 'Africa/Nairobi'),
>> ('Africa/Ndjamena', 'Africa/Ndjamena'),
>> ('Africa/Niamey', 'Africa/Niamey'),
>> ('Africa/Nouakchott', 'Africa/Nouakchott'),
>> ('Africa/Ouagadougou', 'Africa/Ouagadougou'),
>> ('Africa/Porto-Novo', 'Africa/Porto-Novo'),
>> ('Africa/Sao_Tome', 'Africa/Sao_Tome'),
>> ('Africa/Timbuktu', 'Africa/Timbuktu'),
>> ('Africa/Tripoli', 'Africa/Tripoli'),
>> ('Africa/Tunis', 'Africa/Tunis'),
>> ('Africa/Windhoek', 'Africa/Windhoek'),
>> ('America/Adak', 'America/Adak'),
>> ('America/Anchorage', 'America/Anchorage'),
>> ('America/Anguilla', 'America/Anguilla'),
>> ('America/Antigua', 'America/Antigua'),
>> ('America/Araguaina', 'America/Araguaina'),
>> ('America/Argentina/Buenos_Aires', 'America/Argentina/Buenos_Aires'),
>> ('America/Argentina/Catamarca', 'America/Argentina/Catamarca'),
>> ('America/Argentina/ComodRivadavia', 'America/Argentina/ComodRivadavia'),
>> ('America/Argentina/Cordoba', 'America/Argentina/Cordoba'),
>> ('America/Argentina/Jujuy', 'America/Argentina/Jujuy'),
>> ('America/Argentina/La_Rioja', 'America/Argentina/La_Rioja'),
>> ('America/Argentina/Mendoza', 'America/Argentina/Mendoza'),
>> ('America/Argentina/Rio_Gallegos', 'America/Argentina/Rio_Gallegos'),
>> ('America/Argentina/Salta', 'America/Argentina/Salta'),
>> ('America/Argentina/San_Juan', 'America/Argentina/San_Juan'),
>> ('America/Argentina/San_Luis', 'America/Argentina/San_Luis'),
>> ('America/Argentina/Tucuman', 'America/Argentina/Tucuman'),
>> ('America/Argentina/Ushuaia', 'America/Argentina/Ushuaia'),
>> ('America/Aruba', 'America/Aruba'),
>> ('America/Asuncion', 'America/Asuncion'),
>> ('America/Atikokan', 'America/Atikokan'),
>> ('America/Atka', 'America/Atka'),
>> ('America/Bahia', 'America/Bahia'),
>> ('America/Bahia_Banderas', 'America/Bahia_Banderas'),
>> ('America/Barbados', 'America/Barbados'),
>> ('America/Belem', 'America/Belem'),
>> ('America/Belize', 'America/Belize'),
>> ('America/Blanc-Sablon', 'America/Blanc-Sablon'),
>> ('America/Boa_Vista', 'America/Boa_Vista'),
>> ('America/Bogota', 'America/Bogota'),
>> ('America/Boise', 'America/Boise'),
>> ('America/Buenos_Aires', 'America/Buenos_Aires'),
>> ('America/Cambridge_Bay', 'America/Cambridge_Bay'),
>> ('America/Campo_Grande', 'America/Campo_Grande'),
>> ('America/Cancun', 'America/Cancun'),
>> ('America/Caracas', 'America/Caracas'),
>> ('America/Catamarca', 'America/Catamarca'),
>> ('America/Cayenne', 'America/Cayenne'),
>> ('America/Cayman', 'America/Cayman'),
>> ('America/Chicago', 'America/Chicago'),
>> ('America/Chihuahua', 'America/Chihuahua'),
>> ('America/Coral_Harbour', 'America/Coral_Harbour'),
>> ('America/Cordoba', 'America/Cordoba'),
>> ('America/Costa_Rica', 'America/Costa_Rica'),
>> ('America/Cuiaba', 'America/Cuiaba'),
>> ('America/Curacao', 'America/Curacao'),
>> ('America/Danmarkshavn', 'America/Danmarkshavn'),
>> ('America/Dawson', 'America/Dawson'),
>> ('America/Dawson_Creek', 'America/Dawson_Creek'),
>> ('America/Denver', 'America/Denver'),
>> ('America/Detroit', 'America/Detroit'),
>> ('America/Dominica', 'America/Dominica'),
>> ('America/Edmonton', 'America/Edmonton'),
>> ('America/Eirunepe', 'America/Eirunepe'),
>> ('America/El_Salvador', 'America/El_Salvador'),
>> ('America/Ensenada', 'America/Ensenada'),
>> ('America/Fort_Wayne', 'America/Fort_Wayne'),
>> ('America/Fortaleza', 'America/Fortaleza'),
>> ('America/Glace_Bay', 'America/Glace_Bay'),
>> ('America/Godthab', 'America/Godthab'),
>> ('America/Goose_Bay', 'America/Goose_Bay'),
>> ('America/Grand_Turk', 'America/Grand_Turk'),
>> ('America/Grenada', 'America/Grenada'),
>> ('America/Guadeloupe', 'America/Guadeloupe'),
>> ('America/Guatemala', 'America/Guatemala'),
>> ('America/Guayaquil', 'America/Guayaquil'),
>> ('America/Guyana', 'America/Guyana'),
>> ('America/Halifax', 'America/Halifax'),
>> ('America/Havana', 'America/Havana'),
>> ('America/Hermosillo', 'America/Hermosillo'),
>> ('America/Indiana/Indianapolis', 'America/Indiana/Indianapolis'),
>> ('America/Indiana/Knox', 'America/Indiana/Knox'),
>> ('America/Indiana/Marengo', 'America/Indiana/Marengo'),
>> ('America/Indiana/Petersburg', 'America/Indiana/Petersburg'),
>> ('America/Indiana/Tell_City', 'America/Indiana/Tell_City'),
>> ('America/Indiana/Vevay', 'America/Indiana/Vevay'),
>> ('America/Indiana/Vincennes', 'America/Indiana/Vincennes'),
>> ('America/Indiana/Winamac', 'America/Indiana/Winamac'),
>> ('America/Indianapolis', 'America/Indianapolis'),
>> ('America/Inuvik', 'America/Inuvik'),
>> ('America/Iqaluit', 'America/Iqaluit'),
>> ('America/Jamaica', 'America/Jamaica'),
>> ('America/Jujuy', 'America/Jujuy'),
>> ('America/Juneau', 'America/Juneau'),
>> ('America/Kentucky/Louisville', 'America/Kentucky/Louisville'),
>> ('America/Kentucky/Monticello', 'America/Kentucky/Monticello'),
>> ('America/Knox_IN', 'America/Knox_IN'),
>> ('America/Kralendijk', 'America/Kralendijk'),
>> ('America/La_Paz', 'America/La_Paz'),
>> ('America/Lima', 'America/Lima'),
>> ('America/Los_Angeles', 'America/Los_Angeles'),
>> ('America/Louisville', 'America/Louisville'),
>> ('America/Lower_Princes', 'America/Lower_Princes'),
>> ('America/Maceio', 'America/Maceio'),
>> ('America/Managua', 'America/Managua'),
>> ('America/Manaus', 'America/Manaus'),
>> ('America/Marigot', 'America/Marigot'),
>> ('America/Martinique', 'America/Martinique'),
>> ('America/Matamoros', 'America/Matamoros'),
>> ('America/Mazatlan', 'America/Mazatlan'),
>> ('America/Mendoza', 'America/Mendoza'),
>> ('America/Menominee', 'America/Menominee'),
>> ('America/Merida', 'America/Merida'),
>> ('America/Metlakatla', 'America/Metlakatla'),
>> ('America/Mexico_City', 'America/Mexico_City'),
>> ('America/Miquelon', 'America/Miquelon'),
>> ('America/Moncton', 'America/Moncton'),
>> ('America/Monterrey', 'America/Monterrey'),
>> ('America/Montevideo', 'America/Montevideo'),
>> ('America/Montreal', 'America/Montreal'),
>> ('America/Montserrat', 'America/Montserrat'),
>> ('America/Nassau', 'America/Nassau'),
>> ('America/New_York', 'America/New_York'),
>> ('America/Nipigon', 'America/Nipigon'),
>> ('America/Nome', 'America/Nome'),
>> ('America/Noronha', 'America/Noronha'),
>> ('America/North_Dakota/Beulah', 'America/North_Dakota/Beulah'),
>> ('America/North_Dakota/Center', 'America/North_Dakota/Center'),
>> ('America/North_Dakota/New_Salem', 'America/North_Dakota/New_Salem'),
>> ('America/Ojinaga', 'America/Ojinaga'),
>> ('America/Panama', 'America/Panama'),
>> ('America/Pangnirtung', 'America/Pangnirtung'),
>> ('America/Paramaribo', 'America/Paramaribo'),
>> ('America/Phoenix', 'America/Phoenix'),
>> ('America/Port-au-Prince', 'America/Port-au-Prince'),
>> ('America/Port_of_Spain', 'America/Port_of_Spain'),
>> ('America/Porto_Acre', 'America/Porto_Acre'),
>> ('America/Porto_Velho', 'America/Porto_Velho'),
>> ('America/Puerto_Rico', 'America/Puerto_Rico'),
>> ('America/Rainy_River', 'America/Rainy_River'),
>> ('America/Rankin_Inlet', 'America/Rankin_Inlet'),
>> ('America/Recife', 'America/Recife'),
>> ('America/Regina', 'America/Regina'),
>> ('America/Resolute', 'America/Resolute'),
>> ('America/Rio_Branco', 'America/Rio_Branco'),
>> ('America/Rosario', 'America/Rosario'),
>> ('America/Santa_Isabel', 'America/Santa_Isabel'),
>> ('America/Santarem', 'America/Santarem'),
>> ('America/Santiago', 'America/Santiago'),
>> ('America/Santo_Domingo', 'America/Santo_Domingo'),
>> ('America/Sao_Paulo', 'America/Sao_Paulo'),
>> ('America/Scoresbysund', 'America/Scoresbysund'),
>> ('America/Shiprock', 'America/Shiprock'),
>> ('America/Sitka', 'America/Sitka'),
>> ('America/St_Barthelemy', 'America/St_Barthelemy'),
>> ('America/St_Johns', 'America/St_Johns'),
>> ('America/St_Kitts', 'America/St_Kitts'),
>> ('America/St_Lucia', 'America/St_Lucia'),
>> ('America/St_Thomas', 'America/St_Thomas'),
>> ('America/St_Vincent', 'America/St_Vincent'),
>> ('America/Swift_Current', 'America/Swift_Current'),
>> ('America/Tegucigalpa', 'America/Tegucigalpa'),
>> ('America/Thule', 'America/Thule'),
>> ('America/Thunder_Bay', 'America/Thunder_Bay'),
>> ('America/Tijuana', 'America/Tijuana'),
>> ('America/Toronto', 'America/Toronto'),
>> ('America/Tortola', 'America/Tortola'),
>> ('America/Vancouver', 'America/Vancouver'),
>> ('America/Virgin', 'America/Virgin'),
>> ('America/Whitehorse', 'America/Whitehorse'),
>> ('America/Winnipeg', 'America/Winnipeg'),
>> ('America/Yakutat', 'America/Yakutat'),
>> ('America/Yellowknife', 'America/Yellowknife'),
>> ('Antarctica/Casey', 'Antarctica/Casey'),
>> ('Antarctica/Davis', 'Antarctica/Davis'),
>> ('Antarctica/DumontDUrville', 'Antarctica/DumontDUrville'),
>> ('Antarctica/Macquarie', 'Antarctica/Macquarie'),
>> ('Antarctica/Mawson', 'Antarctica/Mawson'),
>> ('Antarctica/McMurdo', 'Antarctica/McMurdo'),
>> ('Antarctica/Palmer', 'Antarctica/Palmer'),
>> ('Antarctica/Rothera', 'Antarctica/Rothera'),
>> ('Antarctica/South_Pole', 'Antarctica/South_Pole'),
>> ('Antarctica/Syowa', 'Antarctica/Syowa'),
>> ('Antarctica/Vostok', 'Antarctica/Vostok'),
>> ('Arctic/Longyearbyen', 'Arctic/Longyearbyen'),
>> ('Asia/Aden', 'Asia/Aden'),
>> ('Asia/Almaty', 'Asia/Almaty'),
>> ('Asia/Amman', 'Asia/Amman'),
>> ('Asia/Anadyr', 'Asia/Anadyr'),
>> ('Asia/Aqtau', 'Asia/Aqtau'),
>> ('Asia/Aqtobe', 'Asia/Aqtobe'),
>> ('Asia/Ashgabat', 'Asia/Ashgabat'),
>> ('Asia/Ashkhabad', 'Asia/Ashkhabad'),
>> ('Asia/Baghdad', 'Asia/Baghdad'),
>> ('Asia/Bahrain', 'Asia/Bahrain'),
>> ('Asia/Baku', 'Asia/Baku'),
>> ('Asia/Bangkok', 'Asia/Bangkok'),
>> ('Asia/Beirut', 'Asia/Beirut'),
>> ('Asia/Bishkek', 'Asia/Bishkek'),
>> ('Asia/Brunei', 'Asia/Brunei'),
>> ('Asia/Calcutta', 'Asia/Calcutta'),
>> ('Asia/Choibalsan', 'Asia/Choibalsan'),
>> ('Asia/Chongqing', 'Asia/Chongqing'),
>> ('Asia/Chungking', 'Asia/Chungking'),
>> ('Asia/Colombo', 'Asia/Colombo'),
>> ('Asia/Dacca', 'Asia/Dacca'),
>> ('Asia/Damascus', 'Asia/Damascus'),
>> ('Asia/Dhaka', 'Asia/Dhaka'),
>> ('Asia/Dili', 'Asia/Dili'),
>> ('Asia/Dubai', 'Asia/Dubai'),
>> ('Asia/Dushanbe', 'Asia/Dushanbe'),
>> ('Asia/Gaza', 'Asia/Gaza'),
>> ('Asia/Harbin', 'Asia/Harbin'),
>> ('Asia/Ho_Chi_Minh', 'Asia/Ho_Chi_Minh'),
>> ('Asia/Hong_Kong', 'Asia/Hong_Kong'),
>> ('Asia/Hovd', 'Asia/Hovd'),
>> ('Asia/Irkutsk', 'Asia/Irkutsk'),
>> ('Asia/Istanbul', 'Asia/Istanbul'),
>> ('Asia/Jakarta', 'Asia/Jakarta'),
>> ('Asia/Jayapura', 'Asia/Jayapura'),
>> ('Asia/Jerusalem', 'Asia/Jerusalem'),
>> ('Asia/Kabul', 'Asia/Kabul'),
>> ('Asia/Kamchatka', 'Asia/Kamchatka'),
>> ('Asia/Karachi', 'Asia/Karachi'),
>> ('Asia/Kashgar', 'Asia/Kashgar'),
>> ('Asia/Kathmandu', 'Asia/Kathmandu'),
>> ('Asia/Katmandu', 'Asia/Katmandu'),
>> ('Asia/Kolkata', 'Asia/Kolkata'),
>> ('Asia/Krasnoyarsk', 'Asia/Krasnoyarsk'),
>> ('Asia/Kuala_Lumpur', 'Asia/Kuala_Lumpur'),
>> ('Asia/Kuching', 'Asia/Kuching'),
>> ('Asia/Kuwait', 'Asia/Kuwait'),
>> ('Asia/Macao', 'Asia/Macao'),
>> ('Asia/Macau', 'Asia/Macau'),
>> ('Asia/Magadan', 'Asia/Magadan'),
>> ('Asia/Makassar', 'Asia/Makassar'),
>> ('Asia/Manila', 'Asia/Manila'),
>> ('Asia/Muscat', 'Asia/Muscat'),
>> ('Asia/Nicosia', 'Asia/Nicosia'),
>> ('Asia/Novokuznetsk', 'Asia/Novokuznetsk'),
>> ('Asia/Novosibirsk', 'Asia/Novosibirsk'),
>> ('Asia/Omsk', 'Asia/Omsk'),
>> ('Asia/Oral', 'Asia/Oral'),
>> ('Asia/Phnom_Penh', 'Asia/Phnom_Penh'),
>> ('Asia/Pontianak', 'Asia/Pontianak'),
>> ('Asia/Pyongyang', 'Asia/Pyongyang'),
>> ('Asia/Qatar', 'Asia/Qatar'),
>> ('Asia/Qyzylorda', 'Asia/Qyzylorda'),
>> ('Asia/Rangoon', 'Asia/Rangoon'),
>> ('Asia/Riyadh', 'Asia/Riyadh'),
>> ('Asia/Saigon', 'Asia/Saigon'),
>> ('Asia/Sakhalin', 'Asia/Sakhalin'),
>> ('Asia/Samarkand', 'Asia/Samarkand'),
>> ('Asia/Seoul', 'Asia/Seoul'),
>> ('Asia/Shanghai', 'Asia/Shanghai'),
>> ('Asia/Singapore', 'Asia/Singapore'),
>> ('Asia/Taipei', 'Asia/Taipei'),
>> ('Asia/Tashkent', 'Asia/Tashkent'),
>> ('Asia/Tbilisi', 'Asia/Tbilisi'),
>> ('Asia/Tehran', 'Asia/Tehran'),
>> ('Asia/Tel_Aviv', 'Asia/Tel_Aviv'),
>> ('Asia/Thimbu', 'Asia/Thimbu'),
>> ('Asia/Thimphu', 'Asia/Thimphu'),
>> ('Asia/Tokyo', 'Asia/Tokyo'),
>> ('Asia/Ujung_Pandang', 'Asia/Ujung_Pandang'),
>> ('Asia/Ulaanbaatar', 'Asia/Ulaanbaatar'),
>> ('Asia/Ulan_Bator', 'Asia/Ulan_Bator'),
>> ('Asia/Urumqi', 'Asia/Urumqi'),
>> ('Asia/Vientiane', 'Asia/Vientiane'),
>> ('Asia/Vladivostok', 'Asia/Vladivostok'),
>> ('Asia/Yakutsk', 'Asia/Yakutsk'),
>> ('Asia/Yekaterinburg', 'Asia/Yekaterinburg'),
>> ('Asia/Yerevan', 'Asia/Yerevan'),
>> ('Atlantic/Azores', 'Atlantic/Azores'),
>> ('Atlantic/Bermuda', 'Atlantic/Bermuda'),
>> ('Atlantic/Canary', 'Atlantic/Canary'),
>> ('Atlantic/Cape_Verde', 'Atlantic/Cape_Verde'),
>> ('Atlantic/Faeroe', 'Atlantic/Faeroe'),
>> ('Atlantic/Faroe', 'Atlantic/Faroe'),
>> ('Atlantic/Jan_Mayen', 'Atlantic/Jan_Mayen'),
>> ('Atlantic/Madeira', 'Atlantic/Madeira'),
>> ('Atlantic/Reykjavik', 'Atlantic/Reykjavik'),
>> ('Atlantic/South_Georgia', 'Atlantic/South_Georgia'),
>> ('Atlantic/St_Helena', 'Atlantic/St_Helena'),
>> ('Atlantic/Stanley', 'Atlantic/Stanley'),
>> ('Australia/ACT', 'Australia/ACT'),
>> ('Australia/Adelaide', 'Australia/Adelaide'),
>> ('Australia/Brisbane', 'Australia/Brisbane'),
>> ('Australia/Broken_Hill', 'Australia/Broken_Hill'),
>> ('Australia/Canberra', 'Australia/Canberra'),
>> ('Australia/Currie', 'Australia/Currie'),
>> ('Australia/Darwin', 'Australia/Darwin'),
>> ('Australia/Eucla', 'Australia/Eucla'),
>> ('Australia/Hobart', 'Australia/Hobart'),
>> ('Australia/LHI', 'Australia/LHI'),
>> ('Australia/Lindeman', 'Australia/Lindeman'),
>> ('Australia/Lord_Howe', 'Australia/Lord_Howe'),
>> ('Australia/Melbourne', 'Australia/Melbourne'),
>> ('Australia/NSW', 'Australia/NSW'),
>> ('Australia/North', 'Australia/North'),
>> ('Australia/Perth', 'Australia/Perth'),
>> ('Australia/Queensland', 'Australia/Queensland'),
>> ('Australia/South', 'Australia/South'),
>> ('Australia/Sydney', 'Australia/Sydney'),
>> ('Australia/Tasmania', 'Australia/Tasmania'),
>> ('Australia/Victoria', 'Australia/Victoria'),
>> ('Australia/West', 'Australia/West'),
>> ('Australia/Yancowinna', 'Australia/Yancowinna'),
>> ('Brazil/Acre', 'Brazil/Acre'),
>> ('Brazil/DeNoronha', 'Brazil/DeNoronha'),
>> ('Brazil/East', 'Brazil/East'),
>> ('Brazil/West', 'Brazil/West'),
>> ('CET', 'CET'),
>> ('CST6CDT', 'CST6CDT'),
>> ('Canada/Atlantic', 'Canada/Atlantic'),
>> ('Canada/Central', 'Canada/Central'),
>> ('Canada/East-Saskatchewan', 'Canada/East-Saskatchewan'),
>> ('Canada/Eastern', 'Canada/Eastern'),
>> ('Canada/Mountain', 'Canada/Mountain'),
>> ('Canada/Newfoundland', 'Canada/Newfoundland'),
>> ('Canada/Pacific', 'Canada/Pacific'),
>> ('Canada/Saskatchewan', 'Canada/Saskatchewan'),
>> ('Canada/Yukon', 'Canada/Yukon'),
>> ('Chile/Continental', 'Chile/Continental'),
>> ('Chile/EasterIsland', 'Chile/EasterIsland'),
>> ('Cuba', 'Cuba'),
>> ('EET', 'EET'),
>> ('EST', 'EST'),
>> ('EST5EDT', 'EST5EDT'),
>> ('Egypt', 'Egypt'),
>> ('Eire', 'Eire'),
>> ('Etc/GMT', 'Etc/GMT'),
>> ('Etc/GMT+0', 'Etc/GMT+0'),
>> ('Etc/GMT+1', 'Etc/GMT+1'),
>> ('Etc/GMT+10', 'Etc/GMT+10'),
>> ('Etc/GMT+11', 'Etc/GMT+11'),
>> ('Etc/GMT+12', 'Etc/GMT+12'),
>> ('Etc/GMT+2', 'Etc/GMT+2'),
>> ('Etc/GMT+3', 'Etc/GMT+3'),
>> ('Etc/GMT+4', 'Etc/GMT+4'),
>> ('Etc/GMT+5', 'Etc/GMT+5'),
>> ('Etc/GMT+6', 'Etc/GMT+6'),
>> ('Etc/GMT+7', 'Etc/GMT+7'),
>> ('Etc/GMT+8', 'Etc/GMT+8'),
>> ('Etc/GMT+9', 'Etc/GMT+9'),
>> ('Etc/GMT-0', 'Etc/GMT-0'),
>> ('Etc/GMT-1', 'Etc/GMT-1'),
>> ('Etc/GMT-10', 'Etc/GMT-10'),
>> ('Etc/GMT-11', 'Etc/GMT-11'),
>> ('Etc/GMT-12', 'Etc/GMT-12'),
>> ('Etc/GMT-13', 'Etc/GMT-13'),
>> ('Etc/GMT-14', 'Etc/GMT-14'),
>> ('Etc/GMT-2', 'Etc/GMT-2'),
>> ('Etc/GMT-3', 'Etc/GMT-3'),
>> ('Etc/GMT-4', 'Etc/GMT-4'),
>> ('Etc/GMT-5', 'Etc/GMT-5'),
>> ('Etc/GMT-6', 'Etc/GMT-6'),
>> ('Etc/GMT-7', 'Etc/GMT-7'),
>> ('Etc/GMT-8', 'Etc/GMT-8'),
>> ('Etc/GMT-9', 'Etc/GMT-9'),
>> ('Etc/GMT0', 'Etc/GMT0'),
>> ('Etc/Greenwich', 'Etc/Greenwich'),
>> ('Etc/UCT', 'Etc/UCT'),
>> ('Etc/UTC', 'Etc/UTC'),
>> ('Etc/Universal', 'Etc/Universal'),
>> ('Etc/Zulu', 'Etc/Zulu'),
>> ('Europe/Amsterdam', 'Europe/Amsterdam'),
>> ('Europe/Andorra', 'Europe/Andorra'),
>> ('Europe/Athens', 'Europe/Athens'),
>> ('Europe/Belfast', 'Europe/Belfast'),
>> ('Europe/Belgrade', 'Europe/Belgrade'),
>> ('Europe/Berlin', 'Europe/Berlin'),
>> ('Europe/Bratislava', 'Europe/Bratislava'),
>> ('Europe/Brussels', 'Europe/Brussels'),
>> ('Europe/Bucharest', 'Europe/Bucharest'),
>> ('Europe/Budapest', 'Europe/Budapest'),
>> ('Europe/Chisinau', 'Europe/Chisinau'),
>> ('Europe/Copenhagen', 'Europe/Copenhagen'),
>> ('Europe/Dublin', 'Europe/Dublin'),
>> ('Europe/Gibraltar', 'Europe/Gibraltar'),
>> ('Europe/Guernsey', 'Europe/Guernsey'),
>> ('Europe/Helsinki', 'Europe/Helsinki'),
>> ('Europe/Isle_of_Man', 'Europe/Isle_of_Man'),
>> ('Europe/Istanbul', 'Europe/Istanbul'),
>> ('Europe/Jersey', 'Europe/Jersey'),
>> ('Europe/Kaliningrad', 'Europe/Kaliningrad'),
>> ('Europe/Kiev', 'Europe/Kiev'),
>> ('Europe/Lisbon', 'Europe/Lisbon'),
>> ('Europe/Ljubljana', 'Europe/Ljubljana'),
>> ('Europe/London', 'Europe/London'),
>> ('Europe/Luxembourg', 'Europe/Luxembourg'),
>> ('Europe/Madrid', 'Europe/Madrid'),
>> ('Europe/Malta', 'Europe/Malta'),
>> ('Europe/Mariehamn', 'Europe/Mariehamn'),
>> ('Europe/Minsk', 'Europe/Minsk'),
>> ('Europe/Monaco', 'Europe/Monaco'),
>> ('Europe/Moscow', 'Europe/Moscow'),
>> ('Europe/Nicosia', 'Europe/Nicosia'),
>> ('Europe/Oslo', 'Europe/Oslo'),
>> ('Europe/Paris', 'Europe/Paris'),
>> ('Europe/Podgorica', 'Europe/Podgorica'),
>> ('Europe/Prague', 'Europe/Prague'),
>> ('Europe/Riga', 'Europe/Riga'),
>> ('Europe/Rome', 'Europe/Rome'),
>> ('Europe/Samara', 'Europe/Samara'),
>> ('Europe/San_Marino', 'Europe/San_Marino'),
>> ('Europe/Sarajevo', 'Europe/Sarajevo'),
>> ('Europe/Simferopol', 'Europe/Simferopol'),
>> ('Europe/Skopje', 'Europe/Skopje'),
>> ('Europe/Sofia', 'Europe/Sofia'),
>> ('Europe/Stockholm', 'Europe/Stockholm'),
>> ('Europe/Tallinn', 'Europe/Tallinn'),
>> ('Europe/Tirane', 'Europe/Tirane'),
>> ('Europe/Tiraspol', 'Europe/Tiraspol'),
>> ('Europe/Uzhgorod', 'Europe/Uzhgorod'),
>> ('Europe/Vaduz', 'Europe/Vaduz'),
>> ('Europe/Vatican', 'Europe/Vatican'),
>> ('Europe/Vienna', 'Europe/Vienna'),
>> ('Europe/Vilnius', 'Europe/Vilnius'),
>> ('Europe/Volgograd', 'Europe/Volgograd'),
>> ('Europe/Warsaw', 'Europe/Warsaw'),
>> ('Europe/Zagreb', 'Europe/Zagreb'),
>> ('Europe/Zaporozhye', 'Europe/Zaporozhye'),
>> ('Europe/Zurich', 'Europe/Zurich'),
>> ('GB', 'GB'),
>> ('GB-Eire', 'GB-Eire'),
>> ('GMT', 'GMT'),
>> ('GMT+0', 'GMT+0'),
>> ('GMT-0', 'GMT-0'),
>> ('GMT0', 'GMT0'),
>> ('Greenwich', 'Greenwich'),
>> ('HST', 'HST'),
>> ('Hongkong', 'Hongkong'),
>> ('Iceland', 'Iceland'),
>> ('Indian/Antananarivo', 'Indian/Antananarivo'),
>> ('Indian/Chagos', 'Indian/Chagos'),
>> ('Indian/Christmas', 'Indian/Christmas'),
>> ('Indian/Cocos', 'Indian/Cocos'),
>> ('Indian/Comoro', 'Indian/Comoro'),
>> ('Indian/Kerguelen', 'Indian/Kerguelen'),
>> ('Indian/Mahe', 'Indian/Mahe'),
>> ('Indian/Maldives', 'Indian/Maldives'),
>> ('Indian/Mauritius', 'Indian/Mauritius'),
>> ('Indian/Mayotte', 'Indian/Mayotte'),
>> ('Indian/Reunion', 'Indian/Reunion'),
>> ('Iran', 'Iran'),
>> ('Israel', 'Israel'),
>> ('Jamaica', 'Jamaica'),
>> ('Japan', 'Japan'),
>> ('Kwajalein', 'Kwajalein'),
>> ('Libya', 'Libya'),
>> ('MET', 'MET'),
>> ('MST', 'MST'),
>> ('MST7MDT', 'MST7MDT'),
>> ('Mexico/BajaNorte', 'Mexico/BajaNorte'),
>> ('Mexico/BajaSur', 'Mexico/BajaSur'),
>> ('Mexico/General', 'Mexico/General'),
>> ('NZ', 'NZ'),
>> ('NZ-CHAT', 'NZ-CHAT'),
>> ('Navajo', 'Navajo'),
>> ('PRC', 'PRC'),
>> ('PST8PDT', 'PST8PDT'),
>> ('Pacific/Apia', 'Pacific/Apia'),
>> ('Pacific/Auckland', 'Pacific/Auckland'),
>> ('Pacific/Chatham', 'Pacific/Chatham'),
>> ('Pacific/Chuuk', 'Pacific/Chuuk'),
>> ('Pacific/Easter', 'Pacific/Easter'),
>> ('Pacific/Efate', 'Pacific/Efate'),
>> ('Pacific/Enderbury', 'Pacific/Enderbury'),
>> ('Pacific/Fakaofo', 'Pacific/Fakaofo'),
>> ('Pacific/Fiji', 'Pacific/Fiji'),
>> ('Pacific/Funafuti', 'Pacific/Funafuti'),
>> ('Pacific/Galapagos', 'Pacific/Galapagos'),
>> ('Pacific/Gambier', 'Pacific/Gambier'),
>> ('Pacific/Guadalcanal', 'Pacific/Guadalcanal'),
>> ('Pacific/Guam', 'Pacific/Guam'),
>> ('Pacific/Honolulu', 'Pacific/Honolulu'),
>> ('Pacific/Johnston', 'Pacific/Johnston'),
>> ('Pacific/Kiritimati', 'Pacific/Kiritimati'),
>> ('Pacific/Kosrae', 'Pacific/Kosrae'),
>> ('Pacific/Kwajalein', 'Pacific/Kwajalein'),
>> ('Pacific/Majuro', 'Pacific/Majuro'),
>> ('Pacific/Marquesas', 'Pacific/Marquesas'),
>> ('Pacific/Midway', 'Pacific/Midway'),
>> ('Pacific/Nauru', 'Pacific/Nauru'),
>> ('Pacific/Niue', 'Pacific/Niue'),
>> ('Pacific/Norfolk', 'Pacific/Norfolk'),
>> ('Pacific/Noumea', 'Pacific/Noumea'),
>> ('Pacific/Pago_Pago', 'Pacific/Pago_Pago'),
>> ('Pacific/Palau', 'Pacific/Palau'),
>> ('Pacific/Pitcairn', 'Pacific/Pitcairn'),
>> ('Pacific/Pohnpei', 'Pacific/Pohnpei'),
>> ('Pacific/Ponape', 'Pacific/Ponape'),
>> ('Pacific/Port_Moresby', 'Pacific/Port_Moresby'),
>> ('Pacific/Rarotonga', 'Pacific/Rarotonga'),
>> ('Pacific/Saipan', 'Pacific/Saipan'),
>> ('Pacific/Samoa', 'Pacific/Samoa'),
>> ('Pacific/Tahiti', 'Pacific/Tahiti'),
>> ('Pacific/Tarawa', 'Pacific/Tarawa'),
>> ('Pacific/Tongatapu', 'Pacific/Tongatapu'),
>> ('Pacific/Truk', 'Pacific/Truk'),
>> ('Pacific/Wake', 'Pacific/Wake'),
>> ('Pacific/Wallis', 'Pacific/Wallis'),
>> ('Pacific/Yap', 'Pacific/Yap'),
>> ('Poland', 'Poland'),
>> ('Portugal', 'Portugal'),
>> ('ROC', 'ROC'),
>> ('ROK', 'ROK'),
>> ('Singapore', 'Singapore'),
>> ('Turkey', 'Turkey'),
>> ('UCT', 'UCT'),
>> ('US/Alaska', 'US/Alaska'),
>> ('US/Aleutian', 'US/Aleutian'),
>> ('US/Arizona', 'US/Arizona'),
>> ('US/Central', 'US/Central'),
>> ('US/East-Indiana', 'US/East-Indiana'),
>> ('US/Eastern', 'US/Eastern'),
>> ('US/Hawaii', 'US/Hawaii'),
>> ('US/Indiana-Starke', 'US/Indiana-Starke'),
>> ('US/Michigan', 'US/Michigan'),
>> ('US/Mountain', 'US/Mountain'),
>> ('US/Pacific', 'US/Pacific'),
>> ('US/Pacific-New', 'US/Pacific-New'),
>> ('US/Samoa', 'US/Samoa'),
>> ('UTC', 'UTC'),
>> ('Universal', 'Universal'),
>> ('W-SU', 'W-SU'),
>> ('WET', 'WET'),
>> ('Zulu', 'Zulu')]
>> FILE_UPLOAD_HANDLERS
>> ('django.core.files.uploadhandler.MemoryFileUploadHandler',
>> 'django.core.files.uploadhandler.TemporaryFileUploadHandler')
>> DEFAULT_CONTENT_TYPE
>> 'text/html'
>> LEAFLET_CONFIG
>> {'TILES_URL': 'http://{s}.tile2.opencyclemap.org/transport/{z}/{x}/{y}.png <http://tile2.opencyclemap.org/transport/%7Bz%7D/%7Bx%7D/%7By%7D.png>'}
>> DEBUG_STATIC
>> True
>> TEST_RUNNER
>> 'django_nose.NoseTestSuiteRunner'
>> APPEND_SLASH
>> True
>> FIRST_DAY_OF_WEEK
>> 0
>> DATABASE_ROUTERS
>> DEFAULT_MAP_ZOOM
>> 0
>> YEAR_MONTH_FORMAT
>> 'F Y'
>> STATICFILES_STORAGE
>> 'django.contrib.staticfiles.storage.StaticFilesStorage'
>> CACHES
>> {'default': {'BACKEND': 'django.core.cache.backends.locmem.LocMemCache'}}
>> SERVER_EMAIL
>> 'root at localhost'
>> SESSION_COOKIE_PATH
>> USE_X_FORWARDED_HOST
>> False
>> ACCOUNT_OPEN_SIGNUP
>> True
>> CATALOGUE
>> {'default': {'ENGINE': 'geonode.catalogue.backends.pycsw_local',
>> 'URL': 'http://crisp.norminet.org.ph/catalogue/csw'}}
>> FILE_UPLOAD_TEMP_DIR
>> None
>> MIDDLEWARE_CLASSES
>> ('django.middleware.common.CommonMiddleware',
>> 'django.contrib.sessions.middleware.SessionMiddleware',
>> 'django.contrib.messages.middleware.MessageMiddleware',
>> 'request.middleware.RequestMiddleware',
>> 'django.middleware.locale.LocaleMiddleware',
>> 'pagination.middleware.PaginationMiddleware',
>> 'django.middleware.csrf.CsrfViewMiddleware',
>> 'django.contrib.auth.middleware.AuthenticationMiddleware')
>> USE_I18N
>> True
>> THOUSAND_SEPARATOR
>> SECRET_KEY
>> DB_DATASTORE_PORT
>> LANGUAGE_COOKIE_NAME
>> 'django_language'
>> ACCOUNT_REMEMBER_ME_EXPIRY
>> 315360000
>> ACCOUNT_PASSWORD_CHANGE_REDIRECT_URL
>> ACCOUNT_EMAIL_UNIQUE
>> True
>> TRANSACTIONS_MANAGED
>> False
>> LOGGING_CONFIG
>> 'django.utils.log.dictConfig'
>> TEMPLATE_LOADERS
>> ('django.template.loaders.filesystem.Loader',
>> 'django.template.loaders.app_directories.Loader')
>> FORCE_SCRIPT_NAME
>> None
>> WSGI_APPLICATION
>> None
>> TEMPLATE_DEBUG
>> True
>> X_FRAME_OPTIONS
>> 'SAMEORIGIN'
>> AUTHENTICATION_BACKENDS
>> ('geonode.security.auth.GranularBackend',)
>> ACCOUNT_EMAIL_CONFIRMATION_EMAIL
>> True
>> ACCOUNT_LOGIN_REDIRECT_URL
>> SIGNING_BACKEND
>> 'django.core.signing.TimestampSigner'
>> SESSION_COOKIE_SECURE
>> False
>> ACCOUNT_LOGIN_URL
>> 'account_login'
>> CSRF_COOKIE_DOMAIN
>> None
>> FILE_CHARSET
>> 'utf-8'
>> DEBUG
>> True
>> SESSION_FILE_PATH
>> None
>> DEFAULT_FILE_STORAGE
>> 'django.core.files.storage.FileSystemStorage'
>> INSTALLED_APPS
>> ('django.contrib.auth',
>> 'django.contrib.contenttypes',
>> 'django.contrib.sessions',
>> 'django.contrib.sites',
>> 'django.contrib.admin',
>> 'django.contrib.sitemaps',
>> 'django.contrib.staticfiles',
>> 'django.contrib.messages',
>> 'django.contrib.humanize',
>> 'pagination',
>> 'taggit',
>> 'taggit_templatetags',
>> 'south',
>> 'friendlytagloader',
>> 'geoexplorer',
>> 'request',
>> 'pinax_theme_bootstrap_account',
>> 'pinax_theme_bootstrap',
>> 'django_forms_bootstrap',
>> 'account',
>> 'avatar',
>> 'dialogos',
>> 'agon_ratings',
>> 'notification',
>> 'announcements',
>> 'actstream',
>> 'relationships',
>> 'user_messages',
>> 'geonode.people',
>> 'geonode.base',
>> 'geonode.layers',
>> 'geonode.upload',
>> 'geonode.maps',
>> 'geonode.proxy',
>> 'geonode.security',
>> 'geonode.search',
>> 'geonode.catalogue',
>> 'geonode.documents')
>> LANGUAGES_BIDI
>> ('he', 'ar', 'fa')
>> USE_L10N
>> False
>> DATABASE_ENGINE
>> 'postgresql_psycopg2'
>> DB_DATASTORE_PASSWORD
>> DATABASE_NAME
>> 'geonode'
>> PREPEND_WWW
>> False
>> SECURE_PROXY_SSL_HEADER
>> None
>> PASSWORD_RESET_TIMEOUT_DAYS
>> ACCOUNT_PASSWORD_RESET_REDIRECT_URL
>> SESSION_COOKIE_HTTPONLY
>> True
>> DATABASE_PORT
>> '5432'
>> DEBUG_PROPAGATE_EXCEPTIONS
>> False
>> MEDIA_URL
>> '/uploaded/'
>> MONTH_DAY_FORMAT
>> 'F j'
>> ACCOUNT_EMAIL_CONFIRMATION_ANONYMOUS_REDIRECT_URL
>> 'account_login'
>> LOGIN_URL
>> '/account/login/'
>> SESSION_EXPIRE_AT_BROWSER_CLOSE
>> False
>> SOUTH_TESTS_MIGRATE
>> False
>> SESSION_SAVE_EVERY_REQUEST
>> False
>> TIME_FORMAT
>> 'P'
>> AUTH_USER_MODEL
>> 'auth.User'
>> DATE_INPUT_FORMATS
>> ('%Y-%m-%d',
>> '%m/%d/%Y',
>> '%m/%d/%y',
>> '%b %d %Y',
>> '%b %d, %Y',
>> '%d %b %Y',
>> '%d %b, %Y',
>> '%B %d %Y',
>> '%B %d, %Y',
>> '%d %B %Y',
>> '%d %B, %Y')
>> ACCOUNT_LOGOUT_REDIRECT_URL
>> DOCUMENTS_APP
>> True
>> EMAIL_HOST_PASSWORD
>> AUTH_PROFILE_MODULE
>> 'people.Profile'
>> CACHE_MIDDLEWARE_ALIAS
>> 'default'
>> DB_DATASTORE_HOST
>> NUMBER_GROUPING
>> 0
>> SHORT_DATETIME_FORMAT
>> 'm/d/Y P'
>> GEOSERVER_CREDENTIALS
>> ('admin', 'geoserver')
>> SESSION_ENGINE
>> 'django.contrib.sessions.backends.db'
>> ACCOUNT_DELETION_MARK_CALLBACK
>> CSRF_COOKIE_PATH
>> LOGIN_REDIRECT_URL
>> ABSOLUTE_URL_OVERRIDES
>> {'auth.user': <function get_user_url at 0x7f03647ab578>}
>> PROJECT_ROOT
>> '/usr/local/lib/python2.7/dist-packages/geonode'
>> ACCOUNT_DELETION_EXPUNGE_HOURS
>> 48
>> GEONODE_ROOT
>> DECIMAL_SEPARATOR
>> CSRF_FAILURE_VIEW
>> 'django.views.csrf.csrf_failure'
>> CACHE_MIDDLEWARE_KEY_PREFIX
>> NOSE_ARGS
>> ['--nocapture', '--detailed-errors']
>> LOCALE_PATHS
>> ('/usr/local/lib/python2.7/dist-packages/geonode/locale',)
>> TEMPLATE_STRING_IF_INVALID
>> COMMENTS_ALLOW_PROFANITIES
>> False
>> LOGOUT_URL
>> '/account/logout/'
>> MAP_BASELAYERS
>> [{'source': {'ptype': 'gxp_wmscsource',
>> 'restUrl': '/gs/rest',
>> 'url': 'http://crisp.norminet.org.ph/geoserver/wms'}},
>> {'args': ['No background'],
>> 'fixed': True,
>> 'group': 'background',
>> 'source': {'ptype': 'gxp_olsource'},
>> 'type': 'OpenLayers.Layer',
>> 'visibility': False},
>> {'args': ['OpenStreetMap'],
>> 'fixed': True,
>> 'type': 'OpenLayers.Layer.OSM',
>> {'group': 'background',
>> 'name': 'osm',
>> 'source': {'ptype': 'gxp_mapquestsource'},
>> 'visibility': True},
>> 'name': 'naip',
>> {'fixed': True,
>> 'name': 'AerialWithLabels',
>> 'source': {'ptype': 'gxp_bingsource'},
>> {'source': {'ptype': 'gxp_mapboxsource'}}]
>> EMAIL_USE_TLS
>> True
>> ACCOUNT_LANGUAGES
>> [('en', u'English'),
>> ('es', u'espa\xf1ol'),
>> ('it', u'italiano'),
>> ('fr', u'fran\xe7ais'),
>> ('de', u'Deutsch'),
>> ('el', u'\u0395\u03bb\u03bb\u03b7\u03bd\u03b9\u03ba\u03ac'),
>> ('id', u'Bahasa Indonesia'),
>> ('ja', u'\u65e5\u672c\u8a9e')]
>> FIXTURE_DIRS
>> EMAIL_HOST
>> 'smtp.gmail.com'
>> DATE_FORMAT
>> 'N j, Y'
>> ACCOUNT_NOTIFY_ON_PASSWORD_CHANGE
>> MEDIA_ROOT
>> '/var/www/geonode/uploaded'
>> AGON_RATINGS_CATEGORY_CHOICES
>> {'layers.Layer': {'layer': 'How good is this layer?'},
>> 'maps.Map': {'map': 'How good is this map?'}}
>> DEFAULT_EXCEPTION_REPORTER_FILTER
>> 'django.views.debug.SafeExceptionReporterFilter'
>> ADMINS
>> (('Jeff', 'jeffytoms at gmail.com'),)
>> FORMAT_MODULE_PATH
>> None
>> DEFAULT_FROM_EMAIL
>> STATICFILES_DIRS
>> ['/etc/geonode/media', '/usr/local/lib/python2.7/dist-packages/geonode/static']
>> GEOSERVER_URL
>> DATETIME_FORMAT
>> 'N j, Y, P'
>> TEMPLATE_DIRS
>> ('/etc/geonode/templates',
>> '/usr/local/lib/python2.7/dist-packages/geonode/templates')
>> ALLOWED_DOCUMENT_TYPES
>> ['doc',
>> 'docx',
>> 'xls',
>> 'xslx',
>> 'pdf',
>> 'zip',
>> 'jpg',
>> 'jpeg',
>> 'tif',
>> 'tiff',
>> 'png',
>> 'gif',
>> 'txt']
>> ACCOUNT_DELETION_EXPUNGE_CALLBACK
>> SITE_ID
>> 1
>> DISALLOWED_USER_AGENTS
>> ALLOWED_INCLUDE_ROOTS
>> ACCOUNT_SETTINGS_REDIRECT_URL
>> 'account_settings'
>> SITEURL
>> 'http://crisp.norminet.org.ph/'
>> LOGGING
>> {'disable_existing_loggers': True,
>> 'filters': {'require_debug_false': {'()': 'django.utils.log.RequireDebugFalse'}},
>> 'formatters': {'simple': {'format': '%(message)s'},
>> 'verbose': {'format': '%(levelname)s %(asctime)s %(module)s %(process)d %(thread)d %(message)s'}},
>> 'handlers': {'console': {'class': 'logging.StreamHandler',
>> 'formatter': 'simple',
>> 'level': 'ERROR'},
>> 'mail_admins': {'class': 'django.utils.log.AdminEmailHandler',
>> 'filters': ['require_debug_false'],
>> 'level': 'ERROR'},
>> 'null': {'class': 'django.utils.log.NullHandler',
>> 'level': 'ERROR'}},
>> 'loggers': {'django': {'handlers': ['console'], 'level': 'ERROR'},
>> 'django.request': {'handlers': ['mail_admins'],
>> 'level': 'ERROR',
>> 'propagate': True},
>> 'geonode': {'handlers': ['console'], 'level': 'ERROR'},
>> 'gsconfig.catalog': {'handlers': ['console'], 'level': 'ERROR'},
>> 'owslib': {'handlers': ['console'], 'level': 'ERROR'},
>> 'pycsw': {'handlers': ['console'], 'level': 'ERROR'},
>> 'south': {'handlers': ['console'], 'level': 'ERROR'}},
>> 'version': 1}
>> SHORT_DATE_FORMAT
>> 'm/d/Y'
>> DATABASE_USER
>> 'geonode'
>> DB_DATASTORE_DATABASE
>> ACCOUNT_SIGNUP_REDIRECT_URL
>> SITENAME
>> 'GeoNode'
>> IGNORABLE_404_URLS
>> TIME_ZONE
>> 'Asia/Manila'
>> SOUTH_MIGRATION_MODULES
>> {'avatar': 'geonode.migrations.avatar'}
>> FILE_UPLOAD_MAX_MEMORY_SIZE
>> 2621440
>> DB_DATASTORE_TYPE
>> EMAIL_BACKEND
>> 'django.core.mail.backends.smtp.EmailBackend'
>> DEFAULT_TABLESPACE
>> TEMPLATE_CONTEXT_PROCESSORS
>> ('django.contrib.auth.context_processors.auth',
>> 'django.core.context_processors.debug',
>> 'django.core.context_processors.i18n',
>> 'django.core.context_processors.tz',
>> 'django.core.context_processors.media',
>> 'django.core.context_processors.static',
>> 'django.core.context_processors.request',
>> 'django.contrib.messages.context_processors.messages',
>> 'account.context_processors.account',
>> 'geonode.context_processors.resource_urls')
>> SESSION_COOKIE_AGE
>> 1209600
>> SETTINGS_MODULE
>> 'geonode.settings'
>> USE_ETAGS
>> False
>> LANGUAGES
>> (('en', 'English'),
>> ('es', 'Espa\xc3\xb1ol'),
>> ('it', 'Italiano'),
>> ('fr', 'Fran\xc3\xa7ais'),
>> ('de', 'Deutsch'),
>> ('el', '\xce\x95\xce\xbb\xce\xbb\xce\xb7\xce\xbd\xce\xb9\xce\xba\xce\xac'),
>> ('id', 'Bahasa Indonesia'),
>> ('ja', '\xe6\x97\xa5\xe6\x9c\xac\xe4\xba\xba'))
>> DEFAULT_INDEX_TABLESPACE
>> INTERNAL_IPS
>> STATIC_URL
>> '/static/'
>> EMAIL_PORT
>> 587
>> DEFAULT_TOPICCATEGORY
>> 'location'
>> USE_TZ
>> False
>> DEFAULT_SEARCH_SIZE
>> 10
>> PASSWORD_HASHERS
>> ACTSTREAM_SETTINGS
>> {'FETCH_RELATIONS': True,
>> 'GFK_FETCH_DEPTH': 1,
>> 'MODELS': ('auth.user', 'layers.layer', 'maps.map'),
>> 'USE_JSONFIELD': True,
>> 'USE_PREFETCH': True}
>> CACHE_MIDDLEWARE_SECONDS
>> 600
>> ACCOUNT_CREATE_ON_SAVE
>> True
>> DATETIME_INPUT_FORMATS
>> ('%Y-%m-%d %H:%M:%S',
>> '%Y-%m-%d %H:%M:%S.%f',
>> '%Y-%m-%d %H:%M',
>> '%Y-%m-%d',
>> '%m/%d/%Y %H:%M:%S',
>> '%m/%d/%Y %H:%M:%S.%f',
>> '%m/%d/%Y %H:%M',
>> '%m/%d/%Y',
>> '%m/%d/%y %H:%M:%S',
>> '%m/%d/%y %H:%M:%S.%f',
>> '%m/%d/%y %H:%M',
>> '%m/%d/%y')
>> ACCOUNT_EMAIL_CONFIRMATION_REQUIRED
>> False
>> DATABASE_PASSWORD
>> PROFANITIES_LIST
>> EMAIL_HOST_USER
>> MAX_DOCUMENT_SIZE
>> 10
>> You're seeing this error because you have DEBUG = True in your Django
>> settings file. Change that to False, and Django will display a standard
>> 500 page.
>> On Wed, Jul 1, 2015 at 7:10 PM, Simone Dalmasso <
>> simone.dalmasso at gmail.com> wrote:
>>> Hm sure that you didn't upgrade geonode at some point ? :)
>>> anyway:
>>> $ geonode syncdb
>>> should fix it
>>> 2015-07-01 11:55 GMT+02:00 Jeffy John Tomarong <jeffytoms at gmail.com>:
>>>> That was really Simone! I applied everything there and it somehow
>>>> started postgres..
>>>> I also managed to finally execute the updateip command at last.
>>>> However, I got a longer error (debug=true), and an error page if I
>>>> access the site url.
>>>> So here's the error (I hope you can bear with me):
>>>> DatabaseError at /
>>>> relation "request_request" does not exist
>>>> LINE 1: INSERT INTO "request_request" ("response", "method", "path",...
>>>> Request Method:GETRequest URL:http://localhost/Django Version:1.5.1Exception
>>>> Type:DatabaseErrorException Value:
>>>> Exception Location:/usr/lib/python2.7/dist-packages/django/db/backends/postgresql_psycopg2/base.py
>>>> in execute, line 54Python Executable:/usr/bin/pythonPython Version:
>>>> 2.7.3Python Path:
>>>> Server time:Wed, 1 Jul 2015 17:16:14 +0800
>>>> Traceback Switch to copy-and-paste view <http://localhost/#>
>>>> get_response
>>>> 1.
>>>> response = middleware_method(request, response)
>>>> ▶ Local vars <http://localhost/#>
>>>> - /usr/local/lib/python2.7/dist-packages/request/middleware.py in
>>>> process_response
>>>> 1.
>>>> r.from_http_request(request, response)
>>>> - /usr/local/lib/python2.7/dist-packages/request/models.py in
>>>> from_http_request
>>>> 1.
>>>> self.save()
>>>> - /usr/local/lib/python2.7/dist-packages/request/models.py in save
>>>> 1.
>>>> super(Request, self).save(*args, **kwargs)
>>>> - /usr/lib/python2.7/dist-packages/django/db/models/base.py in save
>>>> 1.
>>>> force_update=force_update, update_fields=update_fields)
>>>> save_base
>>>> 1.
>>>> result = manager._insert([self], fields=fields, return_id=update_pk, using=using, raw=raw)
>>>> - /usr/lib/python2.7/dist-packages/django/db/models/manager.py in
>>>> _insert
>>>> 1.
>>>> return insert_query(self.model, objs, fields, **kwargs)
>>>> - /usr/lib/python2.7/dist-packages/django/db/models/query.py in
>>>> insert_query
>>>> 1.
>>>> return query.get_compiler(using=using).execute_sql(return_id)
>>>> - /usr/lib/python2.7/dist-packages/django/db/models/sql/compiler.py
>>>> in execute_sql
>>>> 1.
>>>> cursor.execute(sql, params)
>>>> - /usr/lib/python2.7/dist-packages/django/db/backends/util.py in
>>>> execute
>>>> 1.
>>>> return self.cursor.execute(sql, params)
>>>> in execute
>>>> 1.
>>>> six.reraise(utils.DatabaseError, utils.DatabaseError(*tuple(e.args)), sys.exc_info()[2])
>>>> in execute
>>>> 1.
>>>> return self.cursor.execute(query, args)
>>>> No GET data
>>>> 'layer'
>>>> FILES
>>>> No FILES data
>>>> 'h9otIWjzzJPpzTDjHy2TmpAwfLeBnRXT'
>>>> '80'
>>>> HTTP_COOKIE
>>>> 'csrftoken=h9otIWjzzJPpzTDjHy2TmpAwfLeBnRXT'
>>>> SERVER_SOFTWARE
>>>> SCRIPT_NAME
>>>> u''
>>>> SERVER_SIGNATURE
>>>> '<address>Apache/2.2.22 (Ubuntu) Server at localhost Port 80</address>\n'
>>>> REQUEST_METHOD
>>>> 'GET'
>>>> PATH_INFO
>>>> u'/'
>>>> SERVER_PROTOCOL
>>>> 'HTTP/1.1'
>>>> QUERY_STRING
>>>> HTTP_USER_AGENT
>>>> HTTP_CONNECTION
>>>> 'keep-alive'
>>>> SERVER_NAME
>>>> 'localhost'
>>>> REMOTE_ADDR
>>>> '127.0.0.1'
>>>> 'wsgi-script'
>>>> wsgi.url_scheme
>>>> 'http'
>>>> PATH_TRANSLATED
>>>> SERVER_PORT
>>>> '80'
>>>> wsgi.multiprocess
>>>> True
>>>> '0'
>>>> SERVER_ADDR
>>>> '127.0.0.1'
>>>> DOCUMENT_ROOT
>>>> 'geonode'
>>>> SCRIPT_FILENAME
>>>> SERVER_ADMIN
>>>> wsgi.input
>>>> <mod_wsgi.Input object at 0x7fa31c5ab1b0>
>>>> HTTP_HOST
>>>> 'localhost'
>>>> wsgi.multithread
>>>> True
>>>> 'application'
>>>> HTTP_CACHE_CONTROL
>>>> 'max-age=0'
>>>> REQUEST_URI
>>>> HTTP_ACCEPT
>>>> wsgi.version
>>>> (1, 1)
>>>> GATEWAY_INTERFACE
>>>> 'CGI/1.1'
>>>> wsgi.run_once
>>>> False
>>>> wsgi.errors
>>>> <mod_wsgi.Log object at 0x7fa31d89fc30>
>>>> REMOTE_PORT
>>>> '35077'
>>>> 'en-US,en;q=0.8'
>>>> mod_wsgi.version
>>>> (3, 3)
>>>> 'localhost|'
>>>> '1'
>>>> wsgi.file_wrapper
>>>> CSRF_COOKIE
>>>> u'h9otIWjzzJPpzTDjHy2TmpAwfLeBnRXT'
>>>> 'gzip,deflate,sdch'
>>>> STATIC_ROOT
>>>> GOOGLE_API_KEY
>>>> False
>>>> CSRF_COOKIE_SECURE
>>>> False
>>>> LANGUAGE_CODE
>>>> 'en'
>>>> ROOT_URLCONF
>>>> 'geonode.urls'
>>>> MANAGERS
>>>> DB_DATASTORE_NAME
>>>> DEFAULT_CHARSET
>>>> 'utf-8'
>>>> PYCSW
>>>> 'enabled': 'true',
>>>> DEFAULT_MAP_CENTER
>>>> (0, 0)
>>>> 3
>>>> DB_DATASTORE
>>>> False
>>>> None
>>>> GEOSERVER_BASE_URL
>>>> REGISTRATION_OPEN
>>>> False
>>>> ALLOWED_HOSTS
>>>> OGC_SERVER
>>>> 'USER': 'admin',
>>>> MESSAGE_STORAGE
>>>> DATABASE_HOST
>>>> 'localhost'
>>>> '[Django] '
>>>> False
>>>> STATICFILES_FINDERS
>>>> SESSION_CACHE_ALIAS
>>>> 'default'
>>>> None
>>>> SESSION_COOKIE_NAME
>>>> 'sessionid'
>>>> DB_DATASTORE_USER
>>>> CSRF_COOKIE_NAME
>>>> 'csrftoken'
>>>> ADMIN_FOR
>>>> TIME_INPUT_FORMATS
>>>> DATABASES
>>>> 'NAME': 'geonode',
>>>> 'OPTIONS': {},
>>>> 'PORT': '5432',
>>>> 'TEST_NAME': None,
>>>> 'USER': 'geonode'},
>>>> 'NAME': 'geonode',
>>>> 'OPTIONS': {},
>>>> 'PORT': '5432',
>>>> 'TEST_NAME': None,
>>>> 'USER': 'geonode'}}
>>>> None
>>>> ACCOUNT_TIMEZONES
>>>> ('CET', 'CET'),
>>>> ('Cuba', 'Cuba'),
>>>> ('EET', 'EET'),
>>>> ('EST', 'EST'),
>>>> ('Egypt', 'Egypt'),
>>>> ('Eire', 'Eire'),
>>>> ('GB', 'GB'),
>>>> ('GMT', 'GMT'),
>>>> ('GMT+0', 'GMT+0'),
>>>> ('GMT-0', 'GMT-0'),
>>>> ('GMT0', 'GMT0'),
>>>> ('HST', 'HST'),
>>>> ('Iran', 'Iran'),
>>>> ('Japan', 'Japan'),
>>>> ('Libya', 'Libya'),
>>>> ('MET', 'MET'),
>>>> ('MST', 'MST'),
>>>> ('NZ', 'NZ'),
>>>> ('PRC', 'PRC'),
>>>> ('ROC', 'ROC'),
>>>> ('ROK', 'ROK'),
>>>> ('UCT', 'UCT'),
>>>> ('UTC', 'UTC'),
>>>> ('W-SU', 'W-SU'),
>>>> ('WET', 'WET'),
>>>> ('Zulu', 'Zulu')]
>>>> 'text/html'
>>>> LEAFLET_CONFIG
>>>> DEBUG_STATIC
>>>> True
>>>> TEST_RUNNER
>>>> APPEND_SLASH
>>>> True
>>>> FIRST_DAY_OF_WEEK
>>>> 0
>>>> DATABASE_ROUTERS
>>>> DEFAULT_MAP_ZOOM
>>>> 0
>>>> YEAR_MONTH_FORMAT
>>>> 'F Y'
>>>> STATICFILES_STORAGE
>>>> CACHES
>>>> SERVER_EMAIL
>>>> 'root at localhost'
>>>> SESSION_COOKIE_PATH
>>>> False
>>>> ACCOUNT_OPEN_SIGNUP
>>>> True
>>>> CATALOGUE
>>>> None
>>>> MIDDLEWARE_CLASSES
>>>> USE_I18N
>>>> True
>>>> THOUSAND_SEPARATOR
>>>> SECRET_KEY
>>>> DB_DATASTORE_PORT
>>>> 'django_language'
>>>> 315360000
>>>> True
>>>> False
>>>> LOGGING_CONFIG
>>>> TEMPLATE_LOADERS
>>>> FORCE_SCRIPT_NAME
>>>> None
>>>> WSGI_APPLICATION
>>>> None
>>>> TEMPLATE_DEBUG
>>>> True
>>>> X_FRAME_OPTIONS
>>>> 'SAMEORIGIN'
>>>> True
>>>> SIGNING_BACKEND
>>>> False
>>>> ACCOUNT_LOGIN_URL
>>>> 'account_login'
>>>> CSRF_COOKIE_DOMAIN
>>>> None
>>>> FILE_CHARSET
>>>> 'utf-8'
>>>> DEBUG
>>>> True
>>>> SESSION_FILE_PATH
>>>> None
>>>> INSTALLED_APPS
>>>> 'pagination',
>>>> 'taggit',
>>>> 'south',
>>>> 'geoexplorer',
>>>> 'request',
>>>> 'account',
>>>> 'avatar',
>>>> 'dialogos',
>>>> 'agon_ratings',
>>>> 'notification',
>>>> 'announcements',
>>>> 'actstream',
>>>> 'relationships',
>>>> 'user_messages',
>>>> 'geonode.people',
>>>> 'geonode.base',
>>>> 'geonode.layers',
>>>> 'geonode.upload',
>>>> 'geonode.maps',
>>>> 'geonode.proxy',
>>>> 'geonode.security',
>>>> 'geonode.search',
>>>> LANGUAGES_BIDI
>>>> ('he', 'ar', 'fa')
>>>> USE_L10N
>>>> False
>>>> DATABASE_ENGINE
>>>> DATABASE_NAME
>>>> 'geonode'
>>>> PREPEND_WWW
>>>> False
>>>> None
>>>> True
>>>> DATABASE_PORT
>>>> '5432'
>>>> False
>>>> MEDIA_URL
>>>> '/uploaded/'
>>>> MONTH_DAY_FORMAT
>>>> 'F j'
>>>> 'account_login'
>>>> LOGIN_URL
>>>> '/account/login/'
>>>> False
>>>> SOUTH_TESTS_MIGRATE
>>>> False
>>>> False
>>>> TIME_FORMAT
>>>> 'P'
>>>> AUTH_USER_MODEL
>>>> 'auth.User'
>>>> DATE_INPUT_FORMATS
>>>> ('%Y-%m-%d',
>>>> '%m/%d/%Y',
>>>> '%m/%d/%y',
>>>> '%b %d %Y',
>>>> '%b %d, %Y',
>>>> '%d %b %Y',
>>>> '%d %b, %Y',
>>>> '%B %d %Y',
>>>> '%B %d, %Y',
>>>> '%d %B %Y',
>>>> '%d %B, %Y')
>>>> DOCUMENTS_APP
>>>> True
>>>> EMAIL_HOST_PASSWORD
>>>> AUTH_PROFILE_MODULE
>>>> 'people.Profile'
>>>> 'default'
>>>> DB_DATASTORE_HOST
>>>> NUMBER_GROUPING
>>>> 0
>>>> 'm/d/Y P'
>>>> SESSION_ENGINE
>>>> CSRF_COOKIE_PATH
>>>> LOGIN_REDIRECT_URL
>>>> {'auth.user': <function get_user_url at 0x7fa31c7ab5f0>}
>>>> PROJECT_ROOT
>>>> 48
>>>> GEONODE_ROOT
>>>> DECIMAL_SEPARATOR
>>>> CSRF_FAILURE_VIEW
>>>> NOSE_ARGS
>>>> LOCALE_PATHS
>>>> False
>>>> LOGOUT_URL
>>>> '/account/logout/'
>>>> MAP_BASELAYERS
>>>> 'fixed': True,
>>>> 'fixed': True,
>>>> 'name': 'osm',
>>>> 'name': 'naip',
>>>> {'fixed': True,
>>>> EMAIL_USE_TLS
>>>> True
>>>> ACCOUNT_LANGUAGES
>>>> ('de', u'Deutsch'),
>>>> FIXTURE_DIRS
>>>> EMAIL_HOST
>>>> 'smtp.gmail.com'
>>>> DATE_FORMAT
>>>> 'N j, Y'
>>>> MEDIA_ROOT
>>>> ADMINS
>>>> FORMAT_MODULE_PATH
>>>> None
>>>> DEFAULT_FROM_EMAIL
>>>> STATICFILES_DIRS
>>>> GEOSERVER_URL
>>>> DATETIME_FORMAT
>>>> 'N j, Y, P'
>>>> TEMPLATE_DIRS
>>>> ['doc',
>>>> 'docx',
>>>> 'xls',
>>>> 'xslx',
>>>> 'pdf',
>>>> 'zip',
>>>> 'jpg',
>>>> 'jpeg',
>>>> 'tif',
>>>> 'tiff',
>>>> 'png',
>>>> 'gif',
>>>> 'txt']
>>>> SITE_ID
>>>> 1
>>>> 'account_settings'
>>>> SITEURL
>>>> LOGGING
>>>> 'level': 'ERROR'},
>>>> 'level': 'ERROR'},
>>>> 'level': 'ERROR'}},
>>>> 'level': 'ERROR',
>>>> 'propagate': True},
>>>> 'version': 1}
>>>> SHORT_DATE_FORMAT
>>>> 'm/d/Y'
>>>> DATABASE_USER
>>>> 'geonode'
>>>> SITENAME
>>>> 'GeoNode'
>>>> IGNORABLE_404_URLS
>>>> TIME_ZONE
>>>> 'Asia/Manila'
>>>> 2621440
>>>> DB_DATASTORE_TYPE
>>>> EMAIL_BACKEND
>>>> DEFAULT_TABLESPACE
>>>> SESSION_COOKIE_AGE
>>>> 1209600
>>>> SETTINGS_MODULE
>>>> 'geonode.settings'
>>>> USE_ETAGS
>>>> False
>>>> LANGUAGES
>>>> (('en', 'English'),
>>>> ('it', 'Italiano'),
>>>> ('de', 'Deutsch'),
>>>> INTERNAL_IPS
>>>> STATIC_URL
>>>> '/static/'
>>>> EMAIL_PORT
>>>> 587
>>>> 'location'
>>>> USE_TZ
>>>> False
>>>> DEFAULT_SEARCH_SIZE
>>>> 10
>>>> PASSWORD_HASHERS
>>>> ACTSTREAM_SETTINGS
>>>> 600
>>>> True
>>>> '%Y-%m-%d %H:%M',
>>>> '%Y-%m-%d',
>>>> '%m/%d/%Y %H:%M',
>>>> '%m/%d/%Y',
>>>> '%m/%d/%y %H:%M',
>>>> '%m/%d/%y')
>>>> False
>>>> DATABASE_PASSWORD
>>>> PROFANITIES_LIST
>>>> EMAIL_HOST_USER
>>>> MAX_DOCUMENT_SIZE
>>>> 10
>>>> standard 500 page.
>>>> On Wed, Jul 1, 2015 at 4:50 PM, Jeffy John Tomarong <
>>>> jeffytoms at gmail.com> wrote:
>>>>> Restarting PostgreSQL 9.1 database server
>>>>> * The PostgreSQL server failed to start. Please check the log
>>>>> output:
>>>>> 2015-07-01 16:49:11 PHT LOG: database system was interrupted; last
>>>>> known up at 2015-05-27 23:25:59 PHT
>>>>> 2015-07-01 16:49:11 PHT FATAL: could not open file
>>>>> "/etc/ssl/certs/ssl-cert-snakeoil.pem": Permission denied
>>>>> 2015-07-01 16:49:11 PHT LOG: startup process (PID 5730) exited with
>>>>> exit code 1
>>>>> 2015-07-01 16:49:11 PHT LOG: aborting startup due to startup process
>>>>> failure
>>>>> [fail]
>>>>> On Wed, Jul 1, 2015 at 3:40 PM, Jeffy John Tomarong <
>>>>>> /usr/lib/python2.7/dist-packages/django/conf/__init__.py:221:
>>>>>> DeprecationWarning: You have no filters defined on the 'mail_admins'
>>>>>> logging handler: adding implicit debug-false-only filter. See
>>>>>> http://docs.djangoproject.com/en/dev/releases/1.4/#request-exceptions-are-now-always-logged
>>>>>> DeprecationWarning)
>>>>>> OperationalError: could not connect to server: Connection refused
>>>>>> Is the server running on host "localhost" (127.0.0.1) and accepting
>>>>>> TCP/IP connections on port 5432?
>>>>>> On Wed, Jul 1, 2015 at 3:15 PM, Jeffy John Tomarong <
>>>>>>> Replacing SITEURL in /etc/geonode/local_settings.py
>>>>>>> Adding entry for local ip in
>>>>>>> /usr/share/geoserver/data//printing/config.yaml
>>>>>>> IP was already added to the printing whitelist.
>>>>>>> Replacing ALLOWED_HOSTS in /etc/geonode/local_settings.py
>>>>>>> * Restarting web server apache2
>>>>>>> apache2: Could not reliably determine the server's fully
>>>>>>> qualified domain name, using 127.0.1.1 for ServerName
>>>>>>> ... waiting .apache2: Could not reliably determine the server's
>>>>>>> fully qualified domain name, using 127.0.1.1 for ServerName
>>>>>>> [ OK ]
>>>>>>> DeprecationWarning)
>>>>>>> Traceback (most recent call last):
>>>>>>> File "/usr/bin/django-admin", line 5, in <module>
>>>>>>> management.execute_from_command_line()
>>>>>>> File
>>>>>>> "/usr/lib/python2.7/dist-packages/django/core/management/__init__.py", line
>>>>>>> 453, in execute_from_command_line
>>>>>>> utility.execute()
>>>>>>> File
>>>>>>> 392, in execute
>>>>>>> self.fetch_command(subcommand).run_from_argv(self.argv)
>>>>>>> File
>>>>>>> 272, in fetch_command
>>>>>>> klass = load_command_class(app_name, subcommand)
>>>>>>> File
>>>>>>> 77, in load_command_class
>>>>>>> module = import_module('%s.management.commands.%s' % (app_name,
>>>>>>> name))
>>>>>>> File "/usr/lib/python2.7/dist-packages/django/utils/importlib.py",
>>>>>>> line 35, in import_module
>>>>>>> __import__(name)
>>>>>>> File
>>>>>>> "/usr/local/lib/python2.7/dist-packages/geonode/layers/management/commands/updatelayers.py",
>>>>>>> line 23, in <module>
>>>>>>> from geonode.geoserver.helpers import gs_slurp
>>>>>>> File
>>>>>>> "/usr/local/lib/python2.7/dist-packages/geonode/geoserver/helpers.py", line
>>>>>>> 31, in <module>
>>>>>>> from geonode.utils import _user, _password, ogc_server_settings
>>>>>>> File "/usr/local/lib/python2.7/dist-packages/geonode/utils.py",
>>>>>>> line 36, in <module>
>>>>>>> from geonode.security.enumerations import AUTHENTICATED_USERS,
>>>>>>> ANONYMOUS_USERS, INVALID_PERMISSION_MESSAGE
>>>>>>> File
>>>>>>> "/usr/local/lib/python2.7/dist-packages/geonode/security/enumerations.py",
>>>>>>> line 28, in <module>
>>>>>>> ANONYMOUS_USERS: _('Anonymous Users'),
>>>>>>> File
>>>>>>> "/usr/lib/python2.7/dist-packages/django/utils/translation/__init__.py",
>>>>>>> line 71, in ugettext
>>>>>>> return _trans.ugettext(message)
>>>>>>> File
>>>>>>> "/usr/lib/python2.7/dist-packages/django/utils/translation/trans_real.py",
>>>>>>> line 276, in ugettext
>>>>>>> return do_translate(message, 'ugettext')
>>>>>>> File
>>>>>>> line 258, in do_translate
>>>>>>> _default = translation(settings.LANGUAGE_CODE)
>>>>>>> File
>>>>>>> line 172, in translation
>>>>>>> default_translation = _fetch(settings.LANGUAGE_CODE)
>>>>>>> File
>>>>>>> line 154, in _fetch
>>>>>>> app = import_module(appname)
>>>>>>> __import__(name)
>>>>>>> ImportError: No module named relationships
>>>>>>> jjqt at GeoNode:/usr/local/lib/python2.7/dist-packages/geonode$ sudo
>>>>>>> pico local_settings.py
>>>>>>> pico settings.py
>>>>>>> pip install -e.
>>>>>>> [sudo] password for jjqt:
>>>>>>> --editable=. should be formatted with svn+URL, git+URL, hg+URL or
>>>>>>> bzr+URL
>>>>>>> Storing complete log in /home/jjqt/.pip/pip.log
>>>>>>> geonode-updateip crisp.norminet.org.ph
>>>>>>> [ OK ]
>>>>>>> DeprecationWarning)
>>>>>>> File
>>>>>>> utility.execute()
>>>>>>> File
>>>>>>> 392, in execute
>>>>>>> File
>>>>>>> File
>>>>>>> name))
>>>>>>> __import__(name)
>>>>>>> File
>>>>>>> File
>>>>>>> 31, in <module>
>>>>>>> File
>>>>>>> File
>>>>>>> File
>>>>>>> File
>>>>>>> File
>>>>>>> File
>>>>>>> line 154, in _fetch
>>>>>>> __import__(name)
>>>>>>> jjqt at GeoNode:/usr/local/lib/python2.7/dist-packages/geonode$ pip
>>>>>>> install relationships
>>>>>>> Downloading/unpacking relationships
>>>>>>> Exception:
>>>>>>> File "/usr/lib/python2.7/dist-packages/pip/basecommand.py", line
>>>>>>> 126, in main
>>>>>>> self.run(options, args)
>>>>>>> File "/usr/lib/python2.7/dist-packages/pip/commands/install.py",
>>>>>>> line 223, in run
>>>>>>> requirement_set.prepare_files(finder,
>>>>>>> force_root_egg_info=self.bundle, bundle=self.bundle)
>>>>>>> File "/usr/lib/python2.7/dist-packages/pip/req.py", line 942, in
>>>>>>> prepare_files
>>>>>>> location = req_to_install.build_location(self.build_dir, not
>>>>>>> self.is_download)
>>>>>>> File "/usr/lib/python2.7/dist-packages/pip/req.py", line 144, in
>>>>>>> build_location
>>>>>>> _make_build_dir(build_dir)
>>>>>>> File "/usr/lib/python2.7/dist-packages/pip/req.py", line 1185, in
>>>>>>> _make_build_dir
>>>>>>> os.makedirs(build_dir)
>>>>>>> File "/usr/lib/python2.7/os.py", line 157, in makedirs
>>>>>>> mkdir(name, mode)
>>>>>>> OSError: [Errno 13] Permission denied:
>>>>>>> '/usr/local/lib/python2.7/dist-packages/geonode/build'
>>>>>>> File "/usr/bin/pip", line 9, in <module>
>>>>>>> load_entry_point('pip==1.0', 'console_scripts', 'pip')()
>>>>>>> File "/usr/lib/python2.7/dist-packages/pip/__init__.py", line 116,
>>>>>>> in main
>>>>>>> return command.main(initial_args, args[1:], options)
>>>>>>> 147, in main
>>>>>>> log_fp = open_logfile(log_fn, 'w')
>>>>>>> 176, in open_logfile
>>>>>>> log_fp = open(filename, mode)
>>>>>>> IOError: [Errno 13] Permission denied: '/home/jjqt/.pip/pip.log'
>>>> On Wed, Jul 1, 2015 at 4:55 PM, Simone Dalmasso <
>>>>> Take a look at this thread if it helps
>>>>> https://wiki.postgresql.org/wiki/May_2015_Fsync_Permissions_Bug
>>>>> 2015-07-01 10:52 GMT+02:00 Jeffy John Tomarong <jeffytoms at gmail.com>:
>>>>>> Hi Simone,
>>>>>> I got this error when I restarted postgresql and it's quite
>>>>>> persistent:
>>>>>> output:
>>>>>> exit code 1
>>>>>> failure
>>>>>> [fail]
>>>>>> On Wed, Jul 1, 2015 at 4:11 PM, Simone Dalmasso <
>>>>>>> There's no way to restore, but you can add back your db
>>>>>>> configuration. Check whether the local_settings.py file contains the
>>>>>>> correct db connection parameters and that postgres is up and running.
>>>>>>> 2015-07-01 10:08 GMT+02:00 Jeffy John Tomarong <jeffytoms at gmail.com>
>>>>>>>> Nope we dont have a custom configuration. After I installed
>>>>>>>> geonode, all I editted were on the ipaddress part or the site url. I did
>>>>>>>> not touch the DB config in the local_settings.py ..
>>>>>>>> Or is there a way to restore back the local_settings.py, say
>>>>>>>> restore it back to two days ago? Because I'm afraid I might have
>>>>>>>> overwritten the local_settings.py with the old backup file of
>>>>>>>> local_settings.py the moment it got the internal server error..
>>>>>>>> Thank you Simone!
>>>>>>>> On Wed, Jul 1, 2015 at 3:54 PM, Simone Dalmasso <
>>>>>>>>> That is because it can't connect to postgresql. Do you have some
>>>>>>>>> kind of custom configuration?
>>>>>>>>> That command uses /etc/geonode/local_settings.py to get the db
>>>>>>>>> configuration
>>>>>>>>> 2015-07-01 9:43 GMT+02:00 Jeffy John Tomarong <jeffytoms at gmail.com
>>>>>>>>>> Hi Simone,
>>>>>>>>>> It did help! Thank you very much for your quick response.. I also
>>>>>>>>>> did pip install django-request after that.
>>>>>>>>>> However, when I issued updateip again, I got this:
>>>>>>>>>> DeprecationWarning)
>>>>>>>>>> accepting
>>>>>>>>>> Hmm.. ??
>>>>>>>>>> On Wed, Jul 1, 2015 at 3:31 PM, Simone Dalmasso <
>>>>>>>>>>> Hi, I see you are using geonode 2.0
>>>>>>>>>>> the missing package should be django-relationships and since
>>>>>>>>>>> your geonode is installed systemwide you have to use sudo so:
>>>>>>>>>>> $ sudo pip install django-relationships
>>>>>>>>>>> Hope this helps
>>>>>>>>>>> 2015-07-01 9:23 GMT+02:00 Jeffy John Tomarong <
>>>>>>>>>>>> Hi Good Fellas!
>>>>>>>>>>>> Our GeoNode instance was running well in the previous months.
>>>>>>>>>>>> But now, it got Internal Server Error 500.
>>>>>>>>>>>> What I did was to update the IP of geonode (which is just the
>>>>>>>>>>>> same anyway), and it caused me this error:I also tried "pip install
>>>>>>>>>>>> relationship" since it displayed there "Error: No Module named
>>>>>>>>>>>> relationships". But it caused another set of error. GeoNode has been
>>>>>>>>>>>> running well in the last months, I do not know what happened.
>>>>>>>>>>>> I need your help guys on this. I'm at the end of my wits.
>>>>>>>>>>>> Will be very much appreciated. Thank you!
>>>>>>>>>>>> Here's the error message:
>>>>>>>>>>>> server's fully qualified domain name, using 127.0.1.1 for ServerName
>>>>>>>>>>>> [ OK ]
>>>>>>>>>>>> DeprecationWarning)
>>>>>>>>>>>> File
>>>>>>>>>>>> utility.execute()
>>>>>>>>>>>> File
>>>>>>>>>>>> 392, in execute
>>>>>>>>>>>> File
>>>>>>>>>>>> File
>>>>>>>>>>>> (app_name, name))
>>>>>>>>>>>> File
>>>>>>>>>>>> "/usr/lib/python2.7/dist-packages/django/utils/importlib.py", line 35, in
>>>>>>>>>>>> import_module
>>>>>>>>>>>> __import__(name)
>>>>>>>>>>>> File
>>>>>>>>>>>> File
>>>>>>>>>>>> 31, in <module>
>>>>>>>>>>>> ogc_server_settings
>>>>>>>>>>>> File
>>>>>>>>>>>> "/usr/local/lib/python2.7/dist-packages/geonode/utils.py", line 36, in
>>>>>>>>>>>> <module>
>>>>>>>>>>>> AUTHENTICATED_USERS, ANONYMOUS_USERS, INVALID_PERMISSION_MESSAGE
>>>>>>>>>>>> File
>>>>>>>>>>>> File
>>>>>>>>>>>> File
>>>>>>>>>>>> File
>>>>>>>>>>>> File
>>>>>>>>>>>> File
>>>>>>>>>>>> line 154, in _fetch
>>>>>>>>>>>> File
>>>>>>>>>>>> import_module
>>>>>>>>>>>> __import__(name)
>>>>>>>>>>>> sudo pico local_settings.py
>>>>>>>>>>>> sudo pico settings.py
>>>>>>>>>>>> sudo pip install -e.
>>>>>>>>>>>> or bzr+URL
>>>>>>>>>>>> sudo geonode-updateipcrisp.norminet.org.ph
>>>>>>>>>>>> [ OK ]
>>>>>>>>>>>> DeprecationWarning)
>>>>>>>>>>>> File
>>>>>>>>>>>> utility.execute()
>>>>>>>>>>>> File
>>>>>>>>>>>> 392, in execute
>>>>>>>>>>>> File
>>>>>>>>>>>> File
>>>>>>>>>>>> (app_name, name))
>>>>>>>>>>>> File
>>>>>>>>>>>> import_module
>>>>>>>>>>>> __import__(name)
>>>>>>>>>>>> File
>>>>>>>>>>>> File
>>>>>>>>>>>> 31, in <module>
>>>>>>>>>>>> ogc_server_settings
>>>>>>>>>>>> File
>>>>>>>>>>>> <module>
>>>>>>>>>>>> File
>>>>>>>>>>>> File
>>>>>>>>>>>> File
>>>>>>>>>>>> File
>>>>>>>>>>>> File
>>>>>>>>>>>> File
>>>>>>>>>>>> line 154, in _fetch
>>>>>>>>>>>> File
>>>>>>>>>>>> import_module
>>>>>>>>>>>> __import__(name)
>>>>>>>>>>>> pip install relationships
>>>>>>>>>>>> Exception:
>>>>>>>>>>>> line 126, in main
>>>>>>>>>>>> File
>>>>>>>>>>>> "/usr/lib/python2.7/dist-packages/pip/commands/install.py", line 223, in run
>>>>>>>>>>>> in prepare_files
>>>>>>>>>>>> not self.is_download)
>>>>>>>>>>>> in build_location
>>>>>>>>>>>> 1185, in _make_build_dir
>>>>>>>>>>>> mkdir(name, mode)
>>>>>>>>>>>> 116, in main
>>>>>>>>>>>> line 147, in main
>>>>>>>>>>>> line 176, in open_logfile
>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>> geonode-users mailing list
>>>>>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
>>>>>>>>>>> Simone
>>>>>>>>> Simone
>>>>>>> Simone
>>>>> Simone
>>> Simone
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150702/d6488aff/attachment-0001.html>
More information about the geonode-users
