[GeoNode-users] Implementing GeoNode for University
Stefan Steiniger sstein at geo.uzh.ch
Fri Jun 12 09:25:42 PDT 2015
Hi Florian,
I belive GeoNode can do the stuff, but I would not put GeoNode directly
to for the image data. The handling of image mosaiks is anyway done by
GeoServer behind the scene (but I also have been able to only get simple
compression zips to run). However, at the end it depends what you want
the user to do with the image data: watching them or/and downloading. So
in my case I focus only on seeing imagery (and legends aren't of
interest at the moment either) which means I don't need a full WMS and
can provide a link to a Background Map in GeoExplorer (saw that solution
also at OpenQuake. I don't have anything in place for that yet, but I
wanted to go the MapBox route here (e.g. using Tilestream).
Docs are no problem with GeoNode as fast as I see, i.e. xls, doc, zip,
pdf, etc.
However, as long as you have Dev capabilities you can add features to
GeoNode on your own.
lets see what others say.
stefan
Am 12.06.15 um 05:58 schrieb Florian Hoedt:
> Hello Internet,
> We currently use a file-system-based geodata storage which holds several
> hundred gb of geodata. We have access to the whole ESRI Suite and use
> mainly ArcMap as Desktop GIS and have recently set up an ArcGIS Server
> to serve aerial and topografic datasets as WMTS.
> I would like to create a geoportal for my university which is (also non
> geo) user friendly and able to hold vector data as well as loads of
> raster data. Therefore:
> 1. I have some concerns about Geonode since it "just" supports vector
> data (ESRI shp) and GeoTiff, which is not feasable for the loads of
> aerial data we have - I do not want to publish single footprints as
> geotiffs. How could this be achieved?
> 2. I also would like to harvest external data sources (CSW) - these
> should be displayed in the portal, too. Is geonode capable of that?
> 3. In addition there are documents to share, too.
> Is geonode a wise path to choose? How could I achieve my Feature-List
> thanks for your time and thoughts,
> Florian Hoedt form Germany, Höxter
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
More information about the geonode-users mailing list
