[GeoNode-users] Help geonode on windows raster layer publish
Miguel-Angel Manso-Callejo (UPM)
m.manso at upm.es
Wed Jun 17 04:36:49 PDT 2015
Dear all,
I have problems to publish raster layer on geonode 2.4(b25 and early) in
windows platform.
The file is published on geoserver (datastores, layer, style) but in
django geonode framework the process do not finish.
The log of apache web server is next.
Gdal is ok installed, and this not appear to be the problem.
Can any one help us to resolve this issue?
regards,
Miguel A. Manso
[Wed Jun 17 13:31:06.065807 2015] [wsgi:error] [pid 1504:tid 1232]
[Wed Jun 17 13:31:06.065807 2015] [wsgi:error] [pid 1504:tid 1232] File
"c:/GeoNode/GeoNode\\geonode\\upload\\views.py", line 604, in view
resp = _steps[step](req, upload_session)
"c:/GeoNode/GeoNode\\geonode\\upload\\views.py", line 495, in
final_step_view
saved_layer = upload.final_step(upload_session, req.user)
"c:/GeoNode/GeoNode\\geonode\\upload\\upload.py", line 567, in final_step
defaults=defaults
"c:\\GeoNode\\venv\\Lib\\site-packages\\django\\db\\models\\manager.py",
line 154, in get_or_create
return self.get_queryset().get_or_create(**kwargs)
"c:\\GeoNode\\venv\\Lib\\site-packages\\modeltranslation\\manager.py",
line 341, in get_or_create
return super(MultilingualQuerySet, self).get_or_create(**kwargs)
"c:\\GeoNode\\venv\\Lib\\site-packages\\django\\db\\models\\query.py",
line 383, in get_or_create
obj.save(force_insert=True, using=self.db)
"c:\\GeoNode\\venv\\Lib\\site-packages\\polymorphic\\polymorphic_model.py",
line 90, in save
return super(PolymorphicModel, self).save(*args, **kwargs)
"c:\\GeoNode\\venv\\Lib\\site-packages\\django\\db\\models\\base.py",
line 545, in save
force_update=force_update, update_fields=update_fields)
line 582, in save_base
update_fields=update_fields, raw=raw, using=using)
"c:\\GeoNode\\venv\\Lib\\site-packages\\django\\dispatch\\dispatcher.py", line
185, in send
response = receiver(signal=self, sender=sender, **named)
"c:/GeoNode/GeoNode\\geonode\\geoserver\\signals.py", line 465, in
geoserver_post_save
set_styles(instance, gs_catalog)
"c:/GeoNode/GeoNode\\geonode\\geoserver\\helpers.py", line 755, in
set_styles
layer.default_style = save_style(default_style)
"c:/GeoNode/GeoNode\\geonode\\geoserver\\helpers.py", line 770, in
save_style
style.sld_title = gs_style.sld_title
"c:\\GeoNode\\venv\\Lib\\site-packages\\geoserver\\style.py", line 49,
in sld_title
title_node = user_style.find("{http://www.opengis.net/sld}Title")
AttributeError: 'NoneType' object has no attribute 'find'
More information about the geonode-users
