[GeoNode-users] Internal Server Error
Ariel Nunez
ingenieroariel at gmail.com
Thu Jul 30 06:18:22 PDT 2015
I think it may be that the postgis extension is not installed in the
database. You can also make sure it is by doing:
sudo su - postgres
psql geonode_data
CREATE EXTENSION postgis;
On Thu, Jul 30, 2015 at 8:05 AM, Leonardo Jauregui <
leojauregui.geog at gmail.com> wrote:
> Hi Simone
> I will install it and let every one knows
> Leonardo
> 2015-07-30 3:46 GMT-04:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>> Hi, then you need to add POSTGIS_VERSION = (2,1,0) to your settings.
>> ps, please always keep in copy the mailing list as others may benefit
>> from this thread.
>> 2015-07-30 1:13 GMT+02:00 Leonardo Jauregui <leojauregui.geog at gmail.com>:
>>> Hi Simone
>>> Yes I did This is the error log
>>> [Wed Jul 29 18:02:22.566776 2015] [:error] [pid 2642:tid
>>> 140418890794752] [remote 192.168.10.10:29151] File
>>> "/usr/lib/python2.7/dist-packages/django/core/handlers/wsgi.py", line 194,
>>> in __call__
>>> [Wed Jul 29 18:02:22.566836 2015] [:error] [pid 2642:tid
>>> signals.request_started.send(sender=self.__class__)
>>> [Wed Jul 29 18:02:22.566855 2015] [:error] [pid 2642:tid
>>> "/usr/lib/python2.7/dist-packages/django/dispatch/dispatcher.py", line 185,
>>> in send
>>> [Wed Jul 29 18:02:22.566881 2015] [:error] [pid 2642:tid
>>> 140418890794752] [remote 192.168.10.10:29151] response =
>>> receiver(signal=self, sender=sender, **named)
>>> [Wed Jul 29 18:02:22.566897 2015] [:error] [pid 2642:tid
>>> "/usr/lib/python2.7/dist-packages/django/db/__init__.py", line 81, in
>>> reset_queries
>>> [Wed Jul 29 18:02:22.566921 2015] [:error] [pid 2642:tid
>>> 140418890794752] [remote 192.168.10.10:29151] for conn in
>>> connections.all():
>>> [Wed Jul 29 18:02:22.566936 2015] [:error] [pid 2642:tid
>>> "/usr/lib/python2.7/dist-packages/django/db/utils.py", line 213, in all
>>> [Wed Jul 29 18:02:22.566957 2015] [:error] [pid 2642:tid
>>> 140418890794752] [remote 192.168.10.10:29151] return [self[alias]
>>> for alias in self]
>>> [Wed Jul 29 18:02:22.566972 2015] [:error] [pid 2642:tid
>>> "/usr/lib/python2.7/dist-packages/django/db/utils.py", line 199, in
>>> __getitem__
>>> [Wed Jul 29 18:02:22.566992 2015] [:error] [pid 2642:tid
>>> 140418890794752] [remote 192.168.10.10:29151] conn =
>>> backend.DatabaseWrapper(db, alias)
>>> [Wed Jul 29 18:02:22.567007 2015] [:error] [pid 2642:tid
>>> "/usr/lib/python2.7/dist-packages/django/contrib/gis/db/backends/postgis/base.py",
>>> line 11, in __init__
>>> [Wed Jul 29 18:02:22.567030 2015] [:error] [pid 2642:tid
>>> 140418890794752] [remote 192.168.10.10:29151] self.ops =
>>> PostGISOperations(self)
>>> [Wed Jul 29 18:02:22.567044 2015] [:error] [pid 2642:tid
>>> "/usr/lib/python2.7/dist-packages/django/contrib/gis/db/backends/postgis/operations.py",
>>> line 158, in __init__
>>> [Wed Jul 29 18:02:22.567065 2015] [:error] [pid 2642:tid
>>> 140418890794752] [remote 192.168.10.10:29151] if
>>> self.spatial_version < (1, 3, 4):
>>> [Wed Jul 29 18:02:22.567079 2015] [:error] [pid 2642:tid
>>> "/usr/lib/python2.7/dist-packages/django/utils/functional.py", line 49, in
>>> __get__
>>> [Wed Jul 29 18:02:22.567160 2015] [:error] [pid 2642:tid
>>> 140418890794752] [remote 192.168.10.10:29151] res =
>>> instance.__dict__[self.func.__name__] = self.func(instance)
>>> [Wed Jul 29 18:02:22.567184 2015] [:error] [pid 2642:tid
>>> line 258, in spatial_version
>>> [Wed Jul 29 18:02:22.567212 2015] [:error] [pid 2642:tid
>>> 140418890794752] [remote 192.168.10.10:29151] 'template?' %
>>> self.connection.settings_dict['NAME']
>>> [Wed Jul 29 18:02:22.567242 2015] [:error] [pid 2642:tid
>>> 140418890794752] [remote 192.168.10.10:29151] ImproperlyConfigured:
>>> Cannot determine PostGIS version for database "geonode_data". GeoDjango
>>> requires at least PostGIS version 1.3. Was the database created from a
>>> spatial database template?
>>> We really apresiate your hepl, this is our Geonode 2.4 test server,
>>> Leonardo from Bolivia
>>> 2015-07-29 15:40 GMT-04:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
>>>> Hi did you run the Geonode createduperuser and the geonode-updateip
>>>> commands.
>>>> If you take a look at the Apache error log you might get more info.
>>>> Il mercoledì 29 luglio 2015, Leonardo Jauregui <
>>>> leojauregui.geog at gmail.com> ha scritto:
>>>>> 500
>>>>> that is the mesage after I installed geonode 2.4 un Ubuntu 14.04,
>>>>> What is mising ?
>>>> Simone
>> Simone
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150730/02ce1042/attachment-0001.html>
More information about the geonode-users
