[GeoNode-users] Implementing GeoNode for University
cloudtek enterprise solutions
info at cloudtek.co.za
Fri Jun 12 08:40:54 PDT 2015
Hi
Have you looked also at DKAN/CKAN?
On 12 Jun 2015 5:33 PM, "Stefan Steiniger" <sstein at geo.uzh.ch> wrote:
> Hi Florian,
> I belive GeoNode can do the stuff, but I would not put GeoNode directly to
> for the image data. The handling of image mosaiks is anyway done by
> GeoServer behind the scene (but I also have been able to only get simple
> compression zips to run). However, at the end it depends what you want the
> user to do with the image data: watching them or/and downloading. So in my
> case I focus only on seeing imagery (and legends aren't of interest at the
> moment either) which means I don't need a full WMS and can provide a link
> to a Background Map in GeoExplorer (saw that solution also at OpenQuake. I
> don't have anything in place for that yet, but I wanted to go the MapBox
> route here (e.g. using Tilestream).
> Docs are no problem with GeoNode as fast as I see, i.e. xls, doc, zip,
> pdf, etc.
> However, as long as you have Dev capabilities you can add features to
> GeoNode on your own.
> lets see what others say.
> stefan
> Am 12.06.15 um 05:58 schrieb Florian Hoedt:
>> Hello Internet,
>> We currently use a file-system-based geodata storage which holds several
>> hundred gb of geodata. We have access to the whole ESRI Suite and use
>> mainly ArcMap as Desktop GIS and have recently set up an ArcGIS Server
>> to serve aerial and topografic datasets as WMTS.
>> I would like to create a geoportal for my university which is (also non
>> geo) user friendly and able to hold vector data as well as loads of
>> raster data. Therefore:
>> 1. I have some concerns about Geonode since it "just" supports vector
>> data (ESRI shp) and GeoTiff, which is not feasable for the loads of
>> aerial data we have - I do not want to publish single footprints as
>> geotiffs. How could this be achieved?
>> 2. I also would like to harvest external data sources (CSW) - these
>> should be displayed in the portal, too. Is geonode capable of that?
>> 3. In addition there are documents to share, too.
>> Is geonode a wise path to choose? How could I achieve my Feature-List
>> thanks for your time and thoughts,
>> Florian Hoedt form Germany, Höxter
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150612/6b29a1a5/attachment.html>
More information about the geonode-users
