[GeoNode-users] Problems after Upgrade
Christian Willmes christian.willmes at googlemail.com
Tue Mar 17 02:36:41 PDT 2015
ah great. Thanks!
I was blind looking for that line in local_settings.py, did not see it...
Pro tip: do not let the upgrade procedure overwrite your settings file,
when it asks you to apply changes from the updated package. :^)
Cheers,
Christian
Am 17.03.2015 um 10:31 schrieb Le Ny Conseil:
> You have got the ALLOWED_HOSTS section at the end of the same file
> (local_settings.py).
> 2015-03-17 10:28 GMT+01:00 Christian Willmes
> <christian.willmes at googlemail.com
> <mailto:christian.willmes at googlemail.com>>:
>     thanks! That solved the PostGIS problem.
>     I now need to add my server to ALLOWED_HOSTS:
>     [Tue Mar 17 04:24:02.116194 2015] [:error] [pid 1224:tid
>     140153217300224] Invalid HTTP_HOST header: 'localhost'.You may
>     need to add u'localhost' to ALLOWED_HOSTS.
>     I did set the SITEURL in local_settings.py as before the update.
>     Where is that to configure?
>     Thanks,
>     Christian
>     Am 17.03.2015 um 10:09 schrieb Le Ny Conseil:
>>     Hello Christian,
>>     Add this line in your geonode local_settings
>>     POSTGIS_VERSION = (2,1,0)
>>     2015-03-17 10:03 GMT+01:00 Christian Willmes
>>         Hi,
>>         im running a geonode 2.4beta from the testing Ubuntu ppa.
>>         After a apt-get update/upgrade this morning, I can't get
>>         geonode to restart.
>>         I have this (scary) message in my logs:
>>         [Tue Mar 17 03:59:59.676955 2015] [:error] [pid 1671:tid
>>         139799543056128] [remote 127.0.0.1:60324
>>         <http://127.0.0.1:60324>] ImproperlyConfigured: Cannot
>>         determine PostGIS version for database "geonode_data".
>>         GeoDjango requires at least PostGIS version 1.3. Was the
>>         database created from a spatial database template?
>>         Any hints, how to solve this?
>>         Interesting though, that on commandline 'geonode
>>         updatelayers' seems to execute without errors. But it dit not
>>         solve the above problem.
>>         Thanks,
>>         Christian
>>         _______________________________________________
>>         geonode-users mailing list
>>         geonode-users at lists.osgeo.org
>>         <mailto:geonode-users at lists.osgeo.org>
>>         http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
>>     Pierre-André Le Ny
>>     *Le Ny Conseil*
>>     http://www.lenyconseil.fr
>>     geonode-users at lists.osgeo.org  <mailto:geonode-users at lists.osgeo.org>
> Pierre-André Le Ny
> *Le Ny Conseil*
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150317/1fb39ae8/attachment-0001.html>
More information about the geonode-users mailing list
