[GeoNode-users] Unable to find package geonode - Ubuntu 14.04.2LTS
Simone Dalmasso simone.dalmasso at gmail.com
Tue Jun 30 07:35:19 PDT 2015
Thanks Vladimiro. snapshots will be fixed very soon
2015-06-30 16:33 GMT+02:00 Vladimiro Bellini <vlasvlasvlas at gmail.com>:
> I also has installation issues before.
> Maybe a warning must be informed at snapshots download site & installation
> steps page..
> De: Simone Dalmasso <simone.dalmasso at gmail.com>
> Enviado el: ‎30/‎06/‎2015 11:27 a. m.
> Para: Natalia Queiroz <queiroz.nati at gmail.com>
> CC: geonode-users <geonode-users at lists.osgeo.org>
> Asunto: Re: [GeoNode-users] Unable to find package geonode - Ubuntu
> 14.04.2LTS
> Natalia, please use ppa:geonode/testing on a fresh machine for the moment
> as snapshots has some issues.
> Apologize for this.
> 2015-06-30 16:24 GMT+02:00 Natalia Queiroz <queiroz.nati at gmail.com>:
>> Hello Simone, no error during the installation.
>> Follow the steps done:
>> sudo add-apt-repository ppa:geonode/snapshots
>> sudo apt-get update
>> sudo apt-get install geonode
>> On Tue, Jun 30, 2015 at 11:20 AM, Simone Dalmasso <
>> simone.dalmasso at gmail.com> wrote:
>>> Hi Natalia,
>>> strange error. did you see any issues during the installation?
>>> did you install it with:
>>>  sudo add-apt-repository ppa:geonode/testing
>>>  sudo apt-get update
>>> 2015-06-30 16:14 GMT+02:00 Natalia Queiroz <queiroz.nati at gmail.com>:
>>>> Thanks Jeffrey.
>>>> After the installation I', facing an error when I try to create a
>>>> superuser
>>>> $ geonode createsuperuser
>>>> Traceback (most recent call last):
>>>>   File "/usr/bin/django-admin", line 5, in <module>
>>>>     management.execute_from_command_line()
>>>>   File
>>>> "/usr/lib/python2.7/dist-packages/django/core/management/__init__.py", line
>>>> 399, in execute_from_command_line
>>>>     utility.execute()
>>>>   File
>>>> 392, in execute
>>>>     self.fetch_command(subcommand).run_from_argv(self.argv)
>>>>   File
>>>> 261, in fetch_command
>>>>     commands = get_commands()
>>>>   File
>>>> 107, in get_commands
>>>>     apps = settings.INSTALLED_APPS
>>>>   File "/usr/lib/python2.7/dist-packages/django/conf/__init__.py", line
>>>> 54, in __getattr__
>>>>     self._setup(name)
>>>> 49, in _setup
>>>>     self._wrapped = Settings(settings_module)
>>>> 132, in __init__
>>>>     % (self.SETTINGS_MODULE, e)
>>>> ImportError: Could not import settings 'geonode.settings' (Is it on
>>>> sys.path? Is there an import error in the settings file?): No module named
>>>> geonode.settings
>>>> Any idea?
>>>> On Mon, Jun 29, 2015 at 9:07 PM, Jeffrey Johnson <ortelius at gmail.com>
>>>> wrote:
>>>>> Do you intend to use the 2.0 release? Im guessing you are on 14.04 and
>>>>> the release (2.0) is only on 12.04. You should use the snapshots ppa
>>>>> (sudo add-apt-repository ppa:geonode/snapshots) and then sudo apt-get
>>>>> update and sudo apt-get install geonode again.
>>>>> On Mon, Jun 29, 2015 at 5:04 PM, Natalia Queiroz <
>>>>> queiroz.nati at gmail.com> wrote:
>>>>> > Hello,
>>>>> > I'm trying to follow the quick reference guide to install geonode on
>>>>> my
>>>>> > Ubuntu 14.04.2 LTS server using ppa repository but I'm facing an E:
>>>>> Unable
>>>>> > to find the geonode package error message after the install command
>>>>> (sudo
>>>>> > apt-get install geonode).
>>>>> > There where the steps:
>>>>> > sudo apt-get install software-properties-common
>>>>> > sudo add-apt-repository ppa:geonode/release
>>>>> > sudo apt-get update
>>>>> > Any ideia?
>>>>> > Thanks
>>>>> > Natália Oliveira
>>>>> > _______________________________________________
>>>>> > geonode-users mailing list
>>>>> > http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
>>>> Natália Oliveira
>>> Simone
>> Natália Oliveira
> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150630/10691e7e/attachment.html>
More information about the geonode-users mailing list
