[GeoNode-users] Problems after Upgrade
Le Ny Conseil
lenyconseil at gmail.com
Tue Mar 17 02:31:04 PDT 2015
You have got the ALLOWED_HOSTS section at the end of the same file
(local_settings.py).
2015-03-17 10:28 GMT+01:00 Christian Willmes <
christian.willmes at googlemail.com>:
> thanks! That solved the PostGIS problem.
> I now need to add my server to ALLOWED_HOSTS:
> [Tue Mar 17 04:24:02.116194 2015] [:error] [pid 1224:tid 140153217300224]
> Invalid HTTP_HOST header: 'localhost'.You may need to add u'localhost' to
> ALLOWED_HOSTS.
> I did set the SITEURL in local_settings.py as before the update.
> Where is that to configure?
> Thanks,
> Christian
> Am 17.03.2015 um 10:09 schrieb Le Ny Conseil:
> Hello Christian,
> Add this line in your geonode local_settings
> POSTGIS_VERSION = (2,1,0)
> 2015-03-17 10:03 GMT+01:00 Christian Willmes <
>> Hi,
>> im running a geonode 2.4beta from the testing Ubuntu ppa.
>> After a apt-get update/upgrade this morning, I can't get geonode to
>> restart.
>> I have this (scary) message in my logs:
>> [Tue Mar 17 03:59:59.676955 2015] [:error] [pid 1671:tid 139799543056128]
>> [remote 127.0.0.1:60324] ImproperlyConfigured: Cannot determine PostGIS
>> version for database "geonode_data". GeoDjango requires at least PostGIS
>> version 1.3. Was the database created from a spatial database template?
>> Any hints, how to solve this?
>> Interesting though, that on commandline 'geonode updatelayers' seems to
>> execute without errors. But it dit not solve the above problem.
>> Thanks,
>> Christian
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
> Pierre-André Le Ny
> *Le Ny Conseil*
> http://www.lenyconseil.fr
> geonode-users mailing listgeonode-users at lists.osgeo.orghttp://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
Pierre-André Le Ny
*Le Ny Conseil*
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150317/1cc9c49a/attachment.html>
More information about the geonode-users
