[GeoNode-users] Create new filter for layers
Melvin Ramos
melvin.ramos1991 at gmail.com
Thu Jun 18 14:17:35 PDT 2015
Hello,
I'm trying to duplicate the Categories filter, because I'm need to use a
new set of categories for my layers, but I'm having a hard time trying to
find out how the templates gets the data since it uses AngularJS.
So here is what I''ve done so far:
*Modified the models.py of the Base app*
I added a new class called IUCNCategory
> *class IUCNCategory(models.Model): """ Metadata regarding IUCN
> standards """ identifier = models.CharField(max_length=255)
> category_type = models.CharField( choices=(
> ('risk_criteria', 'Risk Criteria'), ('bio_realm',
> 'Biogeographical Realm'), ('typology', 'Typology') ),
> max_length=255, ) description = models.TextField(default='')
> gn_description = models.TextField('RLE description', default='',
> null=True) # is_choice = models.BooleanField(default=True) def
> __unicode__(self): return u"{0}".format(self.gn_description)
> class Meta: ordering = ("category_type","identifier",)
> verbose_name_plural = 'IUCN Categories'*
It's just like TopicCategory with one different attribute.
I added to the class ResourceBase the following attribute
*iucn_category = models.ForeignKey(IUCNCategory, null=True, blank=True)*
*Modified the api.py **of the Api app*
I created a new class called IUCNCategoryResource
> *class IUCNCategoryResource(TypeFilteredResource):** """IUCN Category
> api"""*
> * def serialize(self, request, data, format, options={}):**
> options['count_type'] = 'iucn_category'*
> * return super(IUCNCategoryResource, self).serialize(request, data,
> format, options)*
> * class Meta:*
> * queryset = IUCNCategory.objects.all()*
> * resource_name = 'iucn_categories'*
> * allowed_methods = ['get']*
> * filtering = {*
> * 'identifier': ALL,*
> * }** serializer = CountJSONSerializer()*
It's like the class TopicCategoryResource
*Modified the* *resourcebase_api.py **of the Api app*
I added to the class CommonModelApi the following attribute
> *iucn_category = fields.ToOneField( IUCNCategoryResource,
> 'iucn_category', null=True, full=True)*
In the definition on the Haystack filters I added the following in the
proper places:
> *...iucn_category =
> parameters.getlist("iucn_category__identifier__in")...if iucn_category:
> sqs = (SearchQuerySet() if sqs is None else sqs).narrow(
> 'iucn_category:%s' % ','.join(map(str, iucn_category)))...*
Just like the category field.
*Modified the** urls**.py **of the Api app*
I imported the IUCNCategoryResource from the apy.py and wrote
*api.register(IUCNCategoryResource())*
*Modified the template _general_filters.html inside the search templates*
I added the following code
> *<nav class="filter">*
> * <h4><a href="#" class="toggle toggle-nav"><i class="fa
> fa-chevron-right"></i>{% trans "Risk Criteria" %}</a></h4>*
> * <ul class="nav closed" id="iucn_categories">*
> * {% verbatim %}*
> * <li ng-repeat="iucn_category in iucn_categories"
> ng-if="iucn_category.count > 0">*
> * <a data-value="{{ iucn_category.identifier }}"
> data-filter="iucn_category__identifier__in" *
> * ng-click="multiple_choice_listener($event)"
> class="{{iucn_category.active}}">{{ iucn_category.gn_description | limitTo:
> 25 }}{{ iucn_category.gn_description.length > 25 ? '...' : ''}}*
> * <span class="badge pull-right">{{ iucn_category.count }}</span>*
> * </a>*
> * </li>*
> * {% endverbatim %}*
> * </ul>**</nav>*
But nothing shows beneath the filter name in the template, even when I have
one IUCN category stored in database. I'm guessing there is a view
somewhere or I'm missing something that allows to pass the data and I can't
find it or just Angular is too mystic for me.
Can anybody help me?
Thanks in advance,
Melvin
Melvin David Ramos Macías
07-41408
Ingeniería de Computación
Universidad Simón Bolívar
Enviado con MailTrack
<https://mailtrack.io/install?source=signature&lang=es&referral=melvin.ramos1991@gmail.com&idSignature=23>
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150618/668ad578/attachment.html>
More information about the geonode-users
