[GeoNode-users] Customizing a geonode 2.4 project
Le Ny Conseil lenyconseil at gmail.com
Tue Mar 24 15:17:42 PDT 2015
Sorry, i'm a little bit lost.
I've installed geonode on ubuntu 14.04 with apt and the ppa:testing package
repository.
Version 2.4b22.
I didn't create virtualenv (I didn't follow this step : Installed
Geonode_Project template for Isolation and Customization in
Virtualenvironment). Maybe, it is the reason ?
I haven't got found this local_settings.py.sample.
I'm a disappointed now on this look&feel customization.
Thanks for your suggestions.
2015-03-24 22:50 GMT+01:00 Francesco Bartoli <xbartolone at gmail.com>:
> I mean the local_settings.sample that comes with geonode source. I
> installed from that into an ubuntu 12.04 box. If you want just to customize
> a plain geonode you shouldn’t have the need of the geonode_project
> template. This should be used for adding a new geonode based application
> like the zinnia blog explained in the documentation.
> Hope this clarifies.
> Ciao
> F.
> Il giorno 24/mar/2015, alle ore 22:40, GC-54 <nepanode at gmail.com> ha
> scritto:
> the local_settings.sample that comes with geonode_project shouldn't be
> used... instead you want to copy the local_settings.py from the newly
> installed geonode.
> to find it run
> $ sudo updatedb
> $ sudo locate local_settings
> ... (should find it in the .../python2.7/dist-packages/... dir)
> On Tue, Mar 24, 2015 at 5:32 PM, Francesco Bartoli <xbartolone at gmail.com>
> wrote:
>> I did it yesterday and I can confirm that you find the local_settings
>> sample file to be edited. I downloaded the beta22 tag from github.
>> Francesco Bartoli
>> Il giorno 24/mar/2015, alle ore 21:18, Le Ny Conseil <
>> lenyconseil at gmail.com> ha scritto:
>> Thank you for notes.
>> But it doesn't work. Following the procedure, only thing disturb me. I
>> haven't got a local_settings.py.sample file so i cant' do that : Rename the
>> local_settings.py.sample to local_settings.py and edit it's content by
>> setting the SITEURL and SITENAME
>> My site displays a 404 error.
>> Any idea ?
>> 2015-03-24 6:04 GMT+01:00 GC-54 <nepanode at gmail.com>:
>>> The documentation for running a django project wrapper/skeleton hasn't
>>> been updated for use with 2.4 but after doing it realized it comes down to
>>> using an upstream version tag for the geonode-project github repo ... as an
>>> interim I took some notes on what I did to get Geonode 2.4b20+ running and
>>> customized on Ubuntu 14.04. Hope this helps, if there are any gaps let me
>>> know:
>>> https://github.com/DOE-NEPA/NEPAnode/wiki/Migrating-Current-NEPAnode-Site
>>> On Mon, Mar 23, 2015 at 8:08 AM, Le Ny Conseil <lenyconseil at gmail.com>
>>> wrote:
>>>> Hello Annalisa and dear list members,
>>>> I'm particulary interested in this topic because i've tried few weeks
>>>> ago to customize the look&feel of Geonode 2.4b22 without success.
>>>> Not sure that the documentation be up to date.
>>>> I have tried to replace my_geonode by a new template name, a new folder
>>>> was created in my home folder but i've never succeed to visualize my
>>>> geonode with the new templates.
>>>> Is there here a committer who could tell us more about this important
>>>> point ?
>>>> Thanks,
>>>> Happy spring day to everybody.
>>>> _______________________________________________
>>>> geonode-users mailing list
>>>> geonode-users at lists.osgeo.org
>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
>> Pierre-André Le Ny
>> *Le Ny Conseil*
>> http://www.lenyconseil.fr
Pierre-André Le Ny
*Le Ny Conseil*
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150324/7373f3f6/attachment.html>
More information about the geonode-users mailing list
