[GeoNode-users] Unable to find package geonode - Ubuntu 14.04.2LTS
Simone Dalmasso
simone.dalmasso at gmail.com
Tue Jun 30 08:16:32 PDT 2015
Ok, thanks all for your feedbacks, starting from tomorrow morning the
snapshots ppa should be up and error free.
Ciao
2015-06-30 16:35 GMT+02:00 Simone Dalmasso <simone.dalmasso at gmail.com>:
> Thanks Vladimiro. snapshots will be fixed very soon
> 2015-06-30 16:33 GMT+02:00 Vladimiro Bellini <vlasvlasvlas at gmail.com>:
>> I also has installation issues before.
>> Maybe a warning must be informed at snapshots download site &
>> installation steps page..
>> De: Simone Dalmasso <simone.dalmasso at gmail.com>
>> Enviado el: 30/06/2015 11:27 a. m.
>> Para: Natalia Queiroz <queiroz.nati at gmail.com>
>> CC: geonode-users <geonode-users at lists.osgeo.org>
>> Asunto: Re: [GeoNode-users] Unable to find package geonode - Ubuntu
>> 14.04.2LTS
>> Natalia, please use ppa:geonode/testing on a fresh machine for the moment
>> as snapshots has some issues.
>> Apologize for this.
>> 2015-06-30 16:24 GMT+02:00 Natalia Queiroz <queiroz.nati at gmail.com>:
>>> Hello Simone, no error during the installation.
>>> Follow the steps done:
>>> sudo add-apt-repository ppa:geonode/snapshots
>>> sudo apt-get update
>>> sudo apt-get install geonode
>>> On Tue, Jun 30, 2015 at 11:20 AM, Simone Dalmasso <
>>> simone.dalmasso at gmail.com> wrote:
>>>> Hi Natalia,
>>>> strange error. did you see any issues during the installation?
>>>> did you install it with:
>>>> sudo add-apt-repository ppa:geonode/testing
>>>> sudo apt-get update
>>>> 2015-06-30 16:14 GMT+02:00 Natalia Queiroz <queiroz.nati at gmail.com>:
>>>>> Thanks Jeffrey.
>>>>> After the installation I', facing an error when I try to create a
>>>>> superuser
>>>>> $ geonode createsuperuser
>>>>> Traceback (most recent call last):
>>>>> File "/usr/bin/django-admin", line 5, in <module>
>>>>> management.execute_from_command_line()
>>>>> File
>>>>> "/usr/lib/python2.7/dist-packages/django/core/management/__init__.py", line
>>>>> 399, in execute_from_command_line
>>>>> utility.execute()
>>>>> File
>>>>> 392, in execute
>>>>> self.fetch_command(subcommand).run_from_argv(self.argv)
>>>>> File
>>>>> 261, in fetch_command
>>>>> commands = get_commands()
>>>>> File
>>>>> 107, in get_commands
>>>>> apps = settings.INSTALLED_APPS
>>>>> File "/usr/lib/python2.7/dist-packages/django/conf/__init__.py",
>>>>> line 54, in __getattr__
>>>>> self._setup(name)
>>>>> line 49, in _setup
>>>>> self._wrapped = Settings(settings_module)
>>>>> line 132, in __init__
>>>>> % (self.SETTINGS_MODULE, e)
>>>>> ImportError: Could not import settings 'geonode.settings' (Is it on
>>>>> sys.path? Is there an import error in the settings file?): No module named
>>>>> geonode.settings
>>>>> Any idea?
>>>>> On Mon, Jun 29, 2015 at 9:07 PM, Jeffrey Johnson <ortelius at gmail.com>
>>>>> wrote:
>>>>>> Do you intend to use the 2.0 release? Im guessing you are on 14.04 and
>>>>>> the release (2.0) is only on 12.04. You should use the snapshots ppa
>>>>>> (sudo add-apt-repository ppa:geonode/snapshots) and then sudo apt-get
>>>>>> update and sudo apt-get install geonode again.
>>>>>> On Mon, Jun 29, 2015 at 5:04 PM, Natalia Queiroz <
>>>>>> queiroz.nati at gmail.com> wrote:
>>>>>> > Hello,
>>>>>> > I'm trying to follow the quick reference guide to install geonode
>>>>>> on my
>>>>>> > Ubuntu 14.04.2 LTS server using ppa repository but I'm facing an E:
>>>>>> Unable
>>>>>> > to find the geonode package error message after the install command
>>>>>> (sudo
>>>>>> > apt-get install geonode).
>>>>>> > There where the steps:
>>>>>> > sudo apt-get install software-properties-common
>>>>>> > sudo add-apt-repository ppa:geonode/release
>>>>>> > sudo apt-get update
>>>>>> > Any ideia?
>>>>>> > Thanks
>>>>>> > Natália Oliveira
>>>>>> > _______________________________________________
>>>>>> > geonode-users mailing list
>>>>>> > http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
>>>>> Natália Oliveira
>>>> Simone
>>> Natália Oliveira
>> Simone
> Simone
Simone
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150630/e2fb0b6b/attachment-0001.html>
More information about the geonode-users
