[GeoNode-users] Customizing a geonode 2.4 project
Francesco Bartoli
xbartolone at gmail.com
Tue Mar 24 15:48:49 PDT 2015
In this case you have to edit the local_settings.py under /etc/geonode.
Il giorno 24/mar/2015, alle ore 23:17, Le Ny Conseil <lenyconseil at gmail.com> ha scritto:
> Sorry, i'm a little bit lost.
> I've installed geonode on ubuntu 14.04 with apt and the ppa:testing package repository.
> Version 2.4b22.
> I didn't create virtualenv (I didn't follow this step : Installed Geonode_Project template for Isolation and Customization in Virtualenvironment). Maybe, it is the reason ?
> I haven't got found this local_settings.py.sample.
> I'm a disappointed now on this look&feel customization.
> Thanks for your suggestions.
> 2015-03-24 22:50 GMT+01:00 Francesco Bartoli <xbartolone at gmail.com>:
> I mean the local_settings.sample that comes with geonode source. I installed from that into an ubuntu 12.04 box. If you want just to customize a plain geonode you shouldn’t have the need of the geonode_project template. This should be used for adding a new geonode based application like the zinnia blog explained in the documentation.
> Hope this clarifies.
> Ciao
> F.
> Il giorno 24/mar/2015, alle ore 22:40, GC-54 <nepanode at gmail.com> ha scritto:
>> the local_settings.sample that comes with geonode_project shouldn't be used... instead you want to copy the local_settings.py from the newly installed geonode.
>> to find it run
>> $ sudo updatedb
>> $ sudo locate local_settings
>> ... (should find it in the .../python2.7/dist-packages/... dir)
>> On Tue, Mar 24, 2015 at 5:32 PM, Francesco Bartoli <xbartolone at gmail.com> wrote:
>> I did it yesterday and I can confirm that you find the local_settings sample file to be edited. I downloaded the beta22 tag from github.
>> Francesco Bartoli
>> Il giorno 24/mar/2015, alle ore 21:18, Le Ny Conseil <lenyconseil at gmail.com> ha scritto:
>>> Thank you for notes.
>>> But it doesn't work. Following the procedure, only thing disturb me. I haven't got a local_settings.py.sample file so i cant' do that : Rename the local_settings.py.sample to local_settings.py and edit it's content by setting the SITEURL and SITENAME
>>> My site displays a 404 error.
>>> Any idea ?
>>> 2015-03-24 6:04 GMT+01:00 GC-54 <nepanode at gmail.com>:
>>> The documentation for running a django project wrapper/skeleton hasn't been updated for use with 2.4 but after doing it realized it comes down to using an upstream version tag for the geonode-project github repo ... as an interim I took some notes on what I did to get Geonode 2.4b20+ running and customized on Ubuntu 14.04. Hope this helps, if there are any gaps let me know:
>>> https://github.com/DOE-NEPA/NEPAnode/wiki/Migrating-Current-NEPAnode-Site
>>> On Mon, Mar 23, 2015 at 8:08 AM, Le Ny Conseil <lenyconseil at gmail.com> wrote:
>>> Hello Annalisa and dear list members,
>>> I'm particulary interested in this topic because i've tried few weeks ago to customize the look&feel of Geonode 2.4b22 without success.
>>> Not sure that the documentation be up to date.
>>> I have tried to replace my_geonode by a new template name, a new folder was created in my home folder but i've never succeed to visualize my geonode with the new templates.
>>> Is there here a committer who could tell us more about this important point ?
>>> Thanks,
>>> Happy spring day to everybody.
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
>>> Pierre-André Le Ny
>>> Le Ny Conseil
>>> http://www.lenyconseil.fr
> Pierre-André Le Ny
> Le Ny Conseil
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150324/fc41e297/attachment-0001.html>
More information about the geonode-users
