[GeoNode-users] Customizing a geonode 2.4 project
John Jediny john.jediny at gmail.com
Tue Mar 24 19:17:44 PDT 2015
If you have any need to customize Geonode (install a 3rd party app or even
modify CSS HTML) you still want to use the Geonode project. As everytime
you update/upgrade Geonode using the ppa or merging/pull git you'll always
have to redo your work or resolve the conflict...
Two things to try for those still having probelms... 1.Remove your
existing installation if it is not within a python virtualenv.. I would
also suggest using virtualenvwrapper if you plan to install multiple 3rd
party apps creating a new wrapper env for each. Virtualenv will avoid new
apps from upgrading/downgrading the Python libraries that other apps or
Geonode depend on... Wrapper allows you to manage multiple virtualenvs
one for each Python app.
2. Make sure you use apache2's new permissions
See halfway through this thread for what I mean -
https://github.com/ckan/ckan/issues/1651. About require all granted...
If neither works open a new terminal and use it watch apache log $ sudo su
$ tail -f /var/log/geonode/apache.log
If your seeing permission denied then you need to use chown and/or chmod
700 for the www-data user and group of whatever file or dir Apache can't
access
On Tuesday, March 24, 2015, Francesco Bartoli <xbartolone at gmail.com> wrote:
> In this case you have to edit the local_settings.py under /etc/geonode.
> Il giorno 24/mar/2015, alle ore 23:17, Le Ny Conseil <
> lenyconseil at gmail.com
> <javascript:_e(%7B%7D,'cvml','lenyconseil at gmail.com');>> ha scritto:
> Sorry, i'm a little bit lost.
> I've installed geonode on ubuntu 14.04 with apt and the ppa:testing
> package repository.
> Version 2.4b22.
> I didn't create virtualenv (I didn't follow this step : Installed
> Geonode_Project template for Isolation and Customization in
> Virtualenvironment). Maybe, it is the reason ?
> I haven't got found this local_settings.py.sample.
> I'm a disappointed now on this look&feel customization.
> Thanks for your suggestions.
> 2015-03-24 22:50 GMT+01:00 Francesco Bartoli <xbartolone at gmail.com
> <javascript:_e(%7B%7D,'cvml','xbartolone at gmail.com');>>:
>> I mean the local_settings.sample that comes with geonode source. I
>> installed from that into an ubuntu 12.04 box. If you want just to customize
>> a plain geonode you shouldn’t have the need of the geonode_project
>> template. This should be used for adding a new geonode based application
>> like the zinnia blog explained in the documentation.
>> Hope this clarifies.
>> Ciao
>> F.
>> Il giorno 24/mar/2015, alle ore 22:40, GC-54 <nepanode at gmail.com
>> <javascript:_e(%7B%7D,'cvml','nepanode at gmail.com');>> ha scritto:
>> the local_settings.sample that comes with geonode_project shouldn't be
>> used... instead you want to copy the local_settings.py from the newly
>> installed geonode.
>> to find it run
>> $ sudo updatedb
>> $ sudo locate local_settings
>> ... (should find it in the .../python2.7/dist-packages/... dir)
>> On Tue, Mar 24, 2015 at 5:32 PM, Francesco Bartoli <xbartolone at gmail.com
>> <javascript:_e(%7B%7D,'cvml','xbartolone at gmail.com');>> wrote:
>>> I did it yesterday and I can confirm that you find the local_settings
>>> sample file to be edited. I downloaded the beta22 tag from github.
>>> Francesco Bartoli
>>> Il giorno 24/mar/2015, alle ore 21:18, Le Ny Conseil <
>>> Thank you for notes.
>>> But it doesn't work. Following the procedure, only thing disturb me. I
>>> haven't got a local_settings.py.sample file so i cant' do that : Rename the
>>> local_settings.py.sample to local_settings.py and edit it's content by
>>> setting the SITEURL and SITENAME
>>> My site displays a 404 error.
>>> Any idea ?
>>> 2015-03-24 6:04 GMT+01:00 GC-54 <nepanode at gmail.com
>>> <javascript:_e(%7B%7D,'cvml','nepanode at gmail.com');>>:
>>>> The documentation for running a django project wrapper/skeleton hasn't
>>>> been updated for use with 2.4 but after doing it realized it comes down to
>>>> using an upstream version tag for the geonode-project github repo ... as an
>>>> interim I took some notes on what I did to get Geonode 2.4b20+ running and
>>>> customized on Ubuntu 14.04. Hope this helps, if there are any gaps let me
>>>> know:
>>>> https://github.com/DOE-NEPA/NEPAnode/wiki/Migrating-Current-NEPAnode-Site
>>>> On Mon, Mar 23, 2015 at 8:08 AM, Le Ny Conseil <lenyconseil at gmail.com
>>>> <javascript:_e(%7B%7D,'cvml','lenyconseil at gmail.com');>> wrote:
>>>>> Hello Annalisa and dear list members,
>>>>> I'm particulary interested in this topic because i've tried few weeks
>>>>> ago to customize the look&feel of Geonode 2.4b22 without success.
>>>>> Not sure that the documentation be up to date.
>>>>> I have tried to replace my_geonode by a new template name, a new
>>>>> folder was created in my home folder but i've never succeed to visualize my
>>>>> geonode with the new templates.
>>>>> Is there here a committer who could tell us more about this important
>>>>> point ?
>>>>> Thanks,
>>>>> Happy spring day to everybody.
>>>>> _______________________________________________
>>>>> geonode-users mailing list
>>>>> geonode-users at lists.osgeo.org
>>>>> <javascript:_e(%7B%7D,'cvml','geonode-users at lists.osgeo.org');>
>>>>> http://lists.osgeo.org/cgi-bin/mailman/listinfo/geonode-users
>>> Pierre-André Le Ny
>>> *Le Ny Conseil*
>>> http://www.lenyconseil.fr
> Pierre-André Le Ny
> *Le Ny Conseil*
Cell: 973-931-0580
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20150324/f1213057/attachment.html>
More information about the geonode-users mailing list
