[GeoNode-users] Unable to find package geonode - Ubuntu 14.04.2 LTS
Simone Dalmasso
simone.dalmasso at gmail.com
Tue Jun 30 07:20:05 PDT 2015
Hi Natalia,
strange error. did you see any issues during the installation?
did you install it with:
sudo add-apt-repository ppa:geonode/testing
sudo apt-get update
sudo apt-get install geonode
2015-06-30 16:14 GMT+02:00 Natalia Queiroz <queiroz.nati at gmail.com>:
> Thanks Jeffrey.
> After the installation I', facing an error when I try to create a superuser
> $ geonode createsuperuser
> Traceback (most recent call last):
> File "/usr/bin/django-admin", line 5, in <module>
> management.execute_from_command_line()
> File
> "/usr/lib/python2.7/dist-packages/django/core/management/__init__.py", line
> 399, in execute_from_command_line
> utility.execute()
> File
> 392, in execute
> self.fetch_command(subcommand).run_from_argv(self.argv)
> File
> 261, in fetch_command
> commands = get_commands()
> File
> 107, in get_commands
> apps = settings.INSTALLED_APPS
> File "/usr/lib/python2.7/dist-packages/django/conf/__init__.py", line
> 54, in __getattr__
> self._setup(name)
> 49, in _setup
> self._wrapped = Settings(settings_module)
> 132, in __init__
> % (self.SETTINGS_MODULE, e)
> ImportError: Could not import settings 'geonode.settings' (Is it on
> sys.path? Is there an import error in the settings file?): No module named
> geonode.settings
> Any idea?
> On Mon, Jun 29, 2015 at 9:07 PM, Jeffrey Johnson <ortelius at gmail.com>
> wrote:
>> Do you intend to use the 2.0 release? Im guessing you are on 14.04 and
>> the release (2.0) is only on 12.04. You should use the snapshots ppa
>> (sudo add-apt-repository ppa:geonode/snapshots) and then sudo apt-get
>> update and sudo apt-get install geonode again.
>> On Mon, Jun 29, 2015 at 5:04 PM, Natalia Queiroz <queiroz.nati at gmail.com>
>> wrote:
>> > Hello,
>> > I'm trying to follow the quick reference guide to install geonode on my
>> > Ubuntu 14.04.2 LTS server using ppa repository but I'm facing an E:
>> Unable
>> > to find the geonode package error message after the install command
>> (sudo
>> > apt-get install geonode).
>> > There where the steps:
>> > sudo apt-get install software-properties-common
>> > sudo add-apt-repository ppa:geonode/release
>> > sudo apt-get update
>> > Any ideia?
>> > Thanks
>> > Natália Oliveira
>> > _______________________________________________
>> > geonode-users mailing list
>> > geonode-users at lists.osgeo.org
>> > http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
> Natália Oliveira
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150630/5aca808b/attachment-0001.html>
More information about the geonode-users
