[GeoNode-users] Unable to find package geonode - Ubuntu 14.04.2 LTS
Natalia Queiroz
queiroz.nati at gmail.com
Tue Jun 30 07:24:00 PDT 2015
Hello Simone, no error during the installation.
Follow the steps done:
sudo add-apt-repository ppa:geonode/snapshots
sudo apt-get update
sudo apt-get install geonode
On Tue, Jun 30, 2015 at 11:20 AM, Simone Dalmasso <simone.dalmasso at gmail.com
> wrote:
> Hi Natalia,
> strange error. did you see any issues during the installation?
> did you install it with:
> sudo add-apt-repository ppa:geonode/testing
> sudo apt-get update
> 2015-06-30 16:14 GMT+02:00 Natalia Queiroz <queiroz.nati at gmail.com>:
>> Thanks Jeffrey.
>> After the installation I', facing an error when I try to create a
>> superuser
>> $ geonode createsuperuser
>> Traceback (most recent call last):
>> File "/usr/bin/django-admin", line 5, in <module>
>> management.execute_from_command_line()
>> File
>> "/usr/lib/python2.7/dist-packages/django/core/management/__init__.py", line
>> 399, in execute_from_command_line
>> utility.execute()
>> File
>> 392, in execute
>> self.fetch_command(subcommand).run_from_argv(self.argv)
>> File
>> 261, in fetch_command
>> commands = get_commands()
>> File
>> 107, in get_commands
>> apps = settings.INSTALLED_APPS
>> File "/usr/lib/python2.7/dist-packages/django/conf/__init__.py", line
>> 54, in __getattr__
>> self._setup(name)
>> 49, in _setup
>> self._wrapped = Settings(settings_module)
>> 132, in __init__
>> % (self.SETTINGS_MODULE, e)
>> ImportError: Could not import settings 'geonode.settings' (Is it on
>> sys.path? Is there an import error in the settings file?): No module named
>> geonode.settings
>> Any idea?
>> On Mon, Jun 29, 2015 at 9:07 PM, Jeffrey Johnson <ortelius at gmail.com>
>> wrote:
>>> Do you intend to use the 2.0 release? Im guessing you are on 14.04 and
>>> the release (2.0) is only on 12.04. You should use the snapshots ppa
>>> (sudo add-apt-repository ppa:geonode/snapshots) and then sudo apt-get
>>> update and sudo apt-get install geonode again.
>>> On Mon, Jun 29, 2015 at 5:04 PM, Natalia Queiroz <queiroz.nati at gmail.com>
>>> wrote:
>>> > Hello,
>>> > I'm trying to follow the quick reference guide to install geonode on my
>>> > Ubuntu 14.04.2 LTS server using ppa repository but I'm facing an E:
>>> Unable
>>> > to find the geonode package error message after the install command
>>> (sudo
>>> > apt-get install geonode).
>>> > There where the steps:
>>> > sudo apt-get install software-properties-common
>>> > sudo add-apt-repository ppa:geonode/release
>>> > sudo apt-get update
>>> > Any ideia?
>>> > Thanks
>>> > Natália Oliveira
>>> > _______________________________________________
>>> > geonode-users mailing list
>>> > geonode-users at lists.osgeo.org
>>> > http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
>> Natália Oliveira
> Simone
Natália Oliveira
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150630/27c8a4c9/attachment.html>
More information about the geonode-users
