[GeoNode-users] Customizing a geonode 2.4 project
Francesco Bartoli xbartolone at gmail.com
Tue Mar 24 14:50:26 PDT 2015
I mean the local_settings.sample that comes with geonode source. I installed from that into an ubuntu 12.04 box. If you want just to customize a plain geonode you shouldn’t have the need of the geonode_project template. This should be used for adding a new geonode based application like the zinnia blog explained in the documentation.
Hope this clarifies.
Ciao
F.
Il giorno 24/mar/2015, alle ore 22:40, GC-54 <nepanode at gmail.com> ha scritto:
> the local_settings.sample that comes with geonode_project shouldn't be used... instead you want to copy the local_settings.py from the newly installed geonode.
> to find it run
> $ sudo updatedb
> $ sudo locate local_settings
> ... (should find it in the .../python2.7/dist-packages/... dir)
> On Tue, Mar 24, 2015 at 5:32 PM, Francesco Bartoli <xbartolone at gmail.com> wrote:
> I did it yesterday and I can confirm that you find the local_settings sample file to be edited. I downloaded the beta22 tag from github.
> Francesco Bartoli
> Il giorno 24/mar/2015, alle ore 21:18, Le Ny Conseil <lenyconseil at gmail.com> ha scritto:
>> Thank you for notes.
>> But it doesn't work. Following the procedure, only thing disturb me. I haven't got a local_settings.py.sample file so i cant' do that : Rename the local_settings.py.sample to local_settings.py and edit it's content by setting the SITEURL and SITENAME
>> My site displays a 404 error.
>> Any idea ?
>> 2015-03-24 6:04 GMT+01:00 GC-54 <nepanode at gmail.com>:
>> The documentation for running a django project wrapper/skeleton hasn't been updated for use with 2.4 but after doing it realized it comes down to using an upstream version tag for the geonode-project github repo ... as an interim I took some notes on what I did to get Geonode 2.4b20+ running and customized on Ubuntu 14.04. Hope this helps, if there are any gaps let me know:
>> https://github.com/DOE-NEPA/NEPAnode/wiki/Migrating-Current-NEPAnode-Site
>> On Mon, Mar 23, 2015 at 8:08 AM, Le Ny Conseil <lenyconseil at gmail.com> wrote:
>> Hello Annalisa and dear list members,
>> I'm particulary interested in this topic because i've tried few weeks ago to customize the look&feel of Geonode 2.4b22 without success.
>> Not sure that the documentation be up to date.
>> I have tried to replace my_geonode by a new template name, a new folder was created in my home folder but i've never succeed to visualize my geonode with the new templates.
>> Is there here a committer who could tell us more about this important point ?
>> Thanks,
>> Happy spring day to everybody.
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
>> Pierre-André Le Ny
>> Le Ny Conseil
>> http://www.lenyconseil.fr
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150324/ade8b6c7/attachment.html>
More information about the geonode-users mailing list
