[GeoNode-users] Cannot find /var/lib/geonode/ to get templates
William Francis william.francis.james at gmail.com
Thu Jun 18 04:59:25 PDT 2015
Thank you GC-45
Yes, that helps.
The geonode is already deployed. I am following the documentation for
Customizing the look and feel of the Geonode
https://geonode.readthedocs.org/en/1.2/deploy/customize.html
On Thu, Jun 18, 2015 at 4:21 AM, GC-54 <nepanode at gmail.com> wrote:
> First things first - when making reference to documentation please provide
> a link to where you encountered this as there is a developers customization
> and admin customization depending on how you've deployed geonode...
> Second tip is to use these linux commands when looking for a file or
> directory:
> $ sudo updatedb
> $ sudo locate {name} | less
> *Those two lines will usually do the trick if your looking for a specific
> file or directory just replace {name} with whatever file/dir/path your
> looking for...
> *But for what you're looking for the directory geonode is deployed her*e:
> /usr/local/lib/python2.7/dist-packages/geonode/templates/
> ?Did you already setup your geonode=project within a virtualenvironment?
> On Wed, Jun 17, 2015 at 8:54 AM, William Francis <
> william.francis.james at gmail.com> wrote:
>> Hello,
>> I am following the Customizing the geonode instructions and looking for
>> the template files to copy to etc/geonode/templates
>> e.g.
>> /var/lib/geonode/src/GeoNodePy/geonode/templates/index.html
>> However the directory  /var/lib/geonode/ doesn't exist.
>> Where can I find a copy of these templates?
>> I am using v*ersion 2.4b25*  of geonode.
>> Thank you.
>> Will
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150618/2660d001/attachment.html>
More information about the geonode-users mailing list
