[GeoNode-users] Separating layers by projects
Simone Dalmasso
simone.dalmasso at gmail.com
Thu Jun 18 23:48:10 PDT 2015
Yeah the Francesco idea is very similar to the sites one. The groups can be
used also, you have to take care if them across all instances while the
sites are born exactly for that purpose. And the change to the API is
minimal.
Il venerdì 19 giugno 2015, Francesco Bartoli <xbartolone at gmail.com> ha
scritto:
> Hi,
> why not exploiting the capabilities of haystack with SearchIndex and
> filters based on fields [1]? This would mean to alter the model of layers
> by adding a project field that would be used with the indexed document.
> Theoretically this could work, never tried though.
> Regards,
> Francesco
> [1] http://django-haystack.readthedocs.org/en/latest/searchindex_api.html
> Il giorno 18/giu/2015, alle ore 18:30, John Jediny <john.jediny at gmail.com
> <javascript:_e(%7B%7D,'cvml','john.jediny at gmail.com');>> ha scritto:
> Simone/Jeff,
> Is there an advantage to using the contrib model over using a filter on
> the api to list resources the group has permissions over?
> On Thursday, June 18, 2015, Simone Dalmasso <simone.dalmasso at gmail.com
> <javascript:_e(%7B%7D,'cvml','simone.dalmasso at gmail.com');>> wrote:
>> Hi Daniel, this would require some development, and you could use this
>> https://docs.djangoproject.com/en/1.8/ref/contrib/sites/
>> 2015-06-18 14:06 GMT+02:00 Daniel Victoria <daniel.victoria at gmail.com>:
>>> Hi List,
>>> Very simple question regarding the usual practices with geonode. We are
>>> using GeoNode to catalog data from several projects and we'd like to be
>>> able to do a search based on each project, i.e. all layers related to
>>> project X. My initial feeling was to implement this using the keywords.
>>> Does that sound reasonable? Or is there a better way? A colleague suggested
>>> using groups by project. Would that be a better option? O groups are more
>>> specific for user management and not intended for that?
>>> Thanks
>>> Daniel
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
>> Simone
> Cell: 973-931-0580
> <javascript:_e(%7B%7D,'cvml','geonode-users at lists.osgeo.org');>
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150619/66730d52/attachment.html>
More information about the geonode-users
