[GeoNode-users] Cannot find /var/lib/geonode/ to get templates
GC-54 nepanode at gmail.com
Wed Jun 17 14:51:52 PDT 2015
First things first - when making reference to documentation please provide
a link to where you encountered this as there is a developers customization
and admin customization depending on how you've deployed geonode...
Second tip is to use these linux commands when looking for a file or
directory:
$ sudo updatedb
$ sudo locate {name} | less
*Those two lines will usually do the trick if your looking for a specific
file or directory just replace {name} with whatever file/dir/path your
looking for...
*But for what you're looking for the directory geonode is deployed her*e:
/usr/local/lib/python2.7/dist-packages/geonode/templates/
?Did you already setup your geonode=project within a virtualenvironment?
On Wed, Jun 17, 2015 at 8:54 AM, William Francis <
william.francis.james at gmail.com> wrote:
> Hello,
> I am following the Customizing the geonode instructions and looking for
> the template files to copy to etc/geonode/templates
> e.g.
> /var/lib/geonode/src/GeoNodePy/geonode/templates/index.html
> However the directory  /var/lib/geonode/ doesn't exist.
> Where can I find a copy of these templates?
> I am using v*ersion 2.4b25*  of geonode.
> Thank you.
> Will
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150617/7393f1ae/attachment.html>
More information about the geonode-users mailing list
