[GeoNode-users] Restrict the add_layer auth to some user
FERRARI Hugo
ferrari_hugo at yahoo.fr
Wed Jun 17 02:49:29 PDT 2015
that's what I did for the upload/create templates. It works fine.
Yet I can't use unitest module in an easy way, and that's a shame
because it seems to be very usefull.
I'll try it again.
Le 17/06/2015 12:29, Simone Dalmasso a écrit :
> That can work for the link, but not if the user types the
> /layers/upload in the url bar. Maybe you should add a check also on
> the upload views.
> In order to make a PR we would need also the javascript permissions
> widget update, all the check in the codebase and some tests. Very
> welcome :)
> 2015-06-17 10:13 GMT+02:00 FERRARI Hugo <ferrari_hugo at yahoo.fr
> <mailto:ferrari_hugo at yahoo.fr>>:
>> Ok, maybe I found a simpler way to do what i want.
>> there is an "add resource base" in the auth list from the auth
>> group admin menu.
>> I can check if the current logged user belongs to a group which
>> has this auth, with a custom tag which takes the context as
>> parameter.
>> If it is true, from the template I display the "add
>> layer/map/document". it is not, i don't display anything (or just
>> "explore" from index.html).
>> the fact is coding some small modification like that doesn't
>> need a Pull Request. Am I right ?
>> Thanks again.
>> Le 17/06/2015 10:07, Simone Dalmasso a écrit :
>>> Yes you have to implement the add_layer permission.
>>> The ath user has been swapper with people profile in Geonode.
>>> And group only work behind the scenes what is called group in
>>> Geonode is actually the groupProfile
>>> Il mercoledì 17 giugno 2015, FERRARI Hugo <ferrari_hugo at yahoo.fr
>>> <mailto:ferrari_hugo at yahoo.fr>> ha scritto:
>>> That's what I thought, but not giving the add_layer auth to
>>> a group doesn't affect the group members.
>>> So first Do I have to make it work for a single member?
>>> On the same topic , usually django admin backend has a auth
>>> user menu. It vanished in my geonode installation, there is
>>> only the group auth menu.
>>> Is it the expected behavior ?
>>> Thanks a lot.
>>> Le 16/06/2015 18:26, Simone Dalmasso a écrit :
>>>> Hi Hugo,
>>>> well this permission is not implemented in GeoNode, you
>>>> will need to hack a bit into it and implement checks for it
>>>> on the layer upload views and add its support in the
>>>> client. The permission itself can then be granted to a group.
>>>> 2015-06-16 16:13 GMT+02:00 FERRARI Hugo
>>>> <ferrari_hugo at yahoo.fr>:
>>>> Hello world,
>>>> in Geonode there are permissions on resources and we
>>>> can modify them.
>>>> But is there any way to restrict actions for some users ?
>>>> I want only few users to be allowed to add new layers
>>>> in geonode but apparently the only existing criteria to
>>>> permit is authentication.
>>>> I'm sure i'm not the first to ask this question.
>>>> In auth_permission postgres table we can see that the
>>>> "add_layer" permision already exists but it is not
>>>> affected to users.
>>>> Thanks for your advices
>>>> Hugo FERRARI
>>>> Le 09/06/2015 18:50,
>>>> geonode-users-request at lists.osgeo.org a écrit :
>>>> Send geonode-users mailing list submissions to
>>>> geonode-users at lists.osgeo.org
>>>> To subscribe or unsubscribe via the World Wide Web,
>>>> visit
>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
>>>> or, via email, send a message with subject or body
>>>> 'help' to
>>>> You can reach the person managing the list at
>>>> geonode-users-owner at lists.osgeo.org
>>>> When replying, please edit your Subject line so it
>>>> is more specific
>>>> than "Re: Contents of geonode-users digest..."
>>>> Today's Topics:
>>>> 1. developpement: Modifying permission behavior
>>>> and data
>>>> visibility in Geonode (FERRARI Hugo)
>>>> 2. Re: developpement: Modifying permission
>>>> behavior and data
>>>> visibility in Geonode (Ariel Nunez)
>>>> 3. Re: developpement: Modifying permission
>>>> behavior and data
>>>> visibility in Geonode (Paolo Corti)
>>>> Message: 1
>>>> Date: Tue, 09 Jun 2015 16:56:18 +0400
>>>> From: FERRARI Hugo <ferrari_hugo at yahoo.fr>
>>>> To: geonode-users at lists.osgeo.org
>>>> Subject: [GeoNode-users] developpement: Modifying
>>>> permission behavior
>>>> and data visibility in Geonode
>>>> Message-ID: <5576E272.6090606 at yahoo.fr>
>>>> Content-Type: text/plain; charset=windows-1252;
>>>> format=flowed
>>>> Hello everyone,
>>>> I have installed a complete geonode instance on a
>>>> developpement server.
>>>> I want to change thebehaviorofthesoftware to make
>>>> it fit the need of
>>>> the institution I work for.
>>>> So i'm looking for some advices because I didn't
>>>> manage to code it yet.
>>>> My aim to separate metada access from the data access.
>>>> That is to make all the layers uploaded in
>>>> geoserver VISIBLE for all
>>>> users (logged or not) but only in the layer-list
>>>> page , not on the
>>>> layer-detail page .
>>>> If you click on any specific layer in the
>>>> layer-list (or document-list
>>>> because i want the same behavior for both), you get
>>>> the layer detail so
>>>> you what will see is:
>>>> - In the case you have the view_resourcebase
>>>> permission (who can see it
>>>> ?), you will see the current template corresponding to
>>>> layer_detail.html: both access to datas and metadatas.
>>>> - In the other case if you don't have the
>>>> view_resourcebase permission,
>>>> you 'll only have access to metadatas's ressource
>>>> (that means a template
>>>> similar to layer_detail.html but Instead of the
>>>> geoexplorer frame you
>>>> sould have a "permission denied" message, but the
>>>> possibility to
>>>> retrieve metadata).
>>>> It's quite simple to make all the layers visible in
>>>> the layer list,
>>>> whoever is logged in (you just have to modify
>>>> SKIP_PERMS_FILTERS in
>>>> settings.py AND read_list function in module
>>>> api/authorisation.py).
>>>> but the actual behavior is to catch a 403 http
>>>> error when trying to view
>>>> the layer detail.
>>>> Modifying the 403.html template does not seems to
>>>> be the good way to
>>>> process.
>>>> I don't think it is necessary to modify geonode's
>>>> database model because
>>>> the view_ressource permission is enough,
>>>> considering that viewing the
>>>> ressource is equivalent to having access to the
>>>> data (even if you can't
>>>> download it). There's no need to add a new kind of
>>>> permissions, as far
>>>> as I can guess.
>>>> What is prefered is not throwing a 403 error but
>>>> just the
>>>> layer_detail.html template modified to get only
>>>> metadatas.
>>>> I hope the explanation was clear enough,
>>>> Hugo FERRARI
>>>> PS
>>>> Does it correspond to the actual geonode
>>>> developpement policy ?
>>>> Datas and metada are strongly linked in this software.
>>>> Could this functionnality be interresting for any
>>>> other geonode users?
>>>> Le 08/06/2015 23:00,
>>>> geonode-users-request at lists.osgeo.org a ?crit :
>>>> Web, visit
>>>> body 'help' to
>>>> it is more specific
>>>> Today's Topics:
>>>> 1. Re: osgeo module install problem
>>>> (Simone Dalmasso)
>>>> 2. Problems to Translate Geonode -
>>>> Transifex - Portuguese
>>>> (Brazil) (Davi Custodio)
>>>> 3. Re: Problems to Translate Geonode -
>>>> (Brazil) (Julien Collaer)
>>>> Message: 1
>>>> Date: Sun, 7 Jun 2015 21:40:13 +0200
>>>> From: Simone Dalmasso <simone.dalmasso at gmail.com>
>>>> To: Vicente <deluca.vicente at gmail.com>
>>>> Cc: geonode-users <geonode-users at lists.osgeo.org>
>>>> Subject: Re: [GeoNode-users] osgeo module
>>>> install problem
>>>> Message-ID:
>>>> <CAAHAC+cU9GgbBUe-ocH4GJZ1PaXEZDrY5W=ZCsTzSUSx5ymVvA at mail.gmail.com>
>>>> Content-Type: text/plain; charset="utf-8"
>>>> Hi, you are missing the gdal python bindings, a
>>>> "pip install gdal" should
>>>> fix it.
>>>> Hope it helps, ciao
>>>> 2015-06-07 17:59 GMT+02:00 Vicente
>>>> <deluca.vicente at gmail.com>:
>>>> Good afternoon,
>>>> If I run the following line from my command
>>>> line, the answer is successful
>>>> $ sudo apt-get -y install libgdal1h
>>>> libgdal-dev python-gdal
>>>> But if I run from the session virtualenv,
>>>> the answer is No module named
>>>> osgeo.
>>>> I have just added the following session
>>>> variables in my .bashrc:
>>>> export VIRTUALENVWRAPPER_PYTHON = / usr /
>>>> bin / python
>>>> export WORKON_HOME = ~ / .venvs
>>>> source /usr/local/bin/virtualenvwrapper.sh
>>>> export PIP_DOWNLOAD_CACHE = $ HOME /
>>>> .pip-downloads
>>>> Both session with virtualenv or outside,
>>>> the python to run is the same,
>>>> Python 2.7.6 (default, Mar 22 2014, 22:59:56)
>>>> The result is that I can not run because
>>>> there is paver start the osgeo
>>>> module from within the session obviously.
>>>> Thanks!
>>>> [image: MANTA] <http://www.estudiomanta.com/>
>>>> Vicente Deluca
>>>> *+54 11 6091 4579
>>>> <tel:%2B54%2011%206091%204579>
>>>> <%2B54%2011%206091%204579>*
>>>> _______________________________________________
>>>> Message: 2
>>>> Date: Tue, 9 Jun 2015 09:01:34 -0500
>>>> From: Ariel Nunez <ingenieroariel at gmail.com>
>>>> To: FERRARI Hugo <ferrari_hugo at yahoo.fr>
>>>> Cc: "geonode-users at lists.osgeo.org"
>>>> Subject: Re: [GeoNode-users] developpement:
>>>> behavior and data visibility in Geonode
>>>> Message-ID:
>>>> <CALh6R-QDnFhFPgQdejPp0Kuh5NABLExo7ONaQWjhyb2hk3chEw at mail.gmail.com>
>>>> Hugo,
>>>> Based on what I understand, the best path forward
>>>> is to have a
>>>> view_metadata permission that you use to enforce
>>>> the behavior you want.
>>>> Assigning a new meaning to the existing permission
>>>> may be problematic for
>>>> other users with different needs (for example where
>>>> metadata is sensitive
>>>> information).
>>>> The place where we want to get to, is to allow
>>>> uploaders to restrict any
>>>> actions they want, but give the end user buttons to
>>>> request permissions (to
>>>> view if they cannot view, to download if they can
>>>> only view, to edit if the
>>>> can only download) to encourage a conversation
>>>> between uploaders and users
>>>> and provide a workflow to allow access to
>>>> information when it is needed.
>>>> The changes you make would be good candidates for
>>>> inclusion in the main
>>>> version of GeoNode so others can benefit in the
>>>> future. Hopefully others
>>>> (Paolo?) can chime in with more specific feedback.
>>>> Best,
>>>> Ariel.
>>>> On Tue, Jun 9, 2015 at 7:56 AM, FERRARI Hugo
>>>> <ferrari_hugo at yahoo.fr> wrote:
>>>> Hello everyone,
>>>> a developpement server.
>>>> make it fit the need of the
>>>> didn't manage to code it yet.
>>>> access.
>>>> layer-list page , not on the
>>>> layer-detail page .
>>>> get the layer detail so you
>>>> what will see is:
>>>> corresponding to layer_detail.html:
>>>> ressource (that means a template
>>>> geoexplorer frame you sould
>>>> possibility to retrieve
>>>> metadata).
>>>> visible in the layer list,
>>>> the layer detail.
>>>> to be the good way to
>>>> process.
>>>> geonode's database model because
>>>> of permissions, as far as I
>>>> can guess.
>>>> but just the
>>>> metadatas.
>>>> Hugo FERRARI
>>>> PS
>>>> software.
>>>> any other geonode users?
>>>> Wide Web, visit
>>>> or body 'help' to
>>>> line so it is more specific
>>>> Today's Topics:
>>>> (Simone Dalmasso)
>>>> Message: 1
>>>> Cc: geonode-users
>>>> install problem
>>>> Message-ID:
>>>> bindings, a "pip install gdal" should
>>>> fix it.
>>>> Hope it helps, ciao
>>>> Good afternoon,
>>>> command line, the answer is
>>>> successful
>>>> virtualenv, the answer is No module named
>>>> osgeo.
>>>> / bin / python
>>>> .pip-downloads
>>>> outside, the python to run is the same,
>>>> 22:59:56)
>>>> because there is paver start the osgeo
>>>> Thanks!
>>>> [image: MANTA]
>>>> Vicente Deluca
>>>> *+54 11 6091 4579
>>>> -------------- next part --------------
>>>> An HTML attachment was scrubbed...
>>>> URL:
>>>> <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150609/4dbe42d3/attachment-0001.html>
>>>> Message: 3
>>>> Date: Tue, 9 Jun 2015 16:50:01 +0200
>>>> From: Paolo Corti <pcorti at gmail.com>
>>>> To: Ariel Nunez <ingenieroariel at gmail.com>
>>>> Cc: FERRARI Hugo <ferrari_hugo at yahoo.fr>,
>>>> Message-ID:
>>>> <CAHXrU-JBaUUQUBz7BjsNuTkmOpOSLB7rxAaXEt3Qsn1TmKmvqw at mail.gmail.com>
>>>> Content-Type: text/plain; charset=UTF-8
>>>> Yes, Ariel is totally right.
>>>> Currently we don't have a specific permission for
>>>> viewing metadata.
>>>> This is implicit with the view_resourcebase
>>>> permission that gives
>>>> access to the data and metadata at the same time.
>>>> As suggested by Ariel you may consider to add a new
>>>> django guardian
>>>> permission at the resource base model, like it has
>>>> been done here [1]
>>>> and then have your GeoNode instance behaved
>>>> according to it in views,
>>>> templates and javascript.
>>>> I don't think there is an easy way to avoid forking
>>>> GeoNode and
>>>> customize the beahviour in your GeoNode project,
>>>> though it may be not
>>>> impossible and this would keep your instance easily
>>>> updateable with
>>>> mainstream code.
>>>> Even better, as Ariel suggested, you may though
>>>> fork it and send a PR
>>>> as it could be useful for others as well.
>>>> regards
>>>> p
>>>> [1]
>>>> https://github.com/GeoNode/geonode/blob/master/geonode/base/models.py#L648
>>>> On Tue, Jun 9, 2015 at 4:01 PM, Ariel Nunez
>>>> <ingenieroariel at gmail.com> wrote:
>>>> Hugo,
>>>> forward is to have a view_metadata
>>>> permission that you use to enforce the behavior
>>>> you want. Assigning a new
>>>> meaning to the existing permission may be
>>>> problematic for other users with
>>>> different needs (for example where metadata is
>>>> sensitive information).
>>>> buttons to request permissions (to
>>>> can only view, to edit if the
>>>> for inclusion in the main
>>>> Best,
>>>> Ariel.
>>>> Hello everyone,
>>>> instance on a developpement server.
>>>> to make it fit the need of the
>>>> data access.
>>>> layer-detail page .
>>>> you get the layer detail so you
>>>> what will see is:
>>>> view_resourcebase permission (who can see it
>>>> the geoexplorer frame you sould
>>>> metadata).
>>>> modify SKIP_PERMS_FILTERS in
>>>> module api/authorisation.py).
>>>> http error when trying to view
>>>> the layer detail.
>>>> seems to be the good way to
>>>> process.
>>>> the data (even if you can't
>>>> kind of permissions, as far as I
>>>> can guess.
>>>> error but just the
>>>> only metadatas.
>>>> Hugo FERRARI
>>>> PS
>>>> this software.
>>>> for any other geonode users?
>>>> submissions to
>>>> World Wide Web, visit
>>>> subject or body 'help' to
>>>> list at
>>>> digest..."
>>>> Today's Topics:
>>>> problem (Simone Dalmasso)
>>>> Geonode - Transifex - Portuguese
>>>> Message: 1
>>>> Cc: geonode-users
>>>> Message-ID:
>>>> fix it.
>>>> Hope it helps, ciao
>>>> Good afternoon,
>>>> successful
>>>> named
>>>> osgeo.
>>>> session variables in my .bashrc:
>>>> usr / bin / python
>>>> source
>>>> / .pip-downloads
>>>> 22:59:56)
>>>> obviously.
>>>> Thanks!
>>>> [image: MANTA]
>>>> Vicente Deluca
>>>> *+54 11 6091 4579
>>>> Simone
>>> Simone
> geonode-users at lists.osgeo.org <mailto:geonode-users at lists.osgeo.org>
> Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150617/02589a6d/attachment-0001.html>
More information about the geonode-users
