[GeoNode-users] Help geonode on windows raster layer publish
Simone Dalmasso
simone.dalmasso at gmail.com
Wed Jun 17 04:47:38 PDT 2015
Hi seems to be an issue related to the layer style. Maybe the default style
has some issues.
2015-06-17 13:36 GMT+02:00 Miguel-Angel Manso-Callejo (UPM) <m.manso at upm.es>
> Dear all,
> I have problems to publish raster layer on geonode 2.4(b25 and early) in
> windows platform.
> The file is published on geoserver (datastores, layer, style) but in
> django geonode framework the process do not finish.
> The log of apache web server is next.
> Gdal is ok installed, and this not appear to be the problem.
> Can any one help us to resolve this issue?
> regards,
> Miguel A. Manso
> [Wed Jun 17 13:31:06.065807 2015] [wsgi:error] [pid 1504:tid 1232]
> Traceback (most recent call last):
> [Wed Jun 17 13:31:06.065807 2015] [wsgi:error] [pid 1504:tid 1232] File
> "c:/GeoNode/GeoNode\\geonode\\upload\\views.py", line 604, in view
> resp = _steps[step](req, upload_session)
> "c:/GeoNode/GeoNode\\geonode\\upload\\views.py", line 495, in
> final_step_view
> saved_layer = upload.final_step(upload_session, req.user)
> "c:/GeoNode/GeoNode\\geonode\\upload\\upload.py", line 567, in final_step
> defaults=defaults
> "c:\\GeoNode\\venv\\Lib\\site-packages\\django\\db\\models\\manager.py",
> line 154, in get_or_create
> return self.get_queryset().get_or_create(**kwargs)
> "c:\\GeoNode\\venv\\Lib\\site-packages\\modeltranslation\\manager.py", line
> 341, in get_or_create
> return super(MultilingualQuerySet, self).get_or_create(**kwargs)
> "c:\\GeoNode\\venv\\Lib\\site-packages\\django\\db\\models\\query.py", line
> 383, in get_or_create
> obj.save(force_insert=True, using=self.db)
> "c:\\GeoNode\\venv\\Lib\\site-packages\\polymorphic\\polymorphic_model.py",
> line 90, in save
> return super(PolymorphicModel, self).save(*args, **kwargs)
> "c:\\GeoNode\\venv\\Lib\\site-packages\\django\\db\\models\\base.py", line
> 545, in save
> force_update=force_update, update_fields=update_fields)
> 582, in save_base
> update_fields=update_fields, raw=raw, using=using)
> "c:\\GeoNode\\venv\\Lib\\site-packages\\django\\dispatch\\dispatcher.py",
> line 185, in send
> response = receiver(signal=self, sender=sender, **named)
> "c:/GeoNode/GeoNode\\geonode\\geoserver\\signals.py", line 465, in
> geoserver_post_save
> set_styles(instance, gs_catalog)
> "c:/GeoNode/GeoNode\\geonode\\geoserver\\helpers.py", line 755, in
> set_styles
> layer.default_style = save_style(default_style)
> "c:/GeoNode/GeoNode\\geonode\\geoserver\\helpers.py", line 770, in
> save_style
> style.sld_title = gs_style.sld_title
> "c:\\GeoNode\\venv\\Lib\\site-packages\\geoserver\\style.py", line 49, in
> sld_title
> title_node = user_style.find("{http://www.opengis.net/sld}Title")
> AttributeError: 'NoneType' object has no attribute 'find'
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150617/1334fe28/attachment.html>
More information about the geonode-users
