[GeoNode-users] Restrict the add_layer auth to some user
Simone Dalmasso simone.dalmasso at gmail.com
Wed Jun 17 01:29:32 PDT 2015
That can work for the link, but not if the user types the /layers/upload in
the url bar. Maybe you should add a check also on the upload views.
In order to make a PR we would need also the javascript permissions widget
update, all the check in the codebase and some tests. Very welcome :)
2015-06-17 10:13 GMT+02:00 FERRARI Hugo <ferrari_hugo at yahoo.fr>:
>  Ok, maybe I found a simpler way to do what i want.
> there is an "add resource base" in the auth list from the auth group admin
> menu.
> I can check if the current logged user belongs to a group which has this
> auth, with a custom tag which takes the context as parameter.
> If it is true, from the template I display the "add layer/map/document".
> it is not, i don't display anything (or just "explore" from index.html).
> the fact is coding some small modification like that doesn't  need a Pull
> Request. Am I right ?
> Thanks again.
> Le 17/06/2015 10:07, Simone Dalmasso a écrit :
> Yes you have to implement the add_layer permission.
> The ath user has been swapper with people profile in Geonode. And group
> only work behind the scenes what is called group in Geonode is actually the
> groupProfile
> Il mercoledì 17 giugno 2015, FERRARI Hugo <ferrari_hugo at yahoo.fr> ha
> scritto:
>> That's what I thought, but not giving the add_layer auth to a group
>> doesn't affect the group members.
>>  So first  Do I have to make it work for a single member?
>> On the same topic , usually django admin backend has a auth user menu. It
>> vanished in my geonode installation, there is only the group auth menu.
>> Is it the expected behavior ?
>> Thanks a lot.
>> Le 16/06/2015 18:26, Simone Dalmasso a écrit :
>> Hi Hugo,
>> well this permission is not implemented in GeoNode, you will need to hack
>> a bit into it and implement checks for it on the layer upload views and add
>> its support in the client. The permission itself can then be granted to a
>> group.
>> 2015-06-16 16:13 GMT+02:00 FERRARI Hugo <ferrari_hugo at yahoo.fr>:
>>> Hello world,
>>> in Geonode there are permissions on resources and we can modify them.
>>> But is there any way to restrict actions for some users ?
>>> I want only few users to be allowed to add new layers in geonode but
>>> apparently the only existing criteria to permit is authentication.
>>> I'm sure i'm not the first to ask this question.
>>> In auth_permission postgres table we can see that the "add_layer"
>>> permision already exists but it is not affected to users.
>>> Thanks for your advices
>>> Hugo FERRARI
>>> Le 09/06/2015 18:50, geonode-users-request at lists.osgeo.org a écrit :
>>>> Send geonode-users mailing list submissions to
>>>>         geonode-users at lists.osgeo.org
>>>> To subscribe or unsubscribe via the World Wide Web, visit
>>>>         http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
>>>> or, via email, send a message with subject or body 'help' to
>>>> You can reach the person managing the list at
>>>>         geonode-users-owner at lists.osgeo.org
>>>> When replying, please edit your Subject line so it is more specific
>>>> than "Re: Contents of geonode-users digest..."
>>>> Today's Topics:
>>>>     1. developpement: Modifying permission behavior and data
>>>>        visibility in Geonode (FERRARI Hugo)
>>>>     2. Re: developpement: Modifying permission behavior and data
>>>>        visibility in Geonode (Ariel Nunez)
>>>>     3. Re: developpement: Modifying permission behavior and data
>>>>        visibility in Geonode (Paolo Corti)
>>>> Message: 1
>>>> Date: Tue, 09 Jun 2015 16:56:18 +0400
>>>> From: FERRARI Hugo <ferrari_hugo at yahoo.fr>
>>>> To: geonode-users at lists.osgeo.org
>>>> Subject: [GeoNode-users] developpement: Modifying permission behavior
>>>>         and data visibility in Geonode
>>>> Message-ID: <5576E272.6090606 at yahoo.fr>
>>>> Content-Type: text/plain; charset=windows-1252; format=flowed
>>>> Hello everyone,
>>>> I have installed a complete geonode instance on a developpement server.
>>>> I want  to change thebehaviorofthesoftware  to make it fit the need of
>>>> the institution I work for.
>>>> So i'm looking for some advices because  I didn't manage to code it yet.
>>>> My aim to separate metada access from the data access.
>>>> That  is to make all the layers uploaded in geoserver VISIBLE for all
>>>> users (logged or not) but only in the layer-list page , not on the
>>>> layer-detail page .
>>>> If you click on any specific layer in the layer-list (or document-list
>>>> because i want the same behavior for both), you get the layer detail so
>>>> you what will see is:
>>>> - In the case you have the view_resourcebase permission (who can see it
>>>> ?), you will see the current template corresponding to
>>>> layer_detail.html: both access to datas and metadatas.
>>>> - In the other case if you don't have the view_resourcebase permission,
>>>> you 'll only have access to metadatas's ressource (that means a template
>>>> similar to layer_detail.html but Instead of the geoexplorer frame you
>>>> sould have a "permission denied" message, but the possibility to
>>>> retrieve metadata).
>>>> It's quite simple to make all the layers visible in the layer list,
>>>> whoever is logged in (you just have to modify SKIP_PERMS_FILTERS in
>>>> settings.py AND read_list function in module api/authorisation.py).
>>>> but the actual behavior is to catch a 403 http error when trying to view
>>>> the layer detail.
>>>> Modifying the 403.html template does not seems to be the good way to
>>>> process.
>>>> I don't think it is necessary to modify geonode's database model because
>>>> the view_ressource permission  is enough, considering that  viewing the
>>>> ressource is equivalent to having access to the data (even if you can't
>>>> download it). There's no need to add a new kind of permissions, as far
>>>> as I can guess.
>>>> What is prefered is not throwing a 403 error but just the
>>>> layer_detail.html template modified to get only metadatas.
>>>> I hope the explanation was clear enough,
>>>> Hugo FERRARI
>>>> PS
>>>> Does it correspond to the actual geonode developpement policy ?
>>>> Datas and metada are strongly linked in this software.
>>>> Could this functionnality be interresting for any other geonode users?
>>>> Le 08/06/2015 23:00, geonode-users-request at lists.osgeo.org a ?crit :
>>>>> Today's Topics:
>>>>>      1. Re: osgeo module install problem (Simone Dalmasso)
>>>>>      2. Problems to Translate Geonode - Transifex -     Portuguese
>>>>>         (Brazil) (Davi Custodio)
>>>>>      3. Re: Problems to Translate Geonode - Transifex - Portuguese
>>>>>         (Brazil) (Julien Collaer)
>>>>> Message: 1
>>>>> Date: Sun, 7 Jun 2015 21:40:13 +0200
>>>>> From: Simone Dalmasso <simone.dalmasso at gmail.com>
>>>>> To: Vicente <deluca.vicente at gmail.com>
>>>>> Cc: geonode-users <geonode-users at lists.osgeo.org>
>>>>> Subject: Re: [GeoNode-users] osgeo module install problem
>>>>> Message-ID:
>>>>>         <CAAHAC+cU9GgbBUe-ocH4GJZ1PaXEZDrY5W=
>>>>> ZCsTzSUSx5ymVvA at mail.gmail.com>
>>>>> Content-Type: text/plain; charset="utf-8"
>>>>> Hi, you are missing the gdal python bindings, a "pip install gdal"
>>>>> should
>>>>> fix it.
>>>>> Hope it helps, ciao
>>>>> 2015-06-07 17:59 GMT+02:00 Vicente <deluca.vicente at gmail.com>:
>>>>>  Good afternoon,
>>>>>> If I run the following line from my command line, the answer is
>>>>>> successful
>>>>>> $ sudo apt-get -y install libgdal1h libgdal-dev python-gdal
>>>>>> But if I run from the session virtualenv, the answer is No module
>>>>>> named
>>>>>> osgeo.
>>>>>> I have just added the following session variables in my .bashrc:
>>>>>> export VIRTUALENVWRAPPER_PYTHON = / usr / bin / python
>>>>>> export WORKON_HOME = ~ / .venvs
>>>>>> source /usr/local/bin/virtualenvwrapper.sh
>>>>>> export PIP_DOWNLOAD_CACHE = $ HOME / .pip-downloads
>>>>>> Both session with virtualenv or outside, the python to run is the
>>>>>> same,
>>>>>> Python 2.7.6 (default, Mar 22 2014, 22:59:56)
>>>>>> The result is that I can not run because there is paver start the
>>>>>> osgeo
>>>>>> module from within the session obviously.
>>>>>> Thanks!
>>>>>> [image: MANTA] <http://www.estudiomanta.com/>
>>>>>> Vicente Deluca
>>>>>> *+54 11 6091 4579 <%2B54%2011%206091%204579>
>>>>>> <%2B54%2011%206091%204579>*
>>>>>> _______________________________________________
>>>> Message: 2
>>>> Date: Tue, 9 Jun 2015 09:01:34 -0500
>>>> From: Ariel Nunez <ingenieroariel at gmail.com>
>>>> To: FERRARI Hugo <ferrari_hugo at yahoo.fr>
>>>> Cc: "geonode-users at lists.osgeo.org" <geonode-users at lists.osgeo.org>
>>>> Subject: Re: [GeoNode-users] developpement: Modifying permission
>>>>         behavior and data visibility in Geonode
>>>> Message-ID:
>>>> CALh6R-QDnFhFPgQdejPp0Kuh5NABLExo7ONaQWjhyb2hk3chEw at mail.gmail.com>
>>>> Hugo,
>>>> Based on what I understand, the best path forward is to have a
>>>> view_metadata permission that you use to enforce the behavior you want.
>>>> Assigning a new meaning to the existing permission may be problematic
>>>> for
>>>> other users with different needs (for example where metadata is
>>>> sensitive
>>>> information).
>>>> The place where we want to get to, is to allow uploaders to restrict any
>>>> actions they want, but give the end user buttons to request permissions
>>>> (to
>>>> view if they cannot view, to download if they can only view, to edit if
>>>> the
>>>> can only download) to encourage a conversation between uploaders and
>>>> users
>>>> and provide a workflow to allow access to information when it is needed.
>>>> The changes you make would be good candidates for inclusion in the main
>>>> version of GeoNode so others can benefit in the future. Hopefully others
>>>> (Paolo?) can chime in with more specific feedback.
>>>> Best,
>>>> Ariel.
>>>> On Tue, Jun 9, 2015 at 7:56 AM, FERRARI Hugo <ferrari_hugo at yahoo.fr>
>>>> wrote:
>>>>  Hello everyone,
>>>>> the
>>>>> yet.
>>>>> layer-detail page .
>>>>> so you
>>>>> what will see is:
>>>>> layer_detail.html:
>>>>> template
>>>>> sould
>>>>> have a "permission denied" message, but the possibility to retrieve
>>>>> metadata).
>>>>> view
>>>>> the layer detail.
>>>>> process.
>>>>> because
>>>>> as I
>>>>> can guess.
>>>>> Hugo FERRARI
>>>>> PS
>>>>>> Today's Topics:
>>>>>> Message: 1
>>>>>> Message-ID:
>>>>>> should
>>>>>> fix it.
>>>>>> Hope it helps, ciao
>>>>>>   Good afternoon,
>>>>>>> successful
>>>>>>> named
>>>>>>> osgeo.
>>>>>>> same,
>>>>>>> osgeo
>>>>>>> Thanks!
>>>>>>> Vicente Deluca
>>>>>  -------------- next part --------------
>>>> An HTML attachment was scrubbed...
>>>> URL: <
>>>> http://lists.osgeo.org/pipermail/geonode-users/attachments/20150609/4dbe42d3/attachment-0001.html
>>>> Message: 3
>>>> Date: Tue, 9 Jun 2015 16:50:01 +0200
>>>> From: Paolo Corti <pcorti at gmail.com>
>>>> To: Ariel Nunez <ingenieroariel at gmail.com>
>>>> Cc: FERRARI Hugo <ferrari_hugo at yahoo.fr>,
>>>> Message-ID:
>>>> CAHXrU-JBaUUQUBz7BjsNuTkmOpOSLB7rxAaXEt3Qsn1TmKmvqw at mail.gmail.com>
>>>> Content-Type: text/plain; charset=UTF-8
>>>> Yes, Ariel is totally right.
>>>> Currently we don't have a specific permission for viewing metadata.
>>>> This is implicit with the view_resourcebase permission that gives
>>>> access to the data and metadata at the same time.
>>>> As suggested by Ariel you may consider to add a new django guardian
>>>> permission at the resource base model, like it has been done here [1]
>>>> and then have your GeoNode instance behaved according to it in views,
>>>> templates and javascript.
>>>> I don't think there is an easy way to avoid forking GeoNode and
>>>> customize the beahviour in your GeoNode project, though it may be not
>>>> impossible and this would keep your instance easily updateable with
>>>> mainstream code.
>>>> Even better, as Ariel suggested, you may though fork it and send a PR
>>>> as it could be useful for others as well.
>>>> regards
>>>> p
>>>> [1]
>>>> https://github.com/GeoNode/geonode/blob/master/geonode/base/models.py#L648
>>>> On Tue, Jun 9, 2015 at 4:01 PM, Ariel Nunez <ingenieroariel at gmail.com>
>>>> wrote:
>>>>> Hugo,
>>>>> view_metadata
>>>>> permission that you use to enforce the behavior you want. Assigning a
>>>>> new
>>>>> meaning to the existing permission may be problematic for other users
>>>>> with
>>>>> different needs (for example where metadata is sensitive information).
>>>>> any
>>>>> permissions (to
>>>>> if the
>>>>> users
>>>>> needed.
>>>>> others
>>>>> Best,
>>>>> Ariel.
>>>>> wrote:
>>>>>> Hello everyone,
>>>>>> server.
>>>>>> of the
>>>>>> yet.
>>>>>> layer-detail page .
>>>>>> so you
>>>>>> what will see is:
>>>>>> it
>>>>>> layer_detail.html:
>>>>>> permission,
>>>>>> template
>>>>>> sould
>>>>>> metadata).
>>>>>> view
>>>>>> the layer detail.
>>>>>> process.
>>>>>> because
>>>>>> the
>>>>>> can't
>>>>>> far as I
>>>>>> can guess.
>>>>>> Hugo FERRARI
>>>>>> PS
>>>>>>> Today's Topics:
>>>>>>> Message: 1
>>>>>>> Message-ID:
>>>>>>> <CAAHAC+cU9GgbBUe-ocH4GJZ1PaXEZDrY5W=ZCsTzSUSx5ymVvA at mail.gmail.com>
>>>>>>> should
>>>>>>> fix it.
>>>>>>> Hope it helps, ciao
>>>>>>>  Good afternoon,
>>>>>>>> successful
>>>>>>>> named
>>>>>>>> osgeo.
>>>>>>>> same,
>>>>>>>> osgeo
>>>>>>>> Thanks!
>>>>>>>> Vicente Deluca
>>>>>>>> *+54 11 6091 4579 <%2B54%2011%206091%204579>*
>> Simone
> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150617/b42f59f3/attachment-0001.html>
More information about the geonode-users mailing list
